Depo 06+ style headlights and other aftermarket headlights thread
Old Sep 2, 2013 | 07:50 PM
  #201
freddys 350z's Avatar
freddys 350z
all you need to do is put aluminum tape on the inside. no biggie. nissan just puts more layers of paint on their parts.
Old Sep 2, 2013 | 07:59 PM
  #202
Jbakes727's Avatar
Jbakes727
It must be reflecting then or something...
Old Sep 2, 2013 | 08:16 PM
  #203
mcubed45's Avatar
mcubed45
It's not the horizontal lines people are talking about. It's the actual silver painted area of the shroud that has a thin layer of paint allowing light to shine through. Look at some of the first pics in the thread.
It's really not that big a deal if you're planning on opening your headlight swap lenses or install halos anyways.
$300 for depo's that need some modification vs $1500 for OEM is kind've a no brainer IMO.
Old Sep 2, 2013 | 10:27 PM
  #204
Jbakes727's Avatar
Jbakes727
Now I see what your talking about. Didn't notice that before.
Old Sep 3, 2013 | 11:05 AM
  #205
worm1998's Avatar
worm1998
hi so i wrote a few weeks ago to say i bought these and would be opening them up. i just got around to doing so and can say that my set was in excellent shape. i didnt have the excess glue everywhere like some reported and everything on the inside was flawless. now, the silver shroud with the horizontal lines on it......the paint isnt layered heavy like factory so that is the reason the light shines through. i put STi-R lenses on and am painting these to match the body so mine wont do that. i hope that helps anyone else wondering about that part
Old Sep 3, 2013 | 02:16 PM
  #206
G4nismo's Avatar
G4nismo
Bought too small of a set of halos, ordered larger ones, now they're on backorder. Fml
Old Sep 3, 2013 | 04:50 PM
  #207
worm1998's Avatar
worm1998
i think i read somewhere the 80mm were a perfect fit if mounted on the outside of the shroud
Old Sep 3, 2013 | 10:59 PM
  #208
Jbakes727's Avatar
Jbakes727
Depo head lights straight out of the box. No mods to them.
Using Phillips 85122 4300k bulbs from retrofitsource.
Old Sep 3, 2013 | 11:52 PM
  #209
zoom-Z's Avatar
zoom-Z
nice, i personally like the amber drl, i might try to see if switchback bulbs work in there too.
Old Sep 4, 2013 | 01:43 AM
  #210
NoQuestionZ's Avatar
NoQuestionZ
727FL350z, Do you plan on modding these? IE changing the color inside from gray to white? I have these on my ppw since I'm DONE fudging with my modded ones. But I miss the white in the housing.... Can't have my cake and eat it too....or something like that
Old Sep 4, 2013 | 06:59 AM
  #211
Jbakes727's Avatar
Jbakes727
I wasn't a fan of that but switch backs are cool. I bought 3156 turn signal bulbs so they wouldn't be on all the time. The 3156 wouldn't fit at first, had to pry off the edge a little and it went right in.
Nah I'm just going to keep them how they are. They look and perform awesome stock, I don't want to go through the trouble tearing them apart.
Old Sep 4, 2013 | 07:27 PM
  #212
Teha99's Avatar
Teha99
I honestly thing with the STI lenses on these they perform better than stock. The projectors on the DEPO ones seem more of a wide angle. I only have one ballast working but didn't know it until some one pointed it out. One light covers like a nice half circle around the front of the car. Plus the cutoff is as good too and I had OEM before these.
Old Sep 4, 2013 | 08:49 PM
  #213
NoQuestionZ
cool. I was just wondering. I want some OEM ones to match better with my JDM tails, or I want some OEM tails to match better with these. can't settle can I?
Old Sep 4, 2013 | 09:12 PM
  #214
G4nismo's Avatar
G4nismo
i'm more interested in the comparison between the 06-08 OEMs vs the Depos (with and w/o sti lenses) than the 03-05 oem hids. i'm actually going to do a side by side comparison as i have both when i have time.
Old Sep 4, 2013 | 10:05 PM
  #215
mrfobbyaccent's Avatar
mrfobbyaccent
Help from anyone please, I am trying to remove the wire harness from my 06 headlight I.E. the grey harness that is connected to the light which is for the bulb, I don't know if I should just rip it off or is there a clip holding it somewhere, any help would be greatly appreciated! thanks everyone
Old Sep 4, 2013 | 10:48 PM
  #216
Jbakes727's Avatar
Jbakes727
I think your talking about the ground, definitely don't rip it. There is a screw holding it in
Old Sep 4, 2013 | 11:26 PM
  #217
RedlineRedZ33's Avatar
RedlineRedZ33
I ended up purchasing a set, but seems as if I have a problem with the cutoff. The left side is perfect and sharp, but the right seems to be curved up, doesn't look anything like the picture 727FL350z posted up earlier. Is it a problem with the bulb not being in the right spot?
Old Sep 5, 2013 | 06:34 AM
  #218
Jbakes727's Avatar
Jbakes727
Post a pic. Are you using d2s bulbs? If so what kind?
Old Sep 5, 2013 | 09:15 AM
  #219
mrfobbyaccent
Thank you for replying! I am not sure if this is the ground or not but here is a picture of what I need to remove, it is circled in grey below. Any help again would be greatly appreciated! Thanks everyone!
Depo 06+ style headlights and other aftermarket headlights thread-lyig1iq.jpg
Old Sep 5, 2013 | 12:09 PM
  #220
atenzany62's Avatar
atenzany62
these seem to have only the screws and taps holding the glass and housing together... if i want to put sti lenses, do i have to bake these open? or just remove the screws and un-tab the glass cover and housing, then i'll have access to the lense.
