Beep?
Old Nov 26, 2007 | 07:42 PM
johns350's Avatar
johns350
Default Beep?
OK - driving home this evening - got off of highway and onto 'slow' back road. I set cruise @35mph - and I heard a 'beep' after about 1 min. Sounded like it came from dash. Never heard it before. Came to stop sign. Went through all of the computer options - nothing flashing. Took off again - hit resume on cruise. After about 1 min - 'beep' again.
I've looked at cell phone, blackberry, etc - all charged - no messages, etc. So - I really don't think it was from either of those. But the sound was similar.
So - I know this really sounds wierd - but does the cruise have a 'reminder' beep? Or - ANY other possible source of that beep? I only heard it twice - will listen for it again tomorrow morning - same road, different direction!
TIA
Old Nov 26, 2007 | 07:50 PM
SiNzz's Avatar
SiNzz
Weird...can't really comment cuz I never use cruise (damn traffic). Curious to know what it ends up being though.
Old Nov 26, 2007 | 07:57 PM
SniperHunter's Avatar
SniperHunter
Do you have navi?
Old Nov 26, 2007 | 07:59 PM
justinrhenry's Avatar
justinrhenry
it's not coming from your car. the cruise doesn't beep. maybe it's the beep soundtrack you have in your cd player.
Old Nov 26, 2007 | 08:31 PM
The Brickyard Rat's Avatar
The Brickyard Rat
was the beep barely audible? If so, I've had the same thing happen a couple of times. Never have figured out what caused it.
Old Nov 26, 2007 | 08:33 PM
Hoods's Avatar
Hoods
Were you using your CC at all?
Old Nov 26, 2007 | 09:37 PM
z2g's Avatar
z2g
low tire pressure i guess
Old Nov 26, 2007 | 10:38 PM
Smulak's Avatar
Smulak
agree with you but maby ICY on road
Old Nov 26, 2007 | 11:13 PM
RanFerr_350z's Avatar
RanFerr_350z
^^^^ +1 i believe it's the temp gauge as well. This happened to me a couple of days ago when it was right about 35-34 degrees outside. It beeped and said "ICY" underneath the temp.
Old Nov 26, 2007 | 11:16 PM
reden's Avatar
reden
oh snap
Old Nov 27, 2007 | 03:41 PM
Spike100's Avatar
Spike100
It's probably your TPS indicating a low pressure at one of the corners. The beap is low and intermittent.
You can verify this by the "!" symbol that displays on your dash if in fact it is low tire pressure. If you don't see this symbol, then it's something else.
--Spike
Old Nov 28, 2007 | 08:24 AM
Master Shake's Avatar
Master Shake
As everyone else is saying... Check your TPS. All four tires need to be higher than 28 PSI -- if just one is 28 or less, then you will get a beep. If not TPS, then check the outside temp.
Old Nov 28, 2007 | 12:20 PM
MyFairladyZ2006's Avatar
MyFairladyZ2006
Eh I never heard any beeps
Beamm
Jul 31, 2013 03:36 PM
vice86
Aug 21, 2004 07:16 AM
amairmech
Jun 22, 2004 12:18 PM
NissanJunkie
Texas
Dec 5, 2003 06:17 AM
iklim
Sep 8, 2003 03:36 PM
