brake boosting a TT 350z.
Old Aug 1, 2007 | 11:17 AM
  #281
Alberto's Avatar
Alberto
Cranky FI Owner
No worries, I thank you and Quadcam for chiming in with ideas-tapping 3 or 4 wires is part of testing right? From now on, it should be VERY clear what people need to do. I'll report back after 4:30 with my impressions/more pics, video to come later. My tires are kinda bald and I lose a$$ anywhere in 2nd (low boost), Im scared if I brake boost from 3rd I'll be spinning sideways quick, we will see
Old Aug 1, 2007 | 11:33 AM
  #282
KPierson's Avatar
KPierson
Yes, it is part of testing, and that is why we stress that all wires should be verified with a meter before making connections. We've had countless modules destroyed by Honda Accord owners because they tap the wrong wire with one of our modules - to the point that we actually redesigned our hardware to allow it to survive the direct short to 12VDC the people are subjecting it to!
Thank you for taking the time to figure this out, I'm sure it will help many people in the future. It is also nice to see that you tapped it without removing the UTEC, I never actually explored where the ECU wireing came in from.
Old Aug 1, 2007 | 11:41 AM
  #283
JRoC's Avatar
JRoC
2nd that, thnx alberto. With me having the utec and hate dealing with wires you made it a good bit easier
Old Aug 1, 2007 | 11:43 AM
  #284
Alberto's Avatar
Alberto
Cranky FI Owner
No problem guys...it is super easy and right in plain sight above the UTEC within easy access as you can see. I followed the wires from the stock ECU harness back up and thats where they led after going through a white plastic connector/relay in the pass kick panel. I'll report back later...
Old Aug 1, 2007 | 11:44 AM
  #285
KPierson's Avatar
KPierson
That is why it wasn't the right color then - the color changes at that white plastic connector in the pass kick panel.
Good luck and keep it straight!
Old Aug 1, 2007 | 01:26 PM
  #286
Alberto's Avatar
Alberto
Cranky FI Owner
Thumbs up Brake BOOOSTAAAAA!
Ok, it works as advertised! Its weird brake boosting in this car, Ive tried before obviously with no success. It doesnt take as much brake pressure as I thought to build full boost from a roll. Below are pics of the brake wire cut/tapped with the brake module (stock cut wire circled in red), then how I secured the unit with the zip ties to the metal support behind the dash. In case of any issues the unit is still in reach (once I take out the 3 10MM bolts) yet out of the way and so is the fuse Any Q's feel free to ask, I did a few 2nd/3rd gear tests, its rush hour so I cant get any videos yet....thanks again Kevin!
Old Aug 1, 2007 | 03:43 PM
  #287
Havok_RLS2's Avatar
Havok_RLS2
I want one!
PM me with payment instruction.
Old Aug 1, 2007 | 03:59 PM
  #288
KPierson's Avatar
KPierson
Ha, your driver kick panel is pretty busy. Mine is installed down in the kick where I can access it easily.
Sounds like you had some fun!
We are still waiting on confirmation from someone with an Auto tranny before we start selling these. I just got off the phone with SFLG35 and I think he is going to go install his right now.
Old Aug 1, 2007 | 04:40 PM
  #289
abyss's Avatar
abyss
sheeeeut brake boosting Z's. I'm f*cked now.
Old Aug 1, 2007 | 04:49 PM
  #290
rcdash's Avatar
rcdash
Thanks for posting pics Alberto! I think that pink wire will be much easier to tap for those of us that don't want to pull the UTEC down...
Old Aug 1, 2007 | 05:03 PM
  #291
sflg35's Avatar
sflg35
KP Technologies
aight its in and i have more pictures. ill post those later and report back tomorrow. its raining out right now so perfect time to test and not eat up the tires. ill try to get a video tomorrow or something of a standing burn out, but right now the camera battery is dead
Old Aug 1, 2007 | 05:36 PM
  #292
sflg35's Avatar
sflg35
KP Technologies
alright test runs went great. spun all the way to redline sittin still with the brake on. ill take a video tomorrow cause im sure it will be raining again. and get teh pictures and video up
Old Aug 1, 2007 | 06:53 PM
  #293
Alberto's Avatar
Alberto
Cranky FI Owner
Thumbs up
After a few more pulls tonight, you def need to hold the brake down hard while moving lol. Earlier I was building boost but accelerating like10mph per second. 3rd gear at 70mph with 13psi = Cant wait to brake boost at 15psi and 570ft/lbs
Old Aug 1, 2007 | 07:03 PM
  #294
athenG's Avatar
athenG
Was this in 1st gear? This is what I want/need
Old Aug 1, 2007 | 07:19 PM
  #295
Alberto's Avatar
Alberto
Cranky FI Owner
4th gear lol...maybe not that fast but I was climbing in speed for sure.
Old Aug 1, 2007 | 07:55 PM
  #296
taurran's Avatar
taurran
My car will be done soon. Can I get one before then?
Old Aug 1, 2007 | 09:10 PM
  #297
sflg35's Avatar
sflg35
KP Technologies
ok so are jason and i the only ones having cruise control problems??
i was just cruisin down the street with the cruise on and then all of a sudden it goes off. so i try to reset it by pressing the set button set lights up but then goes right off. and cruise control doesnt work. i know i have mine installed correctly so thats not the issue
Old Aug 1, 2007 | 09:32 PM
  #298
sflg35's Avatar
sflg35
KP Technologies
alright here are my pictures
1. cut the pink/blue wire in half. connect the orange wire to the pink/blue wire that goes into the ecu
2. connect the purple wire to the pink/blue wire that goes up the harness towards the brake peddle
3. connect the yellow wire to the white/blue wire. make sure you have the correct white/blue wire there is 2 of them in the harness.
4. connect the black wire to the thick black wire in the harness. there were two of them as well in my harness. it is best to use the one in pin 1.
Old Aug 1, 2007 | 10:30 PM
  #299
AboostedG's Avatar
AboostedG
Twin Spoolin
Yeah, like Dan said, MY Cruise is no longer functioning and i'm not very happy about that as I use it EVERY DAY. I sure hope I don't have warranty issues if I go to the Dealership to get a scan. Please enlighten us about this so-called problem, thanks!!
I press the on/off button for the Cruise, the Cruise Green Light comes on, and the Set Green Button just flashes and won't set or anything at all. It won't set, cancel, or anything really, just keeps on flashing SET until I turn the Cruise off, cause there is nothing else to do.
Old Aug 1, 2007 | 10:42 PM
  #300
Weqster's Avatar
Weqster
"i sure hope i dont have warrenty issues"
You volunteered to be a beta tester for a product. And you are COMPLAINING about it not working? Or irregular behaviour? *sigh*
