Coolant bypass mod WHAT IS THE DIFFERENCE?
Old May 7, 2007 | 01:16 PM
Javi's Avatar
Javi
Default Coolant bypass mod WHAT IS THE DIFFERENCE?
Yes, Iv'e searched, yes I know there is a mod and it's supposed to work, but I've got my hands on a VQ35 Pathfinder coolant bypass and except for the thermostat found in the truck bypass, I just can seem to find any benefits/difference in them, can anyone tell me of clarify me this????
I've even got the part# 11060-5w900
Attached Thumbnails Coolant bypass mod WHAT IS THE DIFFERENCE?-coolant-bypass.jpg
Old May 7, 2007 | 01:47 PM
westpak's Avatar
westpak
SFZCC
Where the thermostat goes you installed a cap/fitting that connect to a spot on the block that is normally blocked off
Attached Thumbnails Coolant bypass mod WHAT IS THE DIFFERENCE?-vq35build-026a.jpg
Old May 7, 2007 | 04:58 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
^^^what he said^^^
Old May 7, 2007 | 06:49 PM
andypandy's Avatar
andypandy
for extra cooling i presume? where does the thermostat go then?
Old May 7, 2007 | 06:52 PM
westpak's Avatar
westpak
SFZCC
Yes better flow.
You still keep your stock thermostat in it's stock location
Old May 7, 2007 | 07:31 PM
Nathan's Avatar
Nathan
This is a low cost do it yourself option.
It does not use the extra thermostat, but flows all the time.
Coolant temps remain the same as before as the OE thermostat is still opening the same as normal & restricting total flow when the motor is cold
Attached Thumbnails Coolant bypass mod WHAT IS THE DIFFERENCE?-imgp0529.jpg   Coolant bypass mod WHAT IS THE DIFFERENCE?-imgp0528.jpg
Old May 7, 2007 | 07:39 PM
westpak's Avatar
westpak
SFZCC
Not bad but I prefer the Pathfinder mod as the fittings you have there are about 1/3 the size
Old May 7, 2007 | 07:42 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
So, how hard is the do it yourself on this?
Old May 7, 2007 | 07:54 PM
Eazzy's Avatar
Eazzy
https://my350z.com/forum/engine-and-drivetrain/195998-rear-cylinder-coolant-bypass-modification.html
Old May 7, 2007 | 08:01 PM
Nathan's Avatar
Nathan
Not bad but I prefer the Pathfinder mod as the fittings you have there are about 1/3 the size and wont flow as much.
Both mods flow from the opening in the back of the V.
When you check the openings to the block at the bottom of that cover, you will see they are only small.
The Pathfinder flow is only utilised when the aux thermostat opens under extreme heat conditions. Mine flows all the time yet still runs at the same temps under normal conditions.
Under extreme conditions the pathfinder mod will flow more but both do the job of bypassing some of the water from the 2 rear cylinder heads.
Old May 7, 2007 | 08:04 PM
platinum350's Avatar
platinum350
is this the same thing as what they recomend when installing a MotorDyne spacer, I did something similar. Has to be closed when external temps are above 55.
Old May 7, 2007 | 08:16 PM
Eazzy's Avatar
Eazzy
Apples and Oranges---err --Watermelons
Old May 7, 2007 | 09:04 PM
Javi's Avatar
Javi
Thanks everyone for the info, NOW I get it!!!!!
Eazzzzzzzy I don't know where you got that link, but after the 9th page I gave up... you are the man in the search department...
Old May 7, 2007 | 09:27 PM
Eazzy's Avatar
Eazzy
Is that good or bad ??? Iv had it buried in my saved file and wasnt sure if it was still good
350z82
Oct 1, 2015 06:25 PM
