Homemade Catch Can
Old May 17, 2007 | 01:13 PM
  #61
gothchick's Avatar
gothchick
Originally Posted by Eazzzzzzy
Best to use it ---Its Name Brand is "Chore Boy" and sold in all Grocery stores or Wal Marts---Comes in Stainless or Copper ---Function is never Ghetto------20" Spinners are Ghetto
Good call! Yeah, I used Chore Boy... Bought it at a Super Walmart. I was very careful to make sure there were no loose ends or free floating pieces of mesh in the canister. I also put a small magnet in the bottom, thinking that would help as well.
I would like to get a more professional looking catch can in the near future. But this was fun to put together & works pretty well for cheap.
Old May 21, 2007 | 03:47 PM
  #62
gothchick's Avatar
gothchick
Well, I've been running the mesh inside the canister for about a week, and it is definitely catching more oil now... :-) And just think, without a catch can all this blow-by would be sludging up the plenum, and going into the combustion chambers... YUCK!!
I'd really like to thank i8acobra for posting up this great idea for a DIY catch can!
Old May 25, 2007 | 12:05 AM
  #63
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
To drain it, you just take that nipple thing off the bottom?
Old May 25, 2007 | 12:29 AM
  #64
XuperXero's Avatar
XuperXero
You could. But it's much easier to twist it off from the cap and poor it out.. much less of a mess and easier to do rather than pushing that thing with a screwdriver and letting it drip out.
Old May 29, 2007 | 01:05 PM
  #65
zman2's Avatar
zman2
Default Catch can
Oil travels out of the valve cover in vapor form, not liquid, so it makes sense that stainless steel mesh
will interrupt the flow of oil vapor enough so that it condenses inside.
Borrowed from: http://www.saikoumichi.com/OCC_page.htm
Old Jun 8, 2007 | 06:42 AM
  #66
ktown z's Avatar
ktown z
Steeda sells these home made oil catch cans for the mustang for 70.00. Thats a rip off!!
Old Jun 8, 2007 | 06:50 AM
  #67
Mike Wazowski's Avatar
Mike Wazowski
but theirs comes with a mounting bracket
Old Aug 7, 2007 | 01:22 PM
  #68
Beeker's Avatar
Beeker
I am going to try picking up the parts for this tonight. I've been losing oil in my 2005 and I have a feeling this is where it is going. https://my350z.com/forum/showthread....HER+LOSING+OIL
I noticed puddles of oil in the plenum when I installed the spacer. I hope this catch can explains where the oil is going. I don't feel like dealing with Nissan if I don't have to. I'm sure they will give me a hard time with the mods I have installed.
Old Aug 21, 2007 | 03:43 PM
  #69
Mazinger Z's Avatar
Mazinger Z
So I went to home depot, and they didn't have the filter. Then I went to Osh, and saw they had a few starting from $24.99. Damn! Those things are expensive. I might just get a universal one for about the same price I would if I were to buy all the parts.
Old Aug 21, 2007 | 06:32 PM
  #70
athenG's Avatar
athenG
Help, I went to homedepot and all i can see is the HDA70403AV I looked at the sku # on Homedepot.com for the HDA70400AV and it is the same as the HDA70403AV.
Old Aug 22, 2007 | 06:55 PM
  #71
__jb's Avatar
__jb
Z + Rear Seat
My catch can didn't seem to be catching much oil, so I thought I'd try an upgrade. I put some coarse stainless steal 'pot scrubber' mesh in the can to give the oil something to condense on. It seems to be catching more blow-by now...
Is your catch can supporting itself off of the strength of the tubing, or is there a mount somewhere that I can't see?
Old Aug 23, 2007 | 12:46 PM
  #72
gothchick's Avatar
gothchick
Yeah, it basically does support itself on the strength of the tubing (since it's a short length of high pressure tubing). But I also zip tied it (snug, but not too tight) under the strut bar just to make sure it doesn't move around. Been running this mod for several months now... Works flawlessly. :-)
Old Aug 28, 2007 | 05:27 AM
  #73
StreetOC192's Avatar
StreetOC192
OK, I might be a little slow on the uptake here.....
For an N/A car, this will help eliminate oil puddling on the lower plenum. Does this mean it will help keep the oil from blowing by and causing so much black deposit in the exhaust? That's pretty much the only advantage in an N/A car?
And is it possible/desirable to maybe have this catch can drain back into the oil pan? Would that help out with the oil consumption problem? I know I am tired of adding a quart every 10 days.
Old Sep 3, 2007 | 07:16 PM
  #74
Alvinpv's Avatar
Alvinpv
i read this whole thing and and dont understand what you do when it fills up. do you just put it back in the motor ? thanks
Old Sep 3, 2007 | 07:30 PM
  #75
Mike Wazowski
just throw it away
Old Sep 3, 2007 | 07:50 PM
  #76
Alvinpv's Avatar
Alvinpv
thanks so i guess every so often you will need to add a little oil then
Old Sep 3, 2007 | 07:54 PM
  #77
Nexx's Avatar
Nexx
ahhh, you should be changing your oil faster then you are losing enough oil to have to put more in.
Old Sep 3, 2007 | 07:55 PM
  #78
Alvinpv's Avatar
Alvinpv
ok just wondering and yes i change my oil every 3000 miles i just didnt know how much it would be filling up
Old Sep 3, 2007 | 09:19 PM
  #79
XuperXero's Avatar
XuperXero
Just wondering, have you guys ever smelled the oil?
Out of curiousity last time I emptied the catch can, I smelled the oil. It had heavy scent of gasoline... how's it getting into my oil?
Old Sep 3, 2007 | 10:50 PM
  #80
i8acobra's Avatar
i8acobra
The purpose of the PCV is to vent gasoline vapors out of your crankcase and back to your intake to be burned. This is why the oil in the can smells like gas. It's also why oil from the can should never be dumped back into the motor.
