economical LSD
Old Jul 26, 2004 | 11:28 AM
TriX's Avatar
TriX
Default economical LSD
i have a base z and was thinking of buying an lsd. what are some more economical brands? i know nismo makes one but it is pretty pricy.
any suggestions? would ihave to change the clutch?
Old Jul 26, 2004 | 11:36 AM
zxsaint's Avatar
zxsaint
Fairlady Stalker
Maybe you can get the oem one off someone who upgraded to the nismo lsd?
Old Jul 26, 2004 | 11:45 AM
jor8888's Avatar
jor8888
$1000 for LSD is the average price and u dont want to get oem one from someone's car because u still need a few stuff just to make it work with the base model so u might as well buy a new LSD.
Old Jul 27, 2004 | 03:53 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the NISMO is a good bet, as is Cusco
Old Jul 27, 2004 | 08:13 PM
apex locator's Avatar
apex locator
and Kaaz
Old Jul 27, 2004 | 08:47 PM
S12 driver's Avatar
S12 driver
Maybe you could get a use VLSD from people who upgraded their LSD. or maybe get a Phamtom Grip LSD.
Old Jul 28, 2004 | 06:37 AM
Gsedan35's Avatar
Gsedan35
Just like jor8888 said, you don't want t go that route. I did, biggest modding mistake I have ever done on a car ever, bar none. I got a brand new viscous core for only $100 off a car pulled from the showroom floor. And yet when you add in all the parts that are required to do the conversion and the cost to install them (impossible to DIY), your at $900. And that's IF you get a viscous core for only $100 like I did. It wouldn't be so bad if the dang thing did a credible job of limiting slip, but it does not. I'm embarassed to admit I spent that kind of money with next to NO results. It allow's far to much slip to happen before it begins to lock to be worthwhile. And I do not track my car, were talking just aggressive street driving. Get a clutch type like the Nismo or wait for a Glen Torson type to come out.
You could not pay me enough to put a phantom grip type on even if they existed for the Z33/V35.
Old Jul 28, 2004 | 06:53 AM
Gsedan35's Avatar
Gsedan35
Default Re: economical LSD
Well, the Nismo is where it starts price wise. Call it the price of admission on the course to improving your car. I followed the ill advised temptation to skimp on spending money and I have a $900 hole in my pocket and a oem VLSD conversion that isn't a 1/4 as effective as I thought it would be. I paid the price for not really thinking things through.
The thing about the Nismo LSD is that it comes will all the parts you need to do a open diff conversion. If you did not get those parts with the Nismo you be looking at $300 for LSD stub axles, and $100 for LSD bearings and seals. That's $400 in required parts that come in the Nismo box. It even comes with diff oil.
The Nismo diff sells for $950-$900, installation is usually $400
Old Jul 28, 2004 | 04:24 PM
Tfasano's Avatar
Tfasano
Default Re: Re: economical LSD
Are your sure about this? I thought the open differtial used different stub axles than the LSD and they needed to be purchased seperatley??
Old Jul 28, 2004 | 06:44 PM
Gsedan35's Avatar
Gsedan35
Default Re: Re: Re: economical LSD
Your correct, I had to buy different stub axle's to do my oem VLSD swap. The Nismo LSD comes with the stub axle's you need, to convert a open diff to LSD. If someone already has the VLSD, those parts are extra's.
Here's a pic of what you get then you buy the Nismo LSD and lay out the parts in the box.
LSD
Stub axle's to convert from open diff
LSD bearings
LSD bearing seals
Diff oil
http://pics.montypics.com/Gcoupe35/2...smo_lsdbmp.jpg
Old Jul 29, 2004 | 02:22 AM
MY350Z.COM's Avatar
Is the Phantom Grip available?
Old Jul 29, 2004 | 06:05 AM
Traffic's Avatar
Traffic
Sort of. I think the Z33 uses the R200 differential. Phantom Slip makes a Z32/S14 application; they use the R200 diff. Either way, it's a bad, bad idea. Phantom Slip doesn't work. Either get a clutch-type or leave it stock.
If you're getting clutch-type LSD NISMO is the best bet, since they supply you with everything you need. Kaaz is slightly cheaper but they don't give you peripherals. However, if this is your daily driver, the noise may get to you.
Old Oct 21, 2004 | 08:47 AM
overboostedtoy's Avatar
overboostedtoy
has anyone tried to install a clutch type LSD? how difficult is it, scale 1 to 10? spcial tools required?
Old Oct 21, 2004 | 11:19 AM
Z1 Performance
Former Sponsor
Lots of us have Clutch type LSD's..install is not for the unexperienced. I had a drivetrain specialist install mine as there is specialized tools needed
Old Oct 23, 2004 | 12:26 PM
Edogg218's Avatar
Edogg218
I have a fair amount of mechanical knowledge and many specialized tools, but nothing like what is needed for this install.
After reading through both the included instruction manual and the FSM, I would suggest that you have this installed by a transmission specialist. The tolerances are tight, and a small error in alignment could destroy the gears and require an entire new rear-end.
Mine will be going in next week
Paul.
Oct 16, 2015 07:34 PM
seagrasser
Oct 11, 2015 03:27 PM
RiujinZero
Sep 25, 2015 01:19 PM
3vilbunny
Sep 13, 2015 12:31 PM
