Stillen Stage 4 no power gain
Originally Posted by Alberto
blah blah blah. You posted some BS, Ive called you out and this is all you can come up with? Just admit you dont even have a time slip. You just lost all credibility on these boards
<---Dr.GBTW I do believe the Stillen (stage3 and up) is capable of running great times, but because there arent many kits out though we havent seen it. No doubt with 330+whp it could bea solid mid 12 sec car on street tires. Hopefully, we'll have a G here in MD going 12's soon....
Thanks for giving the Stillen a little credit. I agree There are not that many people running the kit so it remains to be seen. I have yet to go stage 4. When I did have the car dynoed stage 3 I was at 305hp and 303 torque. So i could imagine with stage 4 the numbers may be around 330 or so. Which with the right driver could post some pretty good times. So I will try to be the ginuea pig. I am going to upgrade to stage 4 when I take a little time away from my z32 and I will post up some dyno numbers and some 1/4 mile times. Now to answer the orignal question, one thing you might want to check is that your water pump for your heat exchanger is working. A few weeks ago I was driving my car and noticed that it wasnt making full power. It turned out that the inline fuse to the water pump had blown. I checked the wiring and noticed that the power wire had fryed a little from the bumper support. I would check that right away!
Originally Posted by Dr.G
Alberto i do spin my tires and my back end goes sideways on 3d gear easily, that is why iam spending 6000 $ for new rims and tires, not for the looks. go ahead and call Stillen and ask Dean about it no problems, and don't worry with time you will see that the only bull****ter here is you. and by the way i bet i can kill your *** with a stock Z on a twisty track. and if you have anything interesting to say say it because this post is to help nateg with his problem .
dude. you are full of crap. You don't spin your tires in 3rd gear and get sideways. I'd be willin to bet you have like 50 ft-lbs less tq than I do.
Originally Posted by nateg35
sorry to ask but where's the inline fuse to water pump...thanks again
THANKS...I'll check them so I should be able to twist them around 60, if not then it's wrongly mounted?
hehehehe i will send you a video and show you that in cold nights i even spin on 4th with new Michelin PS2 tires and this will shut you up forever
and post your "timeslip" your so full of $hit....spin 4th gear LMAO, maybe in the rain/gravel
Turn on the ignition but no need to start the car, open the canister and see if the water is circualting. If it is not then it can be the fuse or the pump. The fuse is on the power wire of the pump that leads to a relay that controls the power to the ecu and the pump. Also it's possible that your water pump failed. Stillen dropped the ball and used a cheap pump. My first pump died after about two months. Sometimes debris or what not can clog it then the motor can burn out. If the pump is not working and the fuse is good, make sure the ground to the pump is solid then just touch the power wire to the battery terminal if the pump works then its either the relay or the pump. I replaced my pump with a Bosch heavy duty water pump so that i wont have any more issues. I also removed the relay and wired the ecu to a switched 12volts. I hooked the water pump up to a switch under the dash with a light that so that if the pump isnt getting 12v the light turns off. Makes it a little safer incase you are tracking the car and your pump fails this way you have an indicator light to inform you.
Pretty funny to read all of this sometimes!
IMO, Stillen is a great OUT OF THE BOX solution. It is easy to install and makes a modest 50-70 WHP increase over stock. NOTHING MORE. We have tried everything and NO MATTER what pulley, fuel, timing, methanol, what ever, we still could never make more than 330 WHP on Dynojets and Dynopaks. Unless they increase the blower size itself, NO MORE POWER. Forget what they say on their website.
Now, Is that Lame? Hell No. That is pretty awesome and on most road racetracks with a good driver, even 0-60 runs, the Stillen for the most part can beat almost all competitors.
I know, I have owned 3 Stillen blowers. Customers literally trade them in for JWT kits WHEN and ONLY WHEN they want to make more power or when they have blown their modified Stillen's motor up.
Now the thing Stillen does have is CARB. WHY is this important to their business? Because with CARB all of the DEALERS (conservative and by the book) are willing to install them on your new and used cars.
So, Stillen has its place and if anyone of you want to see very very fast NA Zs with bolt-ons, just go to a road racetrack and you with see NA Z with close to 300 WHP.
We just removed all NA boltons from a car from Arizona to install a JWT kit that made close to 290 WHP. NOw this guy, Steve, was an awesome driver and with his car set-up, he runs better laptiems than most of my FI customers on most tracks.
So just remember there will and always will be FI debates, my car is faster than yours, and LET'S RACE, just try it out at the track on a real road race course and YOU WILL KNOW QUICKLY when that ****ty little stripped down Honda Civic with 200 WHP passes you that POWER ISN'T EVERYTHING when compared to a perfect power to weight ratio.
Now realizing that a power to weight ratio is important, that is why we have been working on a perfect 500 WHP/550 torque package for Zs and Gs. Yes my daily driver is 800 WHP, yet I still street it and track it at 500 WHP.
Goodluck.
Goodluck.
I had 349WHP on a dynapak which is roughly 325-335 on a dynojet with my Stillen Stage 3. This is with all my mods listed below besides the cams. Even with the 3.9 FD I could BARELY chirp third when pounding the **** out of it. Therefore. BS.
you re going to keep saying iam BSing until you feel really dum at the end , so don't dig yourself any deeper and start thinking what if Dr.G was right...
thanx rookie. was that for a g35 dyno or a Z?
343 whp with 92 octane, the torque curve is really nice. i use 98 octane and it is explosive from low rpm, even cars with much higher hp have a hard time keeping up from low rpm.
