Thought about headlift
Old Jul 25, 2006 | 11:02 PM
plumpzz's Avatar
plumpzz
Default Thought about headlift
Im posting this here cause mostly FI guys have this problem, with headlift. i was in my friends car, a 2005 Mini Cooper w/ the john works package, and he had a oil pressure gauge. He's always had turbo/supercharged cars, and when I told him his oil pressure i shella low, at 35 at WOT at 6500RPM, he said thats fully normal on all his turbo cars. He also has 2 Supras and an RX7..daddys a doctor.
I noticed on our cars, it runs at 120-150 at WOT and when cold, it can peak 160. I was thinking and if the oil pressure was so high, at 150psi or over 21600 lbs/square foot, would this cause oil to leak into the coolant and cause hot coolant to rush in as well? I've also noticed now, even the big v8 guys purposely run low oil and water pressure to relieve stress on teh block, but bore out the passages. Many guys switch to synthetic who run FI, which can lower or raise ur oil pressure. Can a increase in oil pressure w/ other conditions possibly cause headlift? Just a thought...
Old Jul 26, 2006 | 06:26 AM
mistaboosta's Avatar
mistaboosta
150 psi ???? are u sure about that ? I've never seen more than 90 (maybe 100) @ WOT
Old Jul 26, 2006 | 07:15 AM
roneski's Avatar
roneski
Damn, I need to get my oil pressure gauge working.
Old Jul 26, 2006 | 09:40 AM
phunk's Avatar
phunk
CJ Motorsports
there is no way his supra and rx7s are running that type of oil pressure, they both run way more then that. i have never seen what a mini runs, but i doubt its only at 35 psi by redline.
Old Jul 26, 2006 | 01:20 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
mine is only high when its cold and i get on it a bit...
Old Jul 26, 2006 | 01:42 PM
phunk's Avatar
phunk
CJ Motorsports
the oil pump is directly driven off the crankshaft, so oil pressure is pretty linear with RPM. However, there is a pressure relief valve to keep it from going too high... and it is also highly effected the the type AND temperature of oil in the engine. Some engines that I build, I will modify the pressure relief to get a little more pressure.
Some engine builders will go by a general rule of 10 psi per 1000 RPM but the conditions are a little more dynamic then that, and application really does matter.
Old Jul 26, 2006 | 06:09 PM
overZealous1's Avatar
overZealous1
+1
Old Jul 26, 2006 | 06:12 PM
plumpzz's Avatar
plumpzz
Yah i was watching his mini and it was 35-40 at redline, which is pretty low. The engine is a 1.5liter if it matters.
His supra tops around 60ish both of them. The rx7 i never rode in(scary..) but i know its around there too.
Old Jul 26, 2006 | 06:52 PM
Weqster's Avatar
Weqster
oil pressure all depends on ur bearing clearences and manufactures specificiations. Old V8s will run alot less pressure then our hi-tech cars. Newer nissian engines run around 120psi at redline. Honda's run 80-90psi at 4000rpm->redline.
When ur oil is cold, its thick and hence u will get more oil pressure. Pressure doesnt mean more flow though. Both are important. Low oil pressure will kill an engine much faster then high oil pressure though. 35psi is very very very dangerous to run on our engine, esp at +4000rpm.
PS. This has nothing to do with 'headlift'. THe heads dont actually lift, its the cylinder sleeves moving around which causes blown headgaskets. GO read up on open deck blocks.
PSS. the supra/mini engines are closed decks.
PSS. It seems as though this guy is taking the oil pressure off the wrong source. My guess is that he has the sender T'd into his oil feed line. This line will be pressure/flow capped at around 30psi to stop over oiling of the turbo.
Old Jul 26, 2006 | 08:40 PM
JoneZZZ's Avatar
JoneZZZ
Subscribing....
Old Jul 28, 2006 | 12:24 AM
plumpzz's Avatar
plumpzz
Ihave no idea on the setup for the oil lines on my friends car. However, the oil guage on the mini max at 70. It usually stays around 40 at most.
Justin100
Nov 25, 2021 06:26 AM
apex locator
Jul 23, 2021 02:27 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
