Engine Swaps For all your engine swap experiences, ideas, questions, & more..
The Official LS Swap Info/Questions Thread
Old Oct 19, 2011 | 10:59 AM
  #341
Royal_T's Avatar
Royal_T
^^ Damn that thing is sexy bro.. and you are a boss to rock the Magnum T56
Old Oct 19, 2011 | 11:01 AM
  #342
QTB's Avatar
QTB
It isn't working yet, but thanks. I'll keep updating as it progresses.
Old Oct 19, 2011 | 02:16 PM
  #343
bbs350z's Avatar
bbs350z
^would be interested in seeing somebody rock a tr6060 as well!!
also, the gto piece fit perfectly with no modifications anywhere. now my sikky shifter sits and shifts perfectly
Old Oct 20, 2011 | 06:23 AM
  #344
QTB's Avatar
QTB
The machine work is done! The guts from the sikky shifter appear to fit. I'm going to do a test fit tonight to see how much, if any tunnel work will need to be done.
...another crappy cell pic. I'll get some with my actual camera tonight.
Old Oct 20, 2011 | 11:20 AM
  #345
bbs350z's Avatar
bbs350z
Jesus that thing is a beast!
Old Oct 20, 2011 | 12:12 PM
  #346
Cass007's Avatar
Cass007
Originally Posted by bbs350z
alas, i have pretty much everything ready to go, however, swap guys need to check the sides of there block for the factory ls dipstick hole and make sure its plugged. i am en route to get this plug (its a freeze plug of some sort is my understanding) and has to be plugged, as our oil pan has the provision for the sikky dipstick. heres the gm part number 12557520
Pic of where the plug needs to go please. I'm texting the tuner now.
Old Oct 20, 2011 | 12:31 PM
  #347
bbs350z's Avatar
bbs350z
heres that stupid hole lmao
Old Oct 20, 2011 | 12:50 PM
  #348
makdaddynuge's Avatar
makdaddynuge
so the only reason people are wanting to run the nissan ecm along side the ls ecm is for stock gauges to work? What about ABS? is the nissan ecm needed for anythign else?
Would it be possible to only use the ls ecm and just run aftermarket gauges? I do not care to run a/c either
Old Oct 20, 2011 | 12:55 PM
  #349
Cass007's Avatar
Cass007
After searching much of the interwebs and getting ditracted by boobies everywhere I found this:
http://ls1tech.com/forums/13239315-post4.html
LS2 stock dipstick is in the pan... no holes to plug for me.
And another reason why LS2>LS1
Old Oct 20, 2011 | 01:05 PM
  #350
QTB's Avatar
QTB
My LS2 has the dipstick hole, but it's from a Vett. Hmmm I didn't think there were different versions of the LS2 block?
Old Oct 20, 2011 | 01:07 PM
  #351
QTB's Avatar
QTB
Ah, I should have looked at the pic first. The GTO block is plugged and uses the pan where the Vett just uses the block.
Old Oct 20, 2011 | 01:45 PM
  #352
Royal_T's Avatar
Royal_T
Well I just talked to Sikky today and they said the kit is suppose to come with a plug for the old dip stick location. So they are shipping me the piece.
Old Oct 20, 2011 | 01:47 PM
  #353
QTB's Avatar
QTB
Did they say what the threaded brass plug is for?
Old Oct 20, 2011 | 06:53 PM
  #354
bbs350z's Avatar
bbs350z
dang im gonna call sikky and get that piece, gm was closed when i was went for it
Old Oct 21, 2011 | 10:31 AM
  #355
Royal_T's Avatar
Royal_T
Yup this is what he told me:
"And yes your hardware kit should have included a 1/8 NPT Pipe Plug."
Old Oct 21, 2011 | 10:44 AM
  #356
bbs350z's Avatar
bbs350z
^lol do they not know that its a freeze plug lmfao. back to gm it is...again
Old Oct 21, 2011 | 10:46 AM
  #357
QTB's Avatar
QTB
Great, so when it leaks I'll at least know why
Old Oct 21, 2011 | 11:34 AM
  #358
Fluid1's Avatar
Fluid1
One of you guys actually completing the swap should put a thread out there with a complete list of the **** you "would" have done had you known what you know now.
Old Oct 21, 2011 | 11:42 AM
  #359
bbs350z's Avatar
bbs350z
^im doing that during my swap lol. motor and trans is back out again so i can get everything done once and for all
Old Oct 21, 2011 | 12:09 PM
  #360
Fluid1's Avatar
Fluid1
Awesome.
