Official STS Rear Mount Turbo Discussion Thread
Old Apr 27, 2009 | 01:29 PM
  #1901
DudeMan's Avatar
DudeMan
another update
well i put the 8.7psi spring in and got tuned but the car was only hitting 4psi and we couldnt figure out why but then i remembered that we move the wg line from the brake booster to the turbo... so i called sts and the first thing they asked was if it was placed there.
so instead of running the line back to the front im getting a big green spring with is 13.07psi and ill explain why
the reason the line is ran to the front is because the turbo will compensate and work harder to make targeted boost so by upgrading the spring and keeping it at the turbo it should be more responsive and spool a little quicker
Old Apr 27, 2009 | 06:59 PM
  #1902
DanielW's Avatar
DanielW
Originally Posted by DudeMan
another update
huh?
Old Apr 27, 2009 | 09:58 PM
  #1903
DudeMan's Avatar
DudeMan
Originally Posted by DanielW
huh?
on your sts kit you have the line going to your wg that runs all the way from your brake booster(because thats how sts says to do it) so you hit targeted boost.... because if it was ran like a normal front mount turbo setup the line would run to your compressor housing on the turbo... but theres about a 4.5psi drop from the turbo to the intake manifold since the pipings so long...
example
in my case i ran the line to my turbo instead of the brake booster so my wg sees the boost that the turbo is actually seeing which is 8.7psi but because of the pipes length it gives me about a 4.5psi drop so the intake manifold is only seeing 4.2psi...
so by upgrading the wg spring to a 13psi spring and keeping my line ran to the turboat the manifold it should hit about 8.5psi
get it meowwww?
Old Apr 29, 2009 | 04:38 PM
  #1904
JonnyC's Avatar
JonnyC
Is that a consistent 4.5 psi drop from the compressor to engine? I ran my wg off of the compressor housing and I think I only hit ~1.5 psi less (3.5 psi vs. 5 psi) on the stock wg spring.
Old Apr 29, 2009 | 04:56 PM
  #1905
DudeMan's Avatar
DudeMan
yes constant and theres no leaks in the system what so ever... if i remember correctly every 2.xft 1psi is lost depending on the pipe size
Old Apr 29, 2009 | 05:44 PM
  #1906
DudeMan's Avatar
DudeMan
so has anyone had problems with their oil pump? mine was staying on while the car was off and would shut off if i wiggle the power wire coming off the battery now the pump wont turbo unless i wiggle the relays... so tomorrow im taking out all the pins and soldering them in hopes of a faulty connection...
any takers?
Old May 1, 2009 | 10:35 AM
  #1907
JonnyC's Avatar
JonnyC
Nope, no problems with mine. It's actually a pretty quality wiring setup, so make sure you don't have it wired up wrong. Somehow the wire connected up to the fuel pump wire must be getting power, or that relay is faulty.
Old May 1, 2009 | 10:49 AM
  #1908
DudeMan's Avatar
DudeMan
yea thats the thing i bought this car with it already on... theres a lot of **** ups that im going through and fixing... so annoying!!!!
Old May 2, 2009 | 11:24 PM
  #1909
DudeMan's Avatar
DudeMan
i cant stand this utec it constantly wants to fight with the ecu so im selling mine and getting a universal aem
Old May 3, 2009 | 11:53 AM
  #1910
Ahsmo's Avatar
Ahsmo
Imakecopies
Bad choice. Haltech instead. More support for the 350z.
Old May 3, 2009 | 12:04 PM
  #1911
Ahsmo's Avatar
Ahsmo
Imakecopies
another update
Just to set things straight in this thread for anyone who reads this in the future, the information in this post is incorrect.
There is no such thing as a free lunch.
Place the wastegate reference line where you WANT to see the desired boost boost pressure. If you want 8 psi at the compressor outlet, put it right on the compressor outlet. If you want to see the desired pressure in the intake manifold, put the reference line to the intake manifold.
Old May 3, 2009 | 12:08 PM
  #1912
Ahsmo's Avatar
Ahsmo
Imakecopies
You were putting less air to the engine at 3.5psi. At a higher pressure, he is putting air into the engine at a greater rate which leads to more losses through the intake piping.
Old May 4, 2009 | 07:40 AM
  #1913
DudeMan's Avatar
DudeMan
so please tell me how thats incorrect?? sts themselves said run the line to intake manifold because the wg will open at the psi levels the mani will see no the turbo... just like when you have a boost leak yea youll hit the same boost but because the turbo compensates for it
Old May 4, 2009 | 06:51 PM
  #1914
JonnyC's Avatar
JonnyC
Quick update on my car...
I got the Magnaflow resonator installed in place of the stock one. I must say, it's not all that much different. It definitely helps, but I still don't want to be rolling into my neighborhood at midnight. However, I did install Kinetix resonated test pipes in place of my HFC's at the same time.
About the test pipes - my car stinks now. I can actually smell it while I'm cruising on the highway with the windows down, and I smell like exhaust when I get out. I might want to go the Motordyne XYZ route sometime, if I feel like dropping that kind of dough.
I installed the small green .5 bar wastegate spring in place of the stock .4 bar red one, and I'm hitting exactly 6 psi. My BCS doesn't seem to work as it doesn't increase boost - only causes the WG to flutter bad. Maybe I have it set up wrong, although I made sure to reference instructions from Julian (I think) in an old post.
Also, I'm hitting 93% duty cycle by 6,250 at 6 psi I either need to get a RFS or bigger injectors (or both $$$).
Old May 4, 2009 | 07:56 PM
  #1915
goosegoose's Avatar
goosegoose
Test pipes make everything noisy. Imagine how loud things would be with the test pipes without the magnaflow?
I wish you could hear my car now with Motordyne XYZ HFC. Sometimes I think it's quieter than stock on vacuum. Very unexpected.
Old May 4, 2009 | 07:58 PM
  #1916
goosegoose's Avatar
goosegoose
Somewhat related question:
Can changing the compressor and impeller wheel of the turbo change the sound/tone of the wastegate and blow-off valve?
Old May 4, 2009 | 08:05 PM
  #1917
JonnyC's Avatar
JonnyC
Did the HFC help out with the exhaust smell? Did Motordyne assure you that it wouldn't blow out?
Old May 4, 2009 | 08:22 PM
  #1918
DudeMan's Avatar
DudeMan
wastegate is pre turbo... and for the bov when i had my hks on my sti i noticed it got a little louder when i went form 17psi to 24psi but maybe it was just me
Old May 4, 2009 | 08:23 PM
  #1919
DudeMan's Avatar
DudeMan
i have resonated test pipes and then the big one near the turbo is deleted and i never smell gas or get complaints from any one? maybe your tune is a little rich?
Old May 5, 2009 | 05:45 AM
  #1920
goosegoose's Avatar
goosegoose
With my previous test pipe setup, the smell was so bad almost everyone commented on it. The smell was was with richer tunes, but still strong with leaner tunes.
With the Motordyne XYZ HFC, I smell some of the fumes when I just start the car, but after the car warms up, there is virtually no smell.
Tony from Motordyne said the HFC should not blow out.
