Homemade Catch Can
Old Sep 6, 2007 | 11:41 AM
  #81
Quamen's Avatar
Quamen
In regards to a boosted application:
Should both the passenger and driver side PCV lines go to a pre-supercharger/turbocharger pipe that doesn't see boost or can the driver side operate with boost because of internal baffling?
Old Sep 6, 2007 | 11:49 AM
  #82
Quamen's Avatar
Quamen
The PCV is run from the passenger side valve cover to the plenum. The crankcase breather tube is run from the rear of the drivers side valve cover to the intake pipe on the drivers side turbo.
Found it out. Air is sucked in through the driver side (breather) and sucked out on the passenger side. With that in mind I am just going to put a breather filter on the driver side and run the passenger side through my catch can and connect the catch can to a vacuum source pre-supercharger for my application.
Old Sep 6, 2007 | 12:02 PM
  #83
gringott's Avatar
gringott
Pre-boost IMHO, or you will have problems I would think. You would end up pressurizing the engine block, I would think oil and fumes would blow out the path of least resistance, along with your boost. Mine are pre-boost.
Old Sep 6, 2007 | 12:14 PM
  #84
Quamen's Avatar
Quamen
Thanks. I am going to put a breather filter on the driver side and connect the passenger side to pre boost vacuum and leave the crossover from the driver side to passenger side as is.
Old Sep 9, 2007 | 03:40 PM
  #85
StreetOC192's Avatar
StreetOC192
I just completed my install. I went to Lowes and got the following since they don't seem to carry the Campbell Hausfield anymore. Thanks to i8acobra for this great DIY mod.
Kobalt filter model#221024
And Kobalt Barb/clamp combo packs model#124224
Old Sep 16, 2007 | 04:12 PM
  #86
Darth Zader's Avatar
Darth Zader
I didn't manage to find the catchers you guys have used but I did find one, which I installed today. Once I was done, I noticed I could hear a sound coming from the hose area and began looking for any creasing in the hose. Out of curiosity, I touched the little release button on the bottom and it was drawing air INto the catch. I double-checked that the arrow was pointing to the plenum and that the lines were not pinched. My catch has a release valve on the bottom that is held closed by a spring. Pressing the button on the bottom opens the valve and drains the liquid. If the valve is sucking air in, then it is being sucked open due to negative pressure in the can. At this point, I am not going to keep the can on until I can get it right.
What's going on? Why would there be negative pressure in the can and where would that pressure be coming from?
Old Sep 26, 2007 | 08:21 PM
  #87
350zenvy's Avatar
350zenvy
bumping an old thread. I did this over the weekend, removed the entire filter and baffle assembly, this is correct right? Any rate I notice that there is a sucking kind of noise. I've checked all the clamps and they are on tight and the arrows are pointing to the pleneum. Anyone else have a slight noise coming from the catch can?
Old Oct 2, 2007 | 10:19 AM
  #88
gothchick's Avatar
gothchick
The passenger side (bank 1) is under vacuum, Make sure the catch can baffle is screwed in tight. If you have a leaky release valve, epoxy will do the trick to seal it up.
Old Oct 10, 2007 | 02:56 PM
  #89
VQ40's Avatar
VQ40
Aside from keeping the plenum cleaner, are there any performance gains from this mod?
Old Oct 10, 2007 | 03:06 PM
  #90
gringott's Avatar
gringott
By theory, less oil in the plenum means there will be a lessening of the effect of oil vapors added to the air fuel mixture. Burning the oil vapors vs. using condensation to remove the oil vapors. Using a breather or filter that is not connected to the plenum would have the same effect, but you would notice/smell the vapors, and would be releasing the oil vapors into the atmosphere.
Old Nov 4, 2007 | 01:07 PM
  #91
StreetOC192
I was asked how I sealed up the nipple at the bottom of the catch can.....
1 - removed the 'c' clip that holds the barb in the housing
2 - removed spring
3 - replaced barb and 'c' clip
4 - while pushing the barb out with a screwdriver from inside the housing, I placed a vacuum cap on the barb (cut to length)
5 - zip tied it as tight as I could get it because I had no hose claps that small.
Here's a pic of the finished product (sorry it's a camera phone pic):
EDIT: that pic sux, I'll try to get a better one soon.
Old Nov 9, 2007 | 05:45 AM
  #92
grudum's Avatar
grudum
So I threw one of these on last night, followed the instructions, sealed everything up, clamped the 50psi fuel hoses down, the flow is going toward the manifold. I glued the bottom valve shut, so no air gets in or out.
Started it up. There is a slight hiss on the longer lenght of tubing im guessing from the vacume narrowing the tub, but it still flows. Let it run for a bit and every min or so, there was a click in the engine bay and the idle rpms would drop to about 400. It would still run, but just kind of hicup for a second and ran rough for a moment.
After a 15 min idle the CEL came on. I did the pedal trick, turned it off. It came back on, I turned it off again, connected a big ground wire from the neg batt to the frame and went to bed.
This morning, no CEL, and the car ran fine. The catch can already caught some oil, so i wanna keep it, but i also want the car to run properly.
What do you make of that?
Old Nov 9, 2007 | 06:34 AM
  #93
Zivman's Avatar
Zivman
I would guess you have a vacuum leak if the problem continues
Old Nov 9, 2007 | 12:33 PM
  #94
jetnoirZ's Avatar
jetnoirZ
is this work just as well for us vq35hr guys?? has anyone done it on their HR??
Old Nov 9, 2007 | 01:33 PM
  #95
Zivman's Avatar
Zivman
Originally Posted by jetnoirZ
so i take that as dont do it to the HR
I was just playin' with you... it will be fine. Install the same way off the PCV routing it into the plenum
Old Nov 13, 2007 | 02:53 PM
  #96
Nexx's Avatar
Nexx
installed this today, not sure why i waited so long but man it was a piece of cake even for a mechanically retarded person as myself. i recommend everyone to do this mod. its cheap, and effective.
Old Dec 3, 2007 | 07:54 AM
  #97
350zenvy's Avatar
350zenvy
Mine seems to fill up all the way to the top every 3-4 weeks. Anyone else running into such a high consumption. I also have a slight hissing noise but not CEL, anyone else? Is it imperative to seal the botto nipple even if it has a cap?
Old Dec 3, 2007 | 08:15 AM
  #98
Mike Wazowski's Avatar
Mike Wazowski
all the way to the top is less than 1/2 an ounce. Not much consumption there at all.
Old Dec 17, 2007 | 07:17 PM
  #99
maximumsportZ's Avatar
maximumsportZ
Finally get to do this after getting the car back.
I picked up the filter @ lowes, it's blue so it matches haha.. it's by Kobalt.
only thing I notice it has a small barb at the bottom with a spring to push it out when its filled I guess, will this leak? should I cap it off? Heres a blurry phone pic:
I see the husky's come with a vac cap on the bottom of theirs. I think the newer ones have this valve that opens and closes it but I wouldn't trust that...
Thanks.
Old Dec 19, 2007 | 12:00 PM
  #100
gothchick's Avatar
gothchick
I'd put a dab of epoxy on it from the inside to seal it up.
