Official STS Rear Mount Turbo Discussion Thread
Old Oct 21, 2008 | 12:10 PM
  #1501
Ahsmo's Avatar
Ahsmo
Imakecopies
Originally Posted by JonnyC
Since my town doesn't require emissions, to play it safe I'll just go with test pipes. I would love to get the XYZ pipe, but it's quite pricey.
What do you guys recommend again for test pipes? I need something cheap. I'd like to get ones that have two extra bungs welded in though so I don't have to head to the exhaust shop. I think maybe the only ones that have that are the Berks, although they don't have the support tabs on them.
My T-Pros ebay test pipes have never cracked.
Old Oct 22, 2008 | 09:02 AM
  #1502
Boozt's Avatar
Boozt
I want to do my research....I have run cats....what will work best with the STS kit. Educate me boys........this is new wrinkle in my FI STS adventure.- Jim
Old Oct 22, 2008 | 11:18 AM
  #1503
JonnyC's Avatar
JonnyC
according to goosegoose, the best thing to run for the stock setup is 2.25" diameter test pipes. Allows for better spool up, along with increased safety (turbo won't be damaged by a cat blowing out).
Old Oct 22, 2008 | 12:36 PM
  #1504
DanielW's Avatar
DanielW
^ true the 2.25 inch test pipes will take away slightly from your top end but they cut down on surface area for heat loss and also increase exhaust gas velocity which gets the turbo spooling a little faster.
Old Oct 22, 2008 | 06:28 PM
  #1505
athenG's Avatar
athenG
I just got back from the track and did get 7 runs!!!! That's right 7 runs in 3 hours (6pm-9pm) lol .. The good news I'm trapping 111mph consistently (best was 111.69mph), bad news I cant hook for ****!!! Street tires and FI FTL!!!! This was done with my heavy Work VSXX 19's and my best 60' was 2.336 (but mis-shifted on 2nd). My 60' was consistently around 2.4-2.5. This was my second time at the track. My first time was bad coz I shifted at 6000rpm on every gear This time I shifted around 6500-6700rpm..
Here's my best..
60 - 2.421
330 - 6.078
1/8 - 8.960
1/8 trap - 87.15mph
1000 - 11.40
1/4 - 13.43
1/4 mph - 111.69
I was spinning and hopping like crazy. Also I was knocking again like crazy! I dont know why I knock like crazy when at the track but not on the street. I do a lot of drag on the street and even when tuning but never knock like this. Utec is pulling timing left and right so I had to do 5 adjustment on my tune at the track. A/F is around 11.3-11.5 on full boost so I had to remove some timing just to eliminate some of the knock...ggrrr also had shift knock so I had to tune the Timing 0 column above 5000rpm to eliminate the shift knock. oh, well I need DR/Slick and lighter wheel!!!
Old Oct 22, 2008 | 09:25 PM
  #1506
JonnyC's Avatar
JonnyC
Here's my best..
60 - 2.421
330 - 6.078
1/8 - 8.960
1/8 trap - 87.15mph
1000 - 11.40
1/4 - 13.43
1/4 mph - 111.69
Well that's good that things were mostly running good. I don't know jack about 60' times so I won't try to comment on that.
As for the knock - that sucks. Your IAT's running really high? I had the same shift-knock issue with my Vortech - I believe I had to add fuel and pull timing above 4500 in the 0 column to completely get rid of it.
Old Oct 22, 2008 | 09:43 PM
  #1507
athenG's Avatar
athenG
My IAT was about 25C-31C so it wasnt crazy... I just dont get it that I get crazy knock at the track but not on the street I copied my timing from 10 column to my 0 column above 5000rpm and that fix some of the shift knock... Anyways my 60' was horrible!!!! Trap is pretty good and indicate that it is a mid 12's easy with some nice 60'... I also have a G35 so my car is heavier...
Old Oct 23, 2008 | 05:16 AM
  #1508
Boozt's Avatar
Boozt
BUT...I need to run cats. My set up is 7-8 lbs of boost on MBC with an APS tall boy plenum (stuff affecting flow).
