HKS Super Charger Installed "WOW"
Old Jul 26, 2005 | 06:31 AM
  #161
PumpedVA's Avatar
PumpedVA
Originally Posted by illZ
Is that what happened to yours Pumped?
Did aam flash your ECU for the HKS or did you go with the FCON?
unit locked up and yes I have the fcon v pro
Old Jul 26, 2005 | 06:37 AM
  #162
Gman2004's Avatar
Gman2004
Originally Posted by forcedinductee
dynoed the car friday and it made 272.39 whp and 282.63 torque
93.12 degrees f 41% humidity
a/f stays rait between 11.7 and 12.0:1
That's rediculous! You could have gotten those numbers with bolt ons. I hope things work out for you. That is a lot of money for those numbers.
Old Jul 26, 2005 | 07:16 AM
  #163
RBlover69's Avatar
RBlover69
yea thats dissapointing. I dunno man, im torn between this but the numbers are very low and can be achieved Na from those results. But dollar for dollar, its alot of money for that.
Old Jul 26, 2005 | 07:57 AM
  #164
forcedinductee's Avatar
forcedinductee
Wow.. Interesting. I'm not really a number guy, but what kind of dyno was this on?
Overall, what are your feelings on this SC?
Thank you!
DYNOJET
Old Jul 26, 2005 | 07:58 AM
  #165
forcedinductee
Originally Posted by Z BOY
are those sae numbers?
yes SAE numbers
Old Jul 26, 2005 | 08:03 AM
  #166
Gman2004's Avatar
Gman2004
DYNOJET
Wow! That is even worse. If it was a mustang dyno then you could at like 13% to those numbers. Mustang dyno usually give lower numbers than Dynojets. Good luck with the trouble shooting.
Old Jul 26, 2005 | 08:11 AM
  #167
forcedinductee
well the car is still a little lean that was only making 5psi and the exhaust if you read is still all stock(lots of back pressure) on an 5AT. the belts have stretched now and i retightened them and it is making 7psi now. i am going to wait to get the HKS exhaust and i am going to retune the f-con sz and dyno the car again with just the cat back. and then add race cats, headers, cams etc. i am doing this to give you guys numbers on the different stages.
Old Jul 26, 2005 | 08:40 AM
  #168
illZ's Avatar
illZ
a little lean?? I thought a/f ratio was between 11.7 and 12 the entire time?
I'm not bashing your numbers, becuase they really don't matter much IMHO. . But I was expecting to see at least 320whp+.
What was your baseline dyno?
Old Jul 26, 2005 | 09:10 AM
  #169
Reaper700's Avatar
Reaper700
Porting your Rotrex is messing with success, you may have upset the tuning.
Old Jul 26, 2005 | 10:11 AM
  #170
forcedinductee
i think it messed with my tuning as well. but thats what HKS did with theres and thay reached 400whp. i am going to work with the tuning when the exhaust arrives.
Old Jul 26, 2005 | 10:13 AM
  #171
Reaper700's Avatar
Reaper700
Keep us posted !
Old Jul 31, 2005 | 12:41 PM
  #172
MethodRN's Avatar
MethodRN
For Sale
I have an 05 Z, anyone know if the HKS kit will work w/ my ecu?
Old Aug 6, 2005 | 11:10 AM
  #173
illZ's Avatar
illZ
bump
Old Aug 6, 2005 | 11:44 AM
  #174
imoz's Avatar
imoz
It sounds like all you did was port the housing. The reason HKS is making that kind of power is because they also did a host of other mods.
Import Tuner article on the HKS car
Originally Posted by Import Tuner
Try 400 hp and 353 ft-lb of torque on VP Racing 100-octane gasoline. Although promising an 80-hp power increase at the wheels, the off-the-shelf Rotrex kit wasn’t good enough for HKS’ 350Z. Specially prepared for HKS USA, the compressor housing was ported and a prototype 9.5-psi pulley was fitted to the supercharger to replace the standard 7-psi unit. The standard upgraded fuel pump was used, although the two auxiliary 525cc injectors were dumped in favor of upgrading all six injectors to 650cc units. Controlling those injectors is an HKS F-CON V Pro D Jetro standalone engine management system, tuned by HKS USA. The standard intercooler included in the kit was also dumped, replaced with a larger prototype S-Type front mount. The included bypass valve was replaced with an SSQV blow-off valve, made by HKS—obviously.
Inhaled through a Super Mega Flow intake, air is compressed, ignited and expunged through prototype HKS SPL headers and into an HKS Dual Hi-Power Ti exhaust system. An HKS dry-carbon engine cover and limited-edition oil cap add a little perk to the under-hood looks. The internals on the VQ35 engine are dead stock, tuned to handle the 9.5 psi of boost using only the F-CON V Pro and 100-octane gas. Anything’s better than California’s 91-octane pea soup. Fit with HKS S35iL Superfire Racing spark plugs and a HKS limited-edition 1.3bar radiator cap, this 350Z has proven to be both capable and powerful.
Old Aug 8, 2005 | 02:00 PM
  #175
forcedinductee
oh i know i just started with the housing cause the pulley is not for sale yet
Old Aug 9, 2005 | 12:46 PM
  #176
illZ's Avatar
illZ
does anyone have any videos??
I cannot find a link that works.
Old Aug 9, 2005 | 06:21 PM
  #177
Z BOY's Avatar
Z BOY
ninja-z has one of his.
Old Aug 10, 2005 | 03:46 AM
  #178
MR RIZK's Avatar
MR RIZK
Nice article. It's a bit sad that to achive those numbers they changed so much in the original kit. The fuel system I understand but needing a different ECU, FMIC and BOV is a bit much to swallow and will can all see the $$$ start counting.
Old Aug 10, 2005 | 06:10 AM
  #179
forcedinductee
i put the car on the dyno last night after installing the Invidia dual catback exhaust. temp was 88.52 the humidity was 47% it made 319.92whp and 312.53wtq. i thought that was pretty good.
so to recap for mods:2004 350z 5AT- HKS Rotrex ported housing w/ f-con sz 7psi-Invidia dual catback. this car feels fast and it is only running 7 psi with stock cats, and a big injector set up in the middle of the plenum. i like the room for improvement that this car has. oh and driveability is unbelievable!
i am going to get rid of the additional injectors, add new larger injectors and change the plenum and i will then dyno the car again and let you all know how that goes.
Old Aug 10, 2005 | 06:11 AM
  #180
Gman2004's Avatar
Gman2004
how much $$$ have you invested so far?
