Engine Swaps For all your engine swap experiences, ideas, questions, & more..
The Official LS Swap Info/Questions Thread
Old Oct 6, 2014 | 09:33 PM
  #1521
sh0rtys463's Avatar
sh0rtys463
For those of you with the Sikky Kit, did you find a solution for the shifter? I sent mine to them and they are "fixing" it but suggested I call my old one a loss and buy the new one...how convenient for them.
Old Oct 7, 2014 | 07:22 AM
  #1522
Royal_T's Avatar
Royal_T
There was a fix on here somewhere.. You have to make a spacer with different mounting locations to move the shifter. Sucks that they would not just replace the old shifters with new ones should be like a recall..
I have a feeling I will have to do the same
Old Oct 7, 2014 | 09:45 AM
  #1523
sh0rtys463's Avatar
sh0rtys463
Yeah since these came with a known flaw they should be responsible for it..not suggest spending another $500 on their new and improved version that MAY actually work
Old Oct 10, 2014 | 01:27 PM
  #1524
bbs350z's Avatar
bbs350z
hey guys, listed my 0 mile fully built ls1 for sale. going a diffrent route and trying to recoupe some expenses on my car prior to selling it. help me out!!
https://my350z.com/forum/engine/5983...w-0-miles.html
Old Oct 13, 2014 | 08:09 AM
  #1525
Cass007's Avatar
Cass007
Not nearly as Baller as Royal ... but it's still running ...
Old Oct 14, 2014 | 06:56 PM
  #1526
bbs350z's Avatar
bbs350z
gents... selling my entire drivetrain. literally drop in built motor, built trans, turbo setup. complete. listed at less than half what i spent.
https://my350z.com/forum/engine/5985...d-pricing.html
Old Nov 18, 2014 | 12:11 PM
  #1527
De La Money's Avatar
De La Money
do anyone have a wiring diagram/workup for using a PSI wiring harness for the the cooling fans/tach/etc?
Old Nov 19, 2014 | 04:56 PM
  #1528
cslithergo's Avatar
cslithergo
Default Not much but its Running!
Yes - I know, look at all those wires. Cutting them out slowly
Old Nov 28, 2014 | 08:27 AM
  #1529
SpartanZ32's Avatar
SpartanZ32
Default Wiring
To all of those with running/driving Z's with LS swaps, would you be so kind as to post what harness you are running (ie:PSI, Chasebays, Wiring Specialties, etc)? Or if it's a custom harness, let us know.
What functions did you lose (ie:AC, gauges, etc)?
Also, interior shots of your aftermarket gauges would be much appreciated.
In sure I speak for others who are in the middle of these swaps, we are envious that you already have the end result of what we are currently working on......and any little bit of info on wiring would be VERY helpful to me.
My engine/trans is going in this weekend, and the wiring is the only thing that I'm concerned with. Thanks in advance guys!!
Old Nov 29, 2014 | 05:42 AM
  #1530
Royal_T's Avatar
Royal_T
So I am running a track setup so no A/C here and not running the OEM gauges.
I am running a ChaseBays harness which is a piece of ****, So do not buy from them. We had to rewire everything.
Also for my gauge setup I am running a STACK and a Speedwire switch panel..
And now for pics..
And a vid.. Why not
Old Dec 1, 2014 | 08:35 PM
  #1531
armt350z's Avatar
armt350z
I'm using the GMPP harness that came with the EROD LS3. It has all of 12 or so wires to dick around with so it was pretty painful.
For gauges I'm running a full set of speedhut gauges. tach, GPS speedo, volt/fuelmeter mix, water temp and a oil psi gauge. I'll edit the post later when i'm home and see if I can find my gauge photos but it should be in my build thread.
The easiest way I found if your going to buy aftermarket gauges and dont need A/C then buy almost any off the shelf harness for your year LSX designed to be used in hot rods or rat rods. They have almost no interfaces with the Z chassis and really simplifies things up.
Old Dec 2, 2014 | 11:11 AM
  #1532
mkiv20vt's Avatar
mkiv20vt
Custom truck harness that came with the LQ9. Modified myself with help from lt1swap.com.
Speedhut tach, DEFI Oil pressure and Coolant Temp, Innovate WB. Deleted AC (never used it). Retained factory DBW (has anyone else done this as well?).
Old Dec 2, 2014 | 11:13 AM
  #1533
mkiv20vt's Avatar
mkiv20vt
And now for pics..
Dat switch panel doe. Makes me jelly.
Old Dec 2, 2014 | 12:11 PM
  #1534
armt350z's Avatar
armt350z
I'm running DBW as well but with a corvette pedal assy.
Old Dec 3, 2014 | 06:31 AM
  #1535
mkiv20vt's Avatar
mkiv20vt
Did you have to modify the pedal assembly to fit properly?
I used a pedal from an escalade and had to modify the bracket to fit and not feel awkward.
Pic before I welded it all up.
Old Dec 3, 2014 | 10:14 AM
  #1536
armt350z's Avatar
armt350z
I unbolted and removed the OEM assy, made a T bracket and drilled holes to get it placed where I wanted. With the bracket it bolts to the oem location and sits just slightly behind the brake pedal.
Old Dec 9, 2014 | 04:58 PM
  #1537
Stock-Ish's Avatar
Stock-Ish
My build has been put away for almost a year for some big changes in life again, now ive been getting ready to pick where i left off and finish this winter. So ive been scrolling through the last pages to see if anyones going more or less my route, any dedicated drag cars in here?
Im surprised that some ppl still are having problems with their sikky kit, i though they would have fixed that by now. I have a FR kit and it was well built, engine placement much better than sikkys, then i thought i could do better and i moved the entire drivetrain 4 full inches behind where the FR kit sits, thing looks buried in there!
Someone here lives close to pittsburgh???? Man i need some wrenching company
Old Dec 10, 2014 | 04:40 AM
  #1538
Classy's Avatar
Classy
The only Drag 350Z's with LS swaps was Snyper with his turbo'd LS2 and later nitrous fed LS7, and Z33 art with his built nitrous fed LS1. Both cars are gone.
Old Dec 10, 2014 | 06:36 AM
  #1539
Royal_T's Avatar
Royal_T
Yeah just like Classy said those are the only two I know off.
Also to comment on the Sikky thing.. They have just upgraded there shifter,oil pan and some other things.. In my opinion I feel sikky is a way better product then FR.. But hey I am bias..lol
Old Dec 10, 2014 | 07:13 AM
  #1540
Stock-Ish's Avatar
Stock-Ish
Those cars didnt seem to be around for very long,, ii liked the direction Quamans car was going, its a shame he sold it. I would have loved to see him dig deeper in the 9's
