Official STS Rear Mount Turbo Discussion Thread
well i'm going to give them a call (STSturbo) today and ask what i can get for this kit if to expensive and i can compare to an aps turbo kit then i will invest in the aps turbo kit. AthenG how much did you get your turbo kit for?
I was thinking of calling cobb tuning down in dallas, tx and ask if they are familiar with install if not I will call this dyno shop in kansas city they are called the house of boost in kansas.
I still have alot of researching to do though but this is what i need is a turbo kit it sucks how a mazda3 speed can walk away from a z on a roll. lol..
/\ +1
I was one of the first 5 testers (first Revup and first 6mt G35 and first one to have the modified piping) so I got a good deal with pretty much free install with 2 custom tune. To bad you are not close to CinMotorsports because they are one of the first shop to introduce this kit in our car. CinMotorsporst know this kit very well so try to contacting them and ask how much will the kit cost from them. You will also get an excellent customer service and they can guide you through the process...
Hey guys, it's been a long time.
My car is sitting in my garage this winter, but come Spring I'm selling it. One friend who is interested has an '06 Revup. I know this has been covered, but will my '03 kit bolt up to his Z? I'm hoping to sell the car without parting it out, but we'll see.
- Jon
- Jon
- Jon
- Jon
What's the latest, Cube?!?
Any clue what the going rate would be for a used STS tuner kit w/ around 5k miles on it? I'm considering parting it out to a friend, but I don't want to screw him and I don't want to screw myself.
I've been out of the game so long that it took me quite a while to price out all of my other parts as well.
Uprev tune update for the STS system. There has been alot of speculation about the lack of "safeguards" with the uprev tune for FI. Last week I had a 02 sensor go bad....the car boosted up and I pitched her a little sideways only to have the car shut down moments later with poor throttle response and compete inability to rev above 2500 rpm. I called my tuner with the problem and he told me "I built in a 2500 RPM rev limit as a fail safe if the ECU was reading different information than what the tune intended". I ran some diagnostics......found the faulty O2 sensor.....replaced them both for safety sake and wholah....The car rips to redline with perfect AF's and throttle response.
Just my 2 cents on the Uprev tune for FI.
I’m not making this up.. all this scenario happened to me multiple times… This is one of the reason why my motor is still intact.… just my .02.
Limp mode is not enough, 02 feedback is in close loop so you are basically cruising.... What happen if your car overboost to 20psi at redline? What happen when you are WOT above 5000rpm and one of you injector failed? Active Knock control on the entire rpm and overboost fuel cutoff is a must in my book. You can drive normal and not detonate, you can hit mild boost on a bad set of gas and not detonate. What if you go WOT and start hitting your high boost on the higher rpm? That bad set of gas will cause you to detonate and it will be to late because you have no idea that your already detonating. Trust me, this happened to me, I was fine until I hit 5psi and when I hit 5+psi this mean I'm redlining that sucker. You are active in racing so let me ask you, when was the last time you spent most of your time under 5000rpm? Like I said, detonation may not happen in the lower rpm or mild boost. Once you are constantly racing that heat can build up and a lot of things can happen above 5000rpm... I think the overboost fuel cutoff is as important or if not the most important in my book. To may engine blew because of overboost or boost creep. No boost controller can match an EMS or ECU oveboost fuel cutoff can give you.