Old Oct 23, 2008 | 05:20 AM
  #1509
goosegoose's Avatar
goosegoose
Why don't you try the Motrodyne XYZ pipe with HFC option? A single larger HFC located further downstream may have less chances blowing up than two smaller CATS in the OEM positions.
Old Oct 23, 2008 | 05:45 AM
  #1510
str8dum1's Avatar
str8dum1
111 mph traps should be mid 12's. so get the spinning and 60ft down and you'l pick up almost 1s.
Here's my best..
60 - 2.421
330 - 6.078
1/8 - 8.960
1/8 trap - 87.15mph
1000 - 11.40
1/4 - 13.43
1/4 mph - 111.69
Old Oct 23, 2008 | 06:06 AM
  #1511
athenG's Avatar
athenG
Yeah, and this was with my 19's.. I might go back again on 11/09 with the G35NYC crew and Glex might lend me his 18's with Nitto Invo. Not sure if that is going to grip on colder weather. The tack last night was just horrible.. There was a 350z there and consistently getting 2.6 60' Next Spring I will definitely get a smaller wheel (15-16 inch) and Slick...
Old Oct 23, 2008 | 06:51 AM
  #1512
DanielW's Avatar
DanielW
well if you can take .25 seconds off your 60' which is entirely doable i think, you should take .5 seconds off of your ET which would put you in 12's. I'm thinking 12.7-12.8
Old Oct 23, 2008 | 10:51 AM
  #1513
Boozt's Avatar
Boozt
Thanks, I'll look into that.- Jim
Old Oct 24, 2008 | 01:16 PM
  #1514
Boozt's Avatar
Boozt
Good news...turbo is intact, not broken or bent. XYZ pipe with HFC's are on the way.
-Jim
Old Oct 27, 2008 | 02:36 PM
  #1515
DanielW's Avatar
DanielW
cool can't wait to see how it does with this kit ^
Old Oct 30, 2008 | 08:20 PM
  #1516
JonnyC's Avatar
JonnyC
^ Yes, I'm very interested as well.
Well, I am definitely getting some compressor surge when letting off when just rolling into boost. Letting off from WOT is fine, but other than that I definitely get a fluttering "squelch" sound from the rear. I have the -11 psi spring now, and in my logs I see it hitting -11+ psi when I'm off-throttle. However, I'll have to double check vacuum at idle tomorrow. I may just go with the -9 psi spring.
So all you guys hear is a "whoosh" or flutter from the BOV letting off under low boost? Nothing from the rear? I'm just wondering why I would be the only one having an issue.
Old Oct 31, 2008 | 05:29 AM
  #1517
Boozt's Avatar
Boozt
I should get my car back today.....It's rainining hard here in Cali so I won't be able to give a good power report until the roads dry out a bit.
Old Oct 31, 2008 | 05:42 AM
  #1518
athenG's Avatar
athenG
How can you get compressor surge at -11 or anything below 0psi? Are you sure it is a surge? On a low boost (1-3psi) all I hear is just a flutter. when driving the flutter sound like it is coming from the back though Even at cruising the turbo is going to whine and it is normal... I even get that whining sound even in vacuum which I kind alike coz I love the sound of the turbo... What I love the most is going up hill just cruising and I hear the turbo whined even on Vacuum!!! I really doubt you are hearing a compressor surge at vacuum.
Old Oct 31, 2008 | 06:21 AM
  #1519
WASHWIZ's Avatar
WASHWIZ
I think what you are hearing is the WG. My car dose the same thing.
Old Oct 31, 2008 | 08:03 AM
  #1520
JonnyC's Avatar
JonnyC
I know, it's crazy. I get it between like 0 - 1 psi. But it seems like you have the same thing. I checked my vacuum this morning, and it is -11 psi, and I have the -11 psi spring in the BOV.
So what is that noise we hear? The WG? I don't see how it could be the wastegate, since it should be staying closed at all times below 3 psi or so. I just thought it sounded like air being forced back out the turbo air inlet, which is compressor surge.
