Engine Swaps For all your engine swap experiences, ideas, questions, & more..
My 2JZ-GTE VVTI swap thread.
Old Sep 6, 2013 | 11:10 AM
  #261
Highway Riding's Avatar
Highway Riding
Originally Posted by Cubano4ever
Maybe the tranny was already bad who knows i buy my car with 43k miles who knows qhat it have go thru .. I just know mine break
That's more likely the situation as some tranny's did have some grind issues etc.. But CD009's are also widely known to be able to hold very good HP an torque. Alot of guys on here from the 2006 and up era were blowing motors left and right @ HP levels well over 500HP all while the trannys held up.. Guys on clublex and supraforums are starting to go this route as they are more affordable then V160's and also 6 speed..
Old Sep 6, 2013 | 11:13 AM
  #262
midz350's Avatar
midz350
Originally Posted by 420og35
And midz this is what you did. You bought a 2j flywheel and a z clutch and made new holes on the flywheel???
Yes and then balance them together. This way you can use the 2JZ starter and use off the shelf VQ35 clutch. Also you can use a thinner adaptor plate to help with the tight fit between the engine and fans.
Old Sep 6, 2013 | 11:22 AM
  #263
Cubano4ever's Avatar
Cubano4ever
Ive read alot in supra forums about the Z tranny in all the threads i find they said is not worth it that the Z tranny have syncro problems and bla bla bla that they dont hold high and all that
Old Sep 6, 2013 | 11:24 AM
  #264
420og35's Avatar
420og35
But how would I get a thinner adapter plate. Collins is the only one that makes one?? And the machine shop can balance as well
Old Sep 6, 2013 | 11:29 AM
  #265
Cubano4ever
There are always false information spread in the internet it always happen ive read alot of info and threads of lots of supra forums and many people are using the stock r154 till 800 hp .. Some till 700 - 750 what kill it is hard launches .. For a roll racing car i dont see a problem with it ..
Old Sep 6, 2013 | 12:01 PM
  #266
midz350's Avatar
midz350
Collins offer two methods. You either get the crank / flywheel spacer and the thick adaptor plate or get the clutch / flywheel ket he offers with the other adaptor plat (it should be thinner)
With the first one you will have a problem, the engine will hit the radiator fans shroud and you need to move it to the front of the rad.
The other one is kinda pricey. Around $2000 for the ~650hp clutch kit.
The easier/cheapest method is to bolt the 2JZGTE Flywheel to VQ35 clutch and fabricate your own adaptor plate.
Old Sep 6, 2013 | 10:02 PM
  #267
420og35's Avatar
420og35
Unfortunately I have no way of making my own custom plate. So I'm kinda stuck with him making the adapter plate. Is it hard to move the fans to the front of the radiator
Old Sep 7, 2013 | 08:50 PM
  #268
Cubano4ever
midz350z make sure you post pics of how the engine sits with ur custom motor mounts and how you make the tranny shifter shorter .. i believe the hardest part of the swap will be to make the shifter shorter to work .. when my friend swap his 2jz on the Z he used collins adapter plate and clutch and the stock 2jz motor mounts and the hardest part was to get the dimensions and make the tranny shifter shorter to be able to work... good luck man
Old Sep 7, 2013 | 10:37 PM
  #269
midz350's Avatar
midz350
There is only one way to shorten the shifter. Unless you're gonna shave the bell-housing.
http://www.rawbrokerage.com/mckinney...ket-vq35-vg30/
Old Sep 7, 2013 | 10:41 PM
  #270
Cubano4ever
what about on the 07-08 Z that have the shifter different .. the fisrt pic of the black shifter dont really look shorter
Old Sep 7, 2013 | 10:50 PM
  #271
Cubano4ever
your shifter is different from 07-08 Z i wonder if that shifter work on a 07-08 tranny and wowwwww that part they sell in the link you add looks really easy to do with it .. is that thing plastic????? looks like plastic
Old Sep 7, 2013 | 11:00 PM
  #272
midz350's Avatar
midz350
I'm just trying to give you an idea. You only can shorten the same distance.
I haven't done anything to the shifter yet. Hopefully this week.
I have a 2008 too, I think its the same shifter IIRC.
Old Sep 7, 2013 | 11:06 PM
  #273
midz350's Avatar
midz350
There are like 3-4 guys selling that bracket. Its billet.
They all give the same length.
Old Sep 7, 2013 | 11:14 PM
  #274
Cubano4ever
when using the Z tranny you have to cut the shifter by alot man maybe more tham the pic you post ..
Old Sep 7, 2013 | 11:21 PM
  #275
Cubano4ever
i just gonna wait till you do yours since is the same year as my car so i can get the idea of how it is .. dont forget to post pics when your shifter is done
Old Sep 7, 2013 | 11:23 PM
  #276
midz350's Avatar
midz350
You can only shorten it about 4".
Read here:
https://sites.google.com/a/vq240z.com/www/shiftermount
Old Sep 7, 2013 | 11:28 PM
  #277
Cubano4ever
watch this thread here
https://my350z.com/forum/media-share...-2jz-swap.html
this is my friends hes car is a 07 he use the stock 2jz mounts watch how the shifter was done in the pics i think if you use custom mounts you gonna have to shorter the shifter even more
Old Sep 22, 2013 | 08:51 PM
  #278
midz350's Avatar
midz350
Finally the exhaust manifold is here. Now we can start test fitting the engine in the car.
Also picked up:
1-Titan fuel rail.
2-Momo sterring wheel.
3-Momo shift ****.
4-AEM 4BAR MAP sensor.
Also about to order these parts from Gruppe-S:
1-2JZGTE ARP head studs.
2-2JZGTE OEM head gasket.
4-AEM Boost solenoid
5-Replacement STRI gauges.
6-350z Whiteline Urethane Bushings. Most of the front ones.
7-BC cam gears.
8-Gates racing timing belt.
Old Oct 5, 2013 | 12:55 PM
  #279
Cubano4ever
updates
Old Oct 5, 2013 | 01:19 PM
  #280
midz350's Avatar
midz350
We cut some of the firewall to try to push the engine back more to clear the fans. I'm out of town this week and my friend is working on other cars, so maybe next week will start dropping the engine in.
I have pics but I can't find my damn camera charger.
