the "bmccann101s car gets a new look/ watch me suffer bodywork hell" thread
Old May 4, 2015 | 10:28 AM
  #1041
bmccann101's Avatar
bmccann101
yeah thats clean as hell..
While im not trying to have my interior look like MUzzys... im also never behind the wheel of this thing much even when it is running.. so its kind of a carnival ride.
Its over the top.. parts people usually dont see.. and that keeps it sponsored
Im preparing a proposal package for AEM now tbh.. might ditch all of these gauges and just replace them w digis from them.. afterall, at one point id love to run thier water meth kit too.
Old May 4, 2015 | 12:59 PM
  #1042
Resmarted's Avatar
Resmarted
If you go water meth, I'd reccomend doing a custom kit and going with devils own. You can run a dual or triple pump setup, and run a high pressure dual stage system. You definitely should go direct port either way. I have an aem failsafe (not in my pic), and that's worth getting. You could even run the aem electronics and the devils own pumps....
I know you like top of the line ish, so devils own would be worth it. Devils own you can setup to run stainless lines. Do a dual pump to feed your lower runners and run a 50/50 mix there, then have a third pump feeding a large nozzle (to keep pressure high and allow full atomization) running pure meth to a nozzel right after the turbo on the charge piping.
Then you have the aem failsafe on the pump(s) feeding the direct port runners, and tune the car with that only (leaving the third turbo pump off). Then you just turn the last meth only pump on, and let it just lower you intake charge. It will richen up your mix by a like .2 or .3 but really no big deal because of the stoich mixes of methanol.
Your ecu will add timing for the secondary kit automatically (lower intake temp), and if that ever stops working will have automatic failsafe built in yo your car (I'm assuming you're tuned on Volumetric Efficiency or speed density). And then the aem failsafe will take control of managing the very important direct port system. You can run the output signal to your ecu or your boost controller so if that ever stops working your car can pull timing or drop to wastegate pressure in a snap. Setting up the data logging on the aem failsafe is so easy and so effective.
Anyway, that's what I'm doing on my car at least. And I won't even start with my nitrous setup I'm brewing. If I'm going vortech I'll still see to it I make panty dropping pump gas numbers lmao
But yeah I get what you're doing with the car now lol. No offense, but it's almost a pity the way you have it because the rest of your interior is so damn minty.
I'd love to see you De clutter the gauges, get an led mod to red for the gauge cluster, swap out the OEM triple, get a gtr steering wheel, and rewire the steering wheel **** to like over boost on a boost controller or something like that.
Old May 4, 2015 | 03:33 PM
  #1043
bmccann101's Avatar
bmccann101
lol.
step 1:
i just want a car that runs and a clutch that doesnt slip.
Old May 4, 2015 | 05:52 PM
  #1044
Resmarted's Avatar
Resmarted
lol.
step 1:
I HAVE NO IDEA WHAT A RUNNING 350z is like anymore.
But I'm in the same boat man. Same boat. It's sinking.
Old May 6, 2015 | 03:49 PM
  #1045
shyun1250's Avatar
shyun1250
When I was on this forum last I don't remember your car looking anything like that... :O
I'm going to take a wild guess and say amuse superleggera wide body sides with added flares for shiggles? nuts.
Old May 9, 2015 | 11:46 AM
  #1046
bmccann101's Avatar
bmccann101
still waiting to hear backl from precision turbo.. so ive been ironing out details as it just sits here.
wheel fit.. needs to be tackled..
front aired out.. has tons of room.. will likely adjust out a degree of camber and also add a 10mm ichiba spacer i have here.
now the rear is a different story.. this tire sticks way out almost until it hits the flare.. then the shorter RUCA pulls in and slips it right under the flare.. sooo close lol.
as we started adding camber, it really adds toe out, so i ordered some Kinetix adjustable traction arms to help.. this fit is killer, but its also aired out, meaning that at ride height, it has no visible camber.. and actually looks so straight up and down that its funny looking..
i plan to add back in a degree or so .. just a touch more..
should look frikn awesome when were done.
i love this fit!
Old May 9, 2015 | 11:52 AM
  #1047
che69velle's Avatar
che69velle
Damm, man looking good. My block and parts are in and car will be underway soon. Then I gotta get the body to these standards....
