CF Hood...trouble latching?
Old Jan 4, 2007 | 10:26 PM
Mazinger Z's Avatar
Mazinger Z
Default CF Hood...trouble latching?
I just got a Fiberimages hood from a member on this board. I can't seem to latch down the hatch. The hood looks perfectly fine, I was thinking maybe the strut bar is rubbing? I pushed the hood (pretty hard) all the way down...still not latching...help?
Old Jan 4, 2007 | 10:27 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Have you tried adjusting your latch up?
Old Jan 4, 2007 | 10:28 PM
Mazinger Z's Avatar
Mazinger Z
How do you do that?
Old Jan 4, 2007 | 10:34 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Originally Posted by bugsbbunny
How do you do that?
You should be able to loosen the bolts that hold up the latch and adjust the latch up or down to make it fit better.
Old Jan 4, 2007 | 10:39 PM
Mazinger Z's Avatar
Mazinger Z
Thanks, I will look for that.
Old Jan 4, 2007 | 11:28 PM
Mazinger Z's Avatar
Mazinger Z
Well, I loosened the (3) bolts and adjusted it all the way up towards the hood. Still not latching. Right now, I just put the latch to one side and held it up with one screw. Now the hood closes all the way down. I might have to modify the 2 holes so the latch will sit even higher
Does anyone have other ideas? I don't really want to modify those holes.
Old Jan 5, 2007 | 04:15 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
The part of the hood that attaches to the latch...if it is a metal piece you can place washers to make it sit lower
Old Jan 5, 2007 | 04:30 AM
chsia's Avatar
chsia
Default Hole in One
The Seibon VSII hood was hitting the plenum, so I cut a hole as shown in the pics. Also took out the strut bar. The hood closed fine with a push.
Attached Thumbnails CF Hood...trouble latching?-hood-hole-1.jpg   CF Hood...trouble latching?-hood-hole-2.jpg
Old Jan 5, 2007 | 05:42 AM
Jim@Showstoppers's Avatar
Jim@Showstoppers
What strut bar and plenum are you running ?
Old Jan 5, 2007 | 05:53 AM
drap660's Avatar
drap660
Hey Carbon, I just purchased a TS hood from you guys and I am running a 5/16 MD spacer.... Am I going to run into any issues???
Old Jan 5, 2007 | 06:48 AM
THE TECH's Avatar
THE TECH
Anyone with a strut bar may run into probs with these hoods. Seibon claims OEM fitment, but that's def not reality.
Old Jan 5, 2007 | 09:42 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
It looks like an OEM strut bar in the 2nd picture
Old Jan 5, 2007 | 10:55 AM
Chebosto's Avatar
Chebosto
i also forgot to mention, if the hood it too far forward, or too far back, it may also have latching issues. i ran with stock strut bar and the cusco one.. both no problems..
you may also be not pressing down hard enough in the front. you need to press you hand down right over where the latch is..
Old Jan 5, 2007 | 03:05 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I have seen a CF hood fit poorly because of interference with a cooling plate.
Chris
Old Jan 5, 2007 | 05:09 PM
Cannysage's Avatar
Cannysage
this seems to be a fairly common issue with seibon hoods... also, removing the strut bar completely is not a bright idea.
Old Jan 6, 2007 | 03:00 AM
chsia's Avatar
chsia
Looks like Seibon hoods are hits and misses. I had a 5/16 MD spacer too and needed to cut a hole in the hood right above the edge of the plenum in order to close the hood. Be prepared to spend some time on this job.
Old Jan 6, 2007 | 05:34 AM
Jim@Showstoppers
OP hood is not a Seibon but a fiber images.
alphared
Aug 21, 2014 04:04 PM
350zlawyer
Jul 3, 2005 12:57 PM
tom11204
Sep 11, 2004 08:57 AM
muscleknight
350Z Roadster
Sep 8, 2004 12:50 PM
Zcool
350Z Roadster
Jul 6, 2004 05:23 PM
