Stillen Stage 4 no power gain
Old Apr 19, 2006 | 12:30 PM
  #81
SinCity350Z's Avatar
SinCity350Z
Track Whore
Blah blah blah blah blah. First off, this thread was about a member's problems with his Stillen. Second, who cares what FI kit can do what. Get a kit that fits your driving style and goals. Stillen makes an awesome kit, it may not put out the best power, but its cheaper than most kits, easiest to install, sounds freakin amazing, and is fun. How much power do you guys really use on the streets anyway? I have 550whp on my track built 350Z, but guess what I am going for on my G35....Stillen Stage 3. Its still fun and good for a daily driver. Who cares if the TN kit puts out more, obviously the biggest numbers isn't why anybody buys the Stillen kit.
Old Apr 19, 2006 | 12:38 PM
  #82
nateg35's Avatar
nateg35
+111111111111111111 I also did hjack my own thread
Old Apr 19, 2006 | 12:46 PM
  #83
SinCity350Z
Track Whore
Oh, and I just realized that you were 5AT, which makes the Stillen even more attractive since you probably wont need a VB upgrade.
Old Apr 19, 2006 | 12:52 PM
  #84
Dr.G's Avatar
Dr.G
Originally Posted by rookie
The Stillen system should be at full boost way before redline. The Stillen system is a blower, the air is never compressed liked a centrifugal SC or turbo hence the max power difference.
the stillen starts giving boost way before red line , in fact it starts around 2000 rpm, however maximum boost comes at redline. and Stillen themselves confirm that.the Turbo will not give boost that early but will give boost suddenly.
Old Apr 19, 2006 | 12:59 PM
  #85
Dr.G's Avatar
Dr.G
Originally Posted by nateg35
Hey Dr.G...what are the 3 belts
1. the supercharger belt (on top of the blower)?
2. the belt on the sc pulley (main belt)
3. ? and where (pic would be appreciated)
this would sounds stupid but I found turning counter-clock wise (un-tighten) the main belt and this would actually tighten this belt
the blower belt (4 ribs ) smallest one
the 6 rib belt around the silver pulley.
and the long belt (look down below) it goes around the crank pulley and double pulley, this belt could be wrongly routed , it can easily be mounted and fitted in two different ways but only one way is right. it is very easy to make the mistake, and also it could be a bit loose.
Old Apr 19, 2006 | 01:07 PM
  #86
nateg35's Avatar
nateg35
Thanks Dr.G...I'll start to check on these belts
Old Apr 19, 2006 | 01:30 PM
  #87
Dr.G's Avatar
Dr.G
To Mr. Alberto , i do not need to prove anything to you , i said it before it does not matter to me if you or others believe me or not. All the proof you are asking for is in a local forum overhere since all that i said was witnessed by friends with me in the car. so i you are really interested in knowing that i am not BSing i'll give you the website address and you can see for yourself and ask anybody in that forum.
Now for the one who claims 300 whp with only NA bolts on: my friend you are contradicting the conservation of energy law. you cannot get something from nothing. to get more power you need to burn more fuel and with NA you can only increase the fuel injected a tiny bit since your air intake cannot be increased much naturally. And if you get 50hp more it would be a spike in hp over a very narrow rpm range in your power curve, and probably loosing in some other rpm range. With SC you increase the fuel by more than 50% and the air intake too so you get a lot more power over all the rpm range. NA cannot be compared with FI , not even close.
Old Apr 19, 2006 | 01:47 PM
  #88
SinCity350Z
Track Whore
^^^Look up Rickdogg. 298whp N/A without even touching the internals yet.