Old May 9, 2015 | 03:28 PM
  #1048
mr. sparco's Avatar
mr. sparco
Tight.
Old May 10, 2015 | 05:08 PM
  #1049
DmanG281's Avatar
DmanG281
Please tell me your bike has a front brake and a freewheel......lol
Old May 10, 2015 | 05:14 PM
  #1050
bmccann101's Avatar
bmccann101
^ in fact it does yes...
I don't understand how anyone rides fixed gear and with no brakes...doesn't seem badass....it's seems like a death wish lol
Old May 10, 2015 | 07:43 PM
  #1051
Resmarted's Avatar
Resmarted
Hipsters are all into that whole "this is totally dumb and un-functional, therefore it's cool and relevant to my life" bs.
BIKE HAS NO BRAKES? MUST BE COOL BEFORE COOL!
Old May 11, 2015 | 05:20 AM
  #1052
DmanG281's Avatar
DmanG281
Oh thank goodness! For a second I was worried.......
My Favorite is the fixee built out of a thousand dollar carbon road frame....Why, just why?
Old May 11, 2015 | 09:31 AM
  #1053
RyankPeck's Avatar
RyankPeck
Not sure if these will work in correlation with your bags.. but these will help you with your toe issue. They'll grab the back side of the hub while the camber arms only grab the front.
http://www.splparts.com/spl-titanium...inks-350z-g35/
Old May 11, 2015 | 09:55 AM
  #1054
Nismo350z#0310's Avatar
Nismo350z#0310
next up on the B Money build, self adjusting camber arms that adjust as ride height adjust.
That rear shot - stance looks fire, fam. Makes me wanna camber mine out a bit more
Old May 11, 2015 | 11:07 AM
  #1055
Highway Riding's Avatar
Highway Riding
Makes me wanna go out and shred the eff out of that gorgeous rubber! Or at least try lmao
Old May 11, 2015 | 11:15 AM
  #1056
bmccann101's Avatar
bmccann101
those are spendy and dont work well with airbags unfortunately.
The collpased bag height inst enough with those.. even w that mount dropped, the bag sets too high up .. wont let you air out.
I bought the kinetix arms.. a touch of adjustment there along w a touch more negative camber will be just fine im sure. Plus it only really impacts the fit when its aired out.. when its riding up you wont notice the slight fwd position .
Old May 11, 2015 | 11:43 AM
  #1057
bmccann101's Avatar
bmccann101
looks good in the shade here but the red is just too broght.. needs to be a darker tone.
test fit gurney flap:
Old May 11, 2015 | 12:32 PM
  #1058
DmanG281's Avatar
DmanG281
Main color choice for the wrap appears to have been perfect......
Old May 11, 2015 | 03:34 PM
  #1059
Resmarted's Avatar
Resmarted
And you have two more gauges on top of the main cluster :O
Overwhelming space ship mode on fleek. Otherwise I dig the rest of it lol. That wrap is on point. I have been thinking about diying some micro suede **** in but I have 100 other projects on this car to finish first.
But I'm horribly picky about gauges... I don't even like A pillar setups. Don't listen to my critique on gauges.
Go pro recording button is a nice touch.
Do you have the apexi ecv? I'm considering getting one....
Old May 11, 2015 | 04:01 PM
  #1060
bmccann101's Avatar
bmccann101
i do have the ecv ^ I just havent mounted the handle and drilled the hole for the cable yet lol.. i figure ill add it to the planted seat base so that way i just do the ol " cop drives by so i close the muffler up by doing what looks like a "grab the gun under my seat" move"... seems like the smart call lol.
Im really just being lazy becuase pulling my seats out w the car still in the garage is going to be a nightmare... and the door panel already hits the driovers shoulder bolster.. needs to adjust towards the center console..
waiting to do it all at once when Takata finally has my belts in stock in the US lol.
Cant wait to install em tbh. Sht will look clean n scary.
Its funny you mention that ECV .. most other people dont know what it actually is
some troll kid on Chris Alphas page commented " the award for the longest description of an exhaust cut out goes to Brian McCann"...
smmfh.. its a butterfly yes.. but it is NOT a cut out lol.. like at ALL. lol
