Official STS Rear Mount Turbo Discussion Thread
Old Mar 28, 2009 | 08:38 PM
  #1821
DudeMan's Avatar
DudeMan
also can anyone post their maps with similar mods-
440cc
plenum spacer
walbro
resonated test pipes
and the psi anywhere from 7-9psi just to compare maps
Old Mar 29, 2009 | 04:53 AM
  #1822
athenG's Avatar
athenG
440cc
plenum spacer
walbro
Is this for RC Inj? I have the old DW 440cc that was rated at 3.5bar so it is really close to 410cc.
Old Mar 29, 2009 | 10:57 AM
  #1823
DudeMan's Avatar
DudeMan
im not sure i just called the previous owner and he said he doesnt know... lol he said they came with the kit and theyre blue? so im guessing not rc? maybe dw?
Old Mar 29, 2009 | 11:21 AM
  #1824
tiguy99's Avatar
tiguy99
Originally Posted by goosegoose
Silly people.
I'm not God.
Life has just been ridiculously busy lately.
Sorry for not checking this forum as often as I should.
Here's how my exhaust has evolved since summer 2007:
Setup ONE
OEM Manifolds
OEM CATs
OEM Y-Pipe
OEM Midpipe with OEM Resonator
STS Tail pipe
Verdict: Pretty loud, but not unbearable. Drone/rasp at ~2K-RPM was unbearable.
Setup TWO
OEM Manifolds (JetHot-Coated and Header-Wrapped)
Fast Intentions HFCs (Header-Wrapped)
OEM Y-Pipe (JetHot-Coated and Header-Wrapped)
STS Endpipe
Verdict: Louder than before. Drone/rasp at ~2K-RPM was VERY unbearable.
Setup THREE
Fast Intentions HFCs (Header-Wrapped - CAT cracked and blown away)
OEM Midpipe with Magnaflow Muffler (JetHot-Coated and Header-Wrapped)
STS Endpipe with Hushpower Resonator (JetHot-Coated and Header-Wrapped)
Verdict: Not as loud as before. Drone/rasp at ~2K-RPM became acceptable.
Setup FOUR
Kinetix Resonated Test Pipes (JetHot-Coated)
Verdict: Fumes stink. Overall volume acceptable. Loud as hell at WOT. Drone at ~2K-RPM became very acceptable.
Setup FIVE (Pending-Perhaps by Late Summer 2009)
OEM HR Headers (JetHot-Coated)
GTM HR Resonated Test Pipes (JetHot-Coated)
Motordyne XYZ Pipe with HFC Option (JetHot-Coated)
Verdict: No idea. Hopefully fumes won't stink up at least.
Goosegoose and Jonny, thanks! This is what I was looking for. Did you manage to ever record a video clip showing off the different sound levels and part combinations?
Old Mar 29, 2009 | 11:53 PM
  #1825
Zski's Avatar
Zski
Ive got an STS kit with 4000 miles on it if anyone wants it. I got it from CNC out of South Carolina used and wasn't able to install it before going overseas so it is in Colorado waiting for someone to upgrade their car. $3999 and its yours.
Old Mar 30, 2009 | 05:13 AM
  #1826
Boozt's Avatar
Boozt
Diffuser update- Fit is good with upgraded hardware (go to ACE) and rebend/modification of leading edge brackets. There is plenty of room to allow for the turbo and piping with the TS diffuser and it looks pretty trick while keeping to many suspicious eyes away from the turbo. Keep in my mind by filter is mounted directly to the turbo and my piping is custom.....but fit with the kit is very good. Here are pics of my set-up prior to diffuser install. I post new pics later this week.
Old Mar 30, 2009 | 07:12 AM
  #1827
eXe-Chris's Avatar
eXe-Chris
Hey just to confirm with you guys the oil return line from the STS oil pump dumps the returned oil back into the passenger side valve cover? Anyone know about how much oil this is dumping in the valve cover?
