Innovate Wideband Trouble
Old Apr 5, 2007 | 04:13 PM
VIZAGE's Avatar
VIZAGE
Default Innovate Wideband Trouble
Monday night took my car to a show and my wideband was ok. Today I go to crank my car up to pull it around for a wash and the wideband was showing this - - -. Nothing at all. There website said that when this present to check cables. The system is only couple weeks old with only 700 miles on it. What could be wrong.
I did the free air calibration and nothing. Sharif told me some things to do but that didn't work. But I'm still waiting reply from him, for he's a busy guy.
Old Apr 5, 2007 | 04:15 PM
MIAPLAYA's Avatar
MIAPLAYA
Did you actually check all the cables? Maybe something was touching an exhaust pipe and got melted through?
Old Apr 5, 2007 | 04:18 PM
VIZAGE's Avatar
VIZAGE
Yes, I did. There all out of the way. New as the day I bought it. They were mounted pretty well.
Old Apr 5, 2007 | 04:19 PM
MIAPLAYA's Avatar
MIAPLAYA
Hmm, maybe the terminator came off? I don't know. Call Innovate directly would be next suggestion...
Old Apr 5, 2007 | 06:57 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Thanks for calling today...so I guess the suggestions didnt work. Bring it by the shop anytime...we'll fix it...or replace it. There is no reason it should stop working after 3 weeks??
Old Apr 5, 2007 | 07:24 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Mine stopped working (sensor failed) after 1000 miles and 1 tuning session, I didnt get a replacement Sharif!
Old Apr 5, 2007 | 07:34 PM
Sharif@Forged
Forged Performance
I need to play around with it first...most of the time...I can get them to work without replacing anything. But seriously, his car was here maybe 2-3 weeks ago tops. After 1 month, you guys are on your own...haha!
Old Apr 5, 2007 | 07:52 PM
BootieMAN's Avatar
BootieMAN
Sorry about hijacking to the OP. But I'm having problems with my Innovate Wideband as well.
Sharif,
We briefly discussed this several weeks ago. When I go wot my a/f is around 10.5-10.9, but as I hit the top of my rpm band it jumps all the way up to 20-30+!! This also happens when I shift gears quickly at wot. No power shifting, just running the car hard.
I tried recalibrating, but no luck. Any suggestions?
Thanks.
Old Apr 6, 2007 | 01:58 AM
VIZAGE's Avatar
VIZAGE
No problem Sharif. I'll try to get by there sometime next week. Or I'll call and let you know something.
Old Apr 6, 2007 | 05:35 AM
THE TECH's Avatar
THE TECH
Innovate has a forum on their site that you may want to check.
Old Apr 6, 2007 | 06:57 AM
rcdash's Avatar
rcdash
Does innovate not offer a warranty on their products? I couldn't find any mention of warranty on their website...
I am trying to decide between a DEFI setup vs. Innovate gauge setup.
Old Apr 6, 2007 | 08:47 AM
Sharif@Forged
Forged Performance
Is anyone else having issues with their Innovates...in general? Recently, I have seem more and more customers have problems with them.
I'd like to find a somewhat afforadable NTK based sensor, like the FJO units...and test them out. NTK sensors are far more reliable, but they tend to be much more expensive...both the sensor...and the control module.
I'll see if I can dig anything up.
Old Apr 6, 2007 | 08:59 AM
350zSteve's Avatar
350zSteve
Mine went out a few weeks ago as well, just have the --- on the gauge. Is it normal for the sensors to go bad?
Old Apr 6, 2007 | 01:34 PM
VIZAGE's Avatar
VIZAGE
Well, again today I went over all the wires under the car that plug into the LC-1 module. Everything looks good. Even tried to reset it again with no luck.
Innovate claims that when showing --- that the LC-1 is not communicating with the gauge. Meaning that something is unplugged. But I beg to differ on that. There something else, I hope. Sharif will take care of it.
Old Apr 6, 2007 | 04:39 PM
VIZAGE's Avatar
VIZAGE
Default New Update
OK, I don't know what's going on now. I went to a friends house and on the way there I decided to do the free air calibration several times and nothing. When I left my buddies house and cranked up the car, it was all of a sudden working again. So I don't know what to think.
So Sharif I'm not going to worry about it now, until next time. From what it feels like, I'm going to need a clutch soon. So hopefully I will order one from you when I come up on the twenty first and when I set up a date for you to install it you could maybe look over the wideband. Thanks for your help so far.
Old Apr 6, 2007 | 05:07 PM
Sharif@Forged
Forged Performance
Sounds good. This is exactly the type of feedback we are looking for. For better or for worse, this insures we'll always try to carry the best products. If the Innovates are having problems, its time for us to switch! I found some nice NTK wideband units, but the question is....would you guys be willing to pay $500-$700 for a bulletproof NTK wideband?
For instance, we have never had an HKS Knock Amp AF sensor or unit go bad....even after months and months of use, and plenty of leaded fuel on my car.
Old Apr 6, 2007 | 10:14 PM
supra crazy's Avatar
supra crazy
I had the same problem with mine, after about a month of useing it the screen just went blank one day. I drove it home and unpluged all the connections and reconected them. It fixed the problem, with the blank screen, but the sensor went bad from being exposed to the exhaust gases without being heated. I then had to buy a new sensor and recalibrate. After I got the sensor in, some how without me hooking it up to a laptop, the main unit switched the fuel type from gasoline to methenol and I kept getting a ****ed up reading until I bought a serial to usb port and hooked it up to my laptop to find out what was up.
Old Apr 7, 2007 | 04:37 AM
MADScientist's Avatar
MADScientist
Sharif,
My offer still stands on the FJO and FCON feedback idea... LOL!
Old Apr 15, 2007 | 06:31 PM
BootieMAN's Avatar
BootieMAN
Default Update
My a/f readings would jump all the way up to 20-30 at wot
After replacing my sensor, the readings are now correct. My old sensor went bad at around 1000 miles.
Many thanks to Sharif for taking good care of me!
Old Apr 30, 2007 | 08:55 PM
gcoupeturbo's Avatar
gcoupeturbo
did anyone have car hesitations with this sensor going bad? mine is connected to the hks fcon.. thanks
