vortech FAQ: read this before asking vortech questions
Old Oct 9, 2012 | 12:03 PM
  #1921
usingthejohn's Avatar
usingthejohn
Originally Posted by str8dum1
why cant you change it yourself?
the brackets are completely different, so theres no way you installed a rev-up kit on a non-revup motor.
Originally Posted by - bigc -
+1 on DIY...you just need a few wrenches and a strap wrench to hold the pulley still.
I had the whole thing installed. But what I'm talking about is here:
https://my350z.com/forum/7001303-post1.html
If you look at photo #1, the pulley on the actual s/c needs to be installed the opposite way. I called Vortech, who confirmed the same; he also mentioned that the pulley needs to be removed via impact wrench, which I don't have.
Old Oct 9, 2012 | 12:18 PM
  #1922
- bigc -'s Avatar
- bigc -
gotcha. you should still be able to break that pulley loose using a strap wrench to hold it steady. your choice though.
Old Oct 9, 2012 | 01:01 PM
  #1923
usingthejohn
Ah, OK....I'll try that first. Worse things worse, Gearheinz performance said he would be willing to do it for me this week; i just need to find time to bring it to him.
Old Oct 9, 2012 | 01:29 PM
  #1924
350z006's Avatar
350z006
Are you able to drive your car to Long Beach? I've taken the cog pulley off my blower plenty of times, just need a cog belt and the right tools....btw, do you have a revup or non-revup?
Old Oct 9, 2012 | 01:50 PM
  #1925
usingthejohn
I could drive it to Long Beach; just leave the cog-belt off, right?
Old Oct 9, 2012 | 01:54 PM
  #1926
350z006's Avatar
350z006
Right...it's not like you can put it on properly in the first place...Also, bring your cog belt...
You still have my cell #? send me a text....
Old Oct 9, 2012 | 02:12 PM
  #1927
usingthejohn
bollocks...no i don't have your cell number. maybe i can FINALLY pick up your fuel rails, too.
shoot me a PM with your number
Old Oct 10, 2012 | 09:20 AM
  #1928
TunerMax's Avatar
TunerMax
Any good "DIY" Links for this install? Primarily trying to get together more specific tool's needed list, As I'm driving from my place in Canada to The U.S. to install this in a friends garage this weekend. He has no tools, I need to bring whatever I might need.
I've seen a bunch of threads on the installa nd read the instructions many times, just looking for a tools needed list mainly.
Old Oct 10, 2012 | 09:27 AM
  #1929
350z006's Avatar
350z006
Here's a good guide that I used when I first installed my Vortech:
https://my350z.com/forum/forced-indu...nks-of-fi.html
And superchargersonline.com has good DIY as well, including tools needed:
http://www.superchargersonline.com/i...age=page&id=51
Old Oct 10, 2012 | 12:48 PM
  #1930
SkyZ33's Avatar
SkyZ33
Driving to WA?
Old Oct 10, 2012 | 10:21 PM
  #1931
TunerMax's Avatar
TunerMax
Thx dude great links. Neither have a part list that is more specific than the vortech one though. No biggie, the whole thing looks like a cake walk anyways, I'm just trying to over prepare lol.
Originally Posted by SkyZ33
Driving to WA?
Upstate NY
Old Oct 11, 2012 | 08:17 AM
  #1932
usingthejohn
OK, I got the correct pulley installed onto my blower, thanks to Gearheinz.
Now, another issue (albeit it, minor at this time). But Last night, i installed the 2.87 pulley on my bracket, however even just hand-tightening the bolt, the pulley would NOT turn at all; installing the 3.12 pulley in place of the 2.87 enabled me to freely spin the pulley.
The problem I'm encountering is similar to this:
https://my350z.com/forum/forced-indu...not-right.html
So, what is the problem? The thread above didn't really cite what needed to be done. I was thinking of having it milled down, but after reading the above thread, i'm not sure i thats the accurate way to go.
Thanks for the help, My350z. Looking forward to joining the FI ranks once I get the above hiccup cured.
Old Oct 11, 2012 | 09:20 AM
  #1933
str8dum1's Avatar
str8dum1
yes it needs to be machined down
Old Oct 11, 2012 | 09:35 AM
  #1934
usingthejohn
OK, wasn't too sure if that was the route you went with. Did you just machine down the flag side of the pulley (closest to the bracket) and (i'm sure i know the answer is yes) but any machine shop can do this? IIRC, you mentioned it needed to be machined down by 0.90", correct?
Old Oct 11, 2012 | 11:37 AM
  #1935
- bigc -'s Avatar
- bigc -
this diagram shows what needs to be removed
Old Oct 11, 2012 | 12:17 PM
  #1936
usingthejohn
How much material is that then? And thanks for that diagram.
**EDIT** i'm at work, so i don't have the pulley in front of me, but i'm assuming that the material to be removed just needs to follow the diagram, and down flush with the face of the pulley, correct?
Old Oct 11, 2012 | 02:43 PM
  #1937
- bigc -'s Avatar
- bigc -
yep, just get it down flush to the face of the pulley. the part that is rubbing is the area highlighted in yellow.
Old Oct 15, 2012 | 07:36 PM
  #1938
usingthejohn
looks like my blower will need a rebuild...not surprising, since i bought it used. I was wondering, has anyone on here ever rebuilt their blower themselves? It isn't an issue of me being cheap; rather, i want to learn to do as much on my car as possible. i've seen a couple DIY threads online via other forums (s2ki, moddedmustangs) and curious if anyone here has done so themselves?
EDIT: Found the following link; curious if anyone else here has gone the DIY route on the rebuild?
https://my350z.com/forum/engine-driv...haft-seal.html
Old Oct 16, 2012 | 05:40 AM
  #1939
TunerMax's Avatar
TunerMax
Got it this weekend but vortech sent the wrong pulley and blower trim.... Looks like this won't be running till at least next season
Old Oct 16, 2012 | 08:55 AM
  #1940
evilscorp's Avatar
evilscorp
Anyone know if Vortech will supply the chargecooler in black? About to order the tuner kit but would prefer a black one and do many of you guys leave the two installation brackets attached to the chargercooler to give it more support on the bottom? Just looks a bit weak with only one side supported, but may have issue with my Zspeed undertray fouling if I leave the install brackets on for support.