Old Mar 30, 2009 | 05:38 PM
  #1828
harvin350z's Avatar
harvin350z
Hi everyone, this might be a silly question, does the utech system that comes with the sts turbo kit also control the boost when switching maps?? Thanks in advance.
Old Mar 30, 2009 | 06:46 PM
  #1829
JonnyC's Avatar
JonnyC
If you buy the TurboXS Boost Control Solenoid (BCS) and mount it up it will allow you to enter a boost map for each of your fuel/timing maps. You can then switch between them. Also, instead of the TXS BCS you can use a GM solenoid. I don't know the details, but there should be some info on this site somewhere.
However, there are a decent number of people who haven't been able to get it working right and ended up going with an Electronic Boost Controller (EBC) that is completely separate from the UTEC. The verdict is still out on my TXS BCS - we'll see if it works this Spring.
Old Mar 30, 2009 | 08:54 PM
  #1830
harvin350z's Avatar
harvin350z
I already bought the map selector so might as well buy the TurboXS Boost Control Solenoid and see if it works for me....Thanks for your help. I should know by next week. I will post my findings.
Old Mar 31, 2009 | 05:40 AM
  #1831
athenG's Avatar
athenG
I have been using the Turboxs BCS for almost 2 years without a problem. It does the job but an EBC is definitely better if you have the $$$.
Old Mar 31, 2009 | 08:16 AM
  #1832
Boozt's Avatar
Boozt
Ok....I am trying to blend in the chunk of CF out back with the rest of the car. I bought this kit http://www.thezstore.com/page/TZS/PROD/350z03a/50-1893 (minus the rear guards).......My Z is chrome silver......so what do you think??? I'll post complete pics after install.
Old Mar 31, 2009 | 10:30 AM
  #1833
DudeMan's Avatar
DudeMan
so i guess thats a no to the maps? huh
Old Mar 31, 2009 | 10:59 AM
  #1834
Chaser720's Avatar
Chaser720
Lemoned Z
I think as far as maps go, people are kind of sensitive on sharing them. Most of them payed upwards of $500 for them and posting them for all to see is kind of like giving away what is yours.
Old Mar 31, 2009 | 11:28 AM
  #1835
DudeMan's Avatar
DudeMan
well someone replied.. i snt this thread to help people with sts kits? i wouldnt care if i spent the money then shared my stuff... guess im just too nice huh
Old Mar 31, 2009 | 12:29 PM
  #1836
Boozt's Avatar
Boozt
Sorry dude....I would share my maps but I don't do them....I have a quasi sponsor with a local speed shop for my racing and they design and load everything according to my driving style, track type, and time of year (it gets crazy hot and cold which seems to affect tune).
Old Mar 31, 2009 | 02:30 PM
  #1837
DudeMan's Avatar
DudeMan
thanks anyways someone already pm with some maps
so does anyone else have idle problems? i tried searching the word idle thorugh this thread and got nothing
my idle will go from mid to high 13s then jump to 16-17 afs? i think i read something about someone drilling there tb to fix it but idk if that was for this problem
Old Mar 31, 2009 | 02:37 PM
  #1838
JonnyC's Avatar
JonnyC
Yeah, mine will sometimes jump to high 18's if it's idling too long and will coincide with a really rough idle. Someone did talk about gradually drilling larger and larger holes in the butterfly valve, but I'm hoping a simple idle raise (~1,000 RPMs) will fix it.
Old Mar 31, 2009 | 02:40 PM
  #1839
athenG's Avatar
athenG
Does this happen when the ECU try to correct your idle to 700rpm? My car pretty much run smooth above 800rpm and only stumble when the ECU try to bring down my idle to 700rpm. I'm thinking of bumping my idle to 900rpm because of this. Can you post your tune at 0% column and 500rpm-1000rpm?
Old Apr 2, 2009 | 09:56 PM
  #1840
harvin350z's Avatar
harvin350z
hey, any problems driving in the rain or the cold>? Or anyone goes to a carwash with underwash normally? Any advice would be good, this is my main concern with this kit. I know it comes with the soc for the filter, but can it really stop all the water that might get up there? Thanks in advance!
