Official STS Rear Mount Turbo Discussion Thread
Old Mar 21, 2013 | 02:40 PM
  #2901
CRIDDA's Avatar
CRIDDA
Nice numbers!!!
Old Mar 21, 2013 | 08:03 PM
  #2902
rawley_12003's Avatar
rawley_12003
thanks i think it should have been a bit higher if i didn't install that 3.3fd but the gears pull very good and tires stay to the ground. i was at 407 whp at 10 to 11 psi with the stock 3.5 gears but when we did the first run with the 3.3 fd it dyno'd at 380 whp with the old tune so up the power to 15 psi and made 436 whp and 399 tq. i'm happy with these numbers especially coming off a dyno dynamics (heartbreaker dyno).
Old Mar 21, 2013 | 09:41 PM
  #2903
CMyTailsBlink's Avatar
CMyTailsBlink
Originally Posted by rawley_12003
well i'm about a month away from my dyno tune to 500+whp. hence why i'm asking i will be upgrading my clutch (soutbend) light weight flywheel (Z1motorsports) bigger fuel pump (walbro) and z1 plenum spacer. I have the haltech pro for the 350z.
I highly HIGHLY recommend you stay away from Walboro. I bought 2 for my set up and they both failed in less than 6 months. Go with DeatschWerks. I bought 2 of them to replace the Walboro's and they were so strong that I had to pull a fuze on one of them and run a single pump before I got a retune because they flowed/pushed so much. I haven't had any problems with them at all since the install, and its been at least a year or more.
Old Mar 22, 2013 | 12:16 PM
  #2904
rawley_12003
well we tried installing the the walboro 400 but didn't fit so we went down to the aeromotive fuel pump. I have a question for you CMYTAILSBLINK, i saw one of your old youtube videos what dyno where you on and what was your setup that got you to your 500 whp mark?
Old Mar 22, 2013 | 08:40 PM
  #2905
CMyTailsBlink
If your talking about when i did my first built, I'm not sure of what kind of dyno it was, but it was at Performance Factory in orlando. My set up on my first built was a 3.8l sleeved block, with stock heads. The STS kit was their upgraded kit, with a Ball bearing turbo 67mm, with a .58 Ar housing, and a bigger intercooler. Fuel system was an APS extreme system good for 1000whp. The set up yeilded 558rwhp @18lbs on pump gas, and 624rwhp @21lbs on C16. Is that the info you were looking for, or anythign else more specific?
Old Mar 23, 2013 | 07:03 AM
  #2906
rawley_12003
no that was the information i was looking for i greatly appreciate it.
Old Mar 23, 2013 | 07:07 AM
  #2907
rawley_12003
i currently have a stage 1 importpartspro long block, a basic AAM fuel return system, aeromotive fuel pump, southbend clutch and z1 ultra lightweight flywheel, 600cc deutchwerk injectors, with a haltech plat pro piggy back. the turbo im running is a sts brand gt35 equivalent.
Old Mar 23, 2013 | 09:24 PM
  #2908
CMyTailsBlink
Great choice going with Southbend, thats what is in my car now.
I had the Haltech on my first set up. I was so pissed when we couldn't use it for the new build. So damn expensive.
You might want to consider getting rid of the Ultra lightweight flywheel. I had one on the first set up and i ended up switching it. Sure, you'll rev quicker from the lower rotational weight, but you'll make more boost faster with a heavier flywheel. The extra weight adds load to the engine, you'd be surprised at the difference. Well worth it to me.
Also, a heavier flywheel won't slow down as fast, so it will hold your RPM's up between shifts, helping to keep you in boost/power band.
Old Mar 24, 2013 | 09:03 AM
  #2909
rawley_12003
So on the Haltech what was wrong that you could not use it? Huh i just installed the flywheel and clutch it might have to stay in for awhile. The wife would kill me if she knew i bought another one. But i understand what you are talking about for a heavier flywheel.
Old Mar 24, 2013 | 11:33 AM
  #2910
str8dum1's Avatar
str8dum1
the haltech was set for a nissan crank trigger pattern, not gm like his new motor.
Old Mar 24, 2013 | 12:42 PM
  #2911
rawley_12003
oh duh.. thats right i completely forgot he has an ls motor lol..
Old Mar 24, 2013 | 02:08 PM
  #2912
rawley_12003
can anybody recommend a good high flow resonator i am currently running straight pipe and it is way to loud for daily driven.
Old Mar 24, 2013 | 09:54 PM
  #2913
CMyTailsBlink
Ah man, I remember when my first build was complete. I didn't want any thing in the exhaust stream before the turbo, so I said no resonator. Jesus it sounded TERRIBLE. LIke a damn pack of fart can Hondas coming down the road I took it out for the first drive, came right back to the shop and put a resonator in there.
I can't remember the brand i used, but i think any HFC should work just fine. Just make sure its not cheap and going to come apart a kill your turbo. That has happened to one of the other rear mount guys, i think it was AthenG.
Old Mar 26, 2013 | 07:34 AM
  #2914
rawley_12003
I was think of putting on a vibrant hi flow resonator or a hushpower 2 flowmaster resonator. Just need to find out what the diameters are for the inlet and the outlet
Old Mar 27, 2013 | 06:36 PM
  #2915
rawley_12003
so i decided that i will be going with the vibrant super quiet resonator heard that brings down the rasp quite a bit. Any opinions
Old Apr 3, 2013 | 10:44 PM
  #2916
PikachuZ's Avatar
PikachuZ
Just had my car tuned using Uprev Osiris, at Dynosty. With the STS turbo kit, upgraded y pipe, berk test pipes, walker mid pipe, kinetix intake manifold, 600cc injectors, and snow water/meth injection, the car put down a max of 368whp and 350tq on a dyno dynamics dyno.
Old Apr 3, 2013 | 11:58 PM
  #2917
CMyTailsBlink
At how many lbs? Doesn't seem like your making nearly enough boost or power to have a water/meth kit.
Old Apr 4, 2013 | 07:46 AM
  #2918
PikachuZ's Avatar
PikachuZ
12psi
Old Apr 4, 2013 | 07:58 AM
  #2919
PikachuZ's Avatar
PikachuZ
It would be closer to ~410whp on a dyno jet run so the power levels not quite as low as it sounds on the dyno dynamics.
Old Apr 28, 2013 | 07:26 AM
  #2920
nofrey's Avatar
nofrey
Bump....
Damn reading all 146 pages made my eyes hurt. Ok thinking of going f/i and was debating between sts(if I find a good deal) and bp. Not looking for big power gains bit I'd like to be around 370ish whp. One question with this kit that I don't think was answered, will this kit work with a slammed Z? I saw boozt set up with a custom pipe and looked like a lot of clearance. Vortech s/c was on top of my list until boozt(I believe it's him) switched to sts and said it pulls way harder then his vortech.
Current power mods on the car: stillen intake box, motordyne 5/16 spacer, topspeed tp, x02 exhaust and osiris tuned by Shawn church. Dj # 284.9hp 272.3tq 04 Z