Old Apr 19, 2006 | 02:01 PM
  #89
PalFX's Avatar
PalFX
I had the Stillen stage 4 installed on my FX about 3 weeks ago and my experience so far has been positive. Went from stage 2 > 3 > 4 in less than 5 months. With stage 4 and in auto mode, the first two gears rev up so fast to 7.5K rpm according to the stock tach (stock ecu and no flash). As a matter of fact, I have to back off the gas a little at the top to persuade it to shift. No shift limiter kicks in either as I assume this is due to the engine rev'ing too fast for it to catch on. 3rd gear in auto, it shifts by itself but at around 7.2K rpm. Not good and nothing to brag about but I do feel the power increase over the stage 3 which was dyno'ed on my FX35 RWD (auto of course) to produce ~24rwhp over the stage 2 which was a nice increase over stock N/A moded. Needless to say, when I want to go WOT, I make sure I'm in manual mode so not to blow my engine. I received the new bulkier 7th injector and the new FMU tune that the initial stage 4 didn't get. No dyno's yet but will at some point in the near future. Lastly, stage 4 loves hi-octane gas.
Old Apr 19, 2006 | 02:11 PM
  #90
Paul350Z's Avatar
Paul350Z
Living in 350Z
Originally Posted by MIAPLAYA
I know a couple turbo cars in you area that would be happy to prove that to you..
Are you willing to prove it in front of a California police officer?
Last time I checked ('bout six months ago) there were still no legal turbo kits for the Z ... and not willing to lose ride or serveral thousand dollars for some extra horses I'm still waiting on a CARB approved turbo kit.
If you're towing your car to the track then it's different.
Old Apr 19, 2006 | 02:19 PM
  #91
superchargedg's Avatar
superchargedg
Damn Noobs
fuking thank you i did not buy the kit for the most power but it seems like there are so many *** holes out there that only the most power will due.come on you *** heads its not only about the rwhp you get but the surge of power you get.im sorry for even posting cause all you *** heads care about is what the dyno says.who gives a *** my old 72 mustang would blow all you turbo z,s away,jack asses.im sick of hearing this **** by the kit you want and *** the rest who give negative comments on this or that.
Old Apr 19, 2006 | 02:56 PM
  #92
nateg35's Avatar
nateg35
I got mine installed by Miller Infiniti (Gene Lee)...yours were there too right?. Should get your dynoed to see what's the whp...what's octane gas r u using?
Old Apr 19, 2006 | 03:07 PM
  #93
rookie's Avatar
rookie
Not to continue this much further since you have a PhD.
The Stillen system does not compress the air, there is a limit to how much air it can blow. The smaller pullies just get you to that limit faster, the M62 is undersized for trying to reach crazy power levels. The power you're feeling at the higher stages is from the added fuel and timing. If you need more of an explanation than that about reaching max boost with what's under your hood than I give up.
BTW I have a Stillen system, I'm not bashing it's merits cause of what I have read on the internet.
  #94
PalFX's Avatar
PalFX
Will dyno soon just to know.
Old Apr 19, 2006 | 03:44 PM
  #95
nateg35's Avatar
nateg35
yeah...I could feel the power when I got my car back but after 1 week it felt the same therefore I brought it back to San Jose for the dyno...result is very very very SAD
Old Apr 19, 2006 | 04:42 PM
  #96
dream724Z's Avatar
dream724Z
Stillen recommends against piggy back ECUs (their controller retards high rev timing to avoid detonation). The delayed performance loss may be due to the stock controller misreading a faulty sensor and adapting. Has anyone TurboXS retuned Stillen's SC to increase their dynos?
Old Apr 19, 2006 | 04:56 PM
  #97
BoOsTedz33TT's Avatar
BoOsTedz33TT
isnt there a video on the board of a NA z wooping as from a dig on a stillen SC z?? very funny...stillin sorry guys but you have
failed!!!!!
Old Apr 19, 2006 | 05:01 PM
  #98
chimmike's Avatar
chimmike
Old Apr 19, 2006 | 05:29 PM
  #99
taurran's Avatar
taurran
Originally Posted by kevinbonds
It's a fact that turbos mounted inside the engine bay like that create massive heat that can affect the performance of the car.
Wow... Perhaps we should let the other 90% of turbocharged car owners in the world know about this fact. Oh snap, that's why the invented intercoolers and vented hoods.
Old Apr 19, 2006 | 07:24 PM
  #100
kevinbonds's Avatar
kevinbonds
"oh snap" this place is crazy. what ever bro I dont even give a **** anymore! You missed my point so go bark up someone elses tree. Listen congrats on your setup beat a dead horse I really dont care. You know more then me etc, etc.
