Built Engine questions
Old Apr 10, 2020 | 11:15 AM
clinthulk2's Avatar
clinthulk2
Default Built Engine questions
So I am planing to build a VQ35 to swap my original motor some time towards the end of this year.
The build is going to consist of:
- Tomie Cams
- Wiseco Forged Pistons 9.5:1 CR
- Carrillo Rods
- Darton mid sleeves 100mm bore
- Upgraded Main, Rod Bearings and Thrust Washers
- OEM crank from VQ37VHR
This will put the car at 4.0 displacement, I plan on boosting the car the following year after i save up for the Kit. Does anyone have any ideas how the car will run NA with this type of setup? Its a pretty big boost in displacement but I'm using lower compression pistons due to wanting to boost it in the future. Are there any NA setups out there with such a high displacement that anybody knows of?
Old Apr 10, 2020 | 11:23 AM
bealljk's Avatar
bealljk
- Tomie Cams
- Carrillo Rods
Do you have to sleeve the block? I, still, to this day have not come across a sleeved block that has a solid longevity. Can you boost an OEM 3.5liter block? You are going to spend a metric-ton of money to get .5liter more displacement based off a history of failures.
Everything is going to be more expensive and custom ...
I would keep it an OEM block and turbo it from there - plenty of success stories on this motor untouched.
The 9.5 compression will cost you power ... it'll run a little less power...you may be able to push timing a little more aggressively ...
Do you understand that a 4.0 liter engine, turbo engine will cost you well into the $25k to $50k when it's all said and done? Most people dont do this because it's simply not worth it. Call it $30k in engine work, upgrades, supporting mods to hit 800hp when for $10k you can have 750hp.
Old Apr 10, 2020 | 11:55 AM
iideadeyeii's Avatar
iideadeyeii
Old Apr 10, 2020 | 01:39 PM
travlee's Avatar
travlee
Master
I chuckled
Old Apr 10, 2020 | 01:46 PM
jhc's Avatar
jhc
General & Tech Moderator
Seems to be an influx of newbs w mile high goals lately.
Old Apr 10, 2020 | 03:03 PM
travlee's Avatar
travlee
Master
Because they are stuck home with nothing to do
Old Apr 10, 2020 | 03:06 PM
jhc's Avatar
jhc
Correct sir!
Old Apr 10, 2020 | 06:04 PM
bealljk's Avatar
bealljk
I'm just trying to be nice!
I told Mic that my new years resolution was to be 'less' of a dick ...
and who knows? Maybe this guy has $50k+ to sink into a $10k car? You never know!
Old Apr 10, 2020 | 06:21 PM
travlee's Avatar
travlee
Master
Glad I never made that statement.....
This build will more than likely never happen
Old Apr 10, 2020 | 06:29 PM
DarkZ03's Avatar
DarkZ03
I would never stroke this engine, and I generally don't give a damn about costs, just not worth it IMO. So far my seats and wheels cost me almost almost as much as my car, I regret nothing lol. Who needs 600+hp in this car anyway, just get something better at that point.
Old Apr 10, 2020 | 06:32 PM
jhc's Avatar
jhc
Dude! You're actually quite nice imho. How do they say,- "The Truth in Love?"
Old Apr 11, 2020 | 04:53 PM
Conway_160's Avatar
Conway_160
- Tomie Cams
- Carrillo Rods
So I'm going to play nice.
IF and ONLY IF you are starting with a HR block will this work!
If you use the VHR Crank, VHR rods, and Custom 100mm pistons you will be at 4.052L
How high do you plan on reving? That will be big factor into what cam's you get. More lift and more duration will move the power to the higher RPM's.
What is your tuning platform?
If you can use 93+ oct then up your compression to 10.5+.
To anwser your final question Sasha Anis has a 4+L N/A Z. But he also has $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ in to his car.
DreamZcometrue
Jul 26, 2016 08:43 AM
aas350z
Aug 28, 2014 11:11 AM
zerosec
Oct 20, 2009 10:35 AM
PWSHHOCKEY44
Aug 21, 2008 03:30 PM
leeboyNY
Sep 14, 2006 10:24 PM
