Cam recommendation for Vortech
Old Sep 5, 2007 | 03:05 PM
RA11325's Avatar
RA11325
Default Cam recommendation for Vortech
Hey guys,
I think its time for me to step up to the plate and start upgrading my internals. I was wondering what some of the engine pros would recommend for a Vortech car that is not a daily driver. I am actually hoping that the car will have some serious lope at idle. Any ideas?
Old Sep 5, 2007 | 03:06 PM
Zilvia's Avatar
Zilvia
big *** cam.....................
Old Sep 5, 2007 | 03:15 PM
RA11325's Avatar
RA11325
Thaaaaanks JC.
Old Sep 5, 2007 | 04:00 PM
sentry65's Avatar
sentry65
the burninator
IMO GTM supercharge/NA cams or JWT will be the best choice
Old Sep 5, 2007 | 04:05 PM
booger's Avatar
booger
I believe he wanted a big lope in his idle . The Nismo and JWT [ from what I hear ] are basicly the same and will not give you a big lope . Idle is a little choppy but not what you are looking for . I dont think the GTM cams will be much different .
What is this car going to be used for ? Stock Vortech SC ....or custom setup ?
Old Sep 5, 2007 | 04:24 PM
GTM's Avatar
GTM
Vendor - Former Vendor
If you want something loopey our GTM Stage 3 cams are what you are looking for, Same cams I will be running in my personal car
-George
GT Motorsports
Old Sep 5, 2007 | 04:26 PM
NA&CH's Avatar
NA&CH
-George
GT Motorsports
Where can info be had on these George? Good for a NA build.
Thanks
Chris
Old Sep 5, 2007 | 04:32 PM
GTM's Avatar
GTM
Thanks
Chris
https://my350z.com/forum/showthread....t=GTM+camshaft
-George
GT Motorsports
Old Sep 5, 2007 | 05:06 PM
Zilvia's Avatar
Zilvia
Originally Posted by Vash350Z
Thaaaaanks JC.
youre welcome.......i wish i could do more that waste ban width sometimes... lol
WA2GOOD's Avatar
WA2GOOD
JWT makes over 5 different cams alone for the VQ35 that are readily available (and a few that are not advertised / "race only") , so it all depends on how agressive of a cam you can handle. We will be proyotyping yet another set of JWT cams (lets call them C9's) and they are so agressive that I am guessing that atleast a 1,300 rpm idle re-flash will be necessary for these monster cams (the most agressive cams for the VQ on the market to date)
With the lagging nature of the Vortech, as agressive of a cam as you can handle would be best, IMO.
--Scott
Old Sep 5, 2007 | 05:16 PM
booger's Avatar
booger
--Scott
Most companies do make more than one cam . I didn know JWT made so many though . Good to know !
And this JWT cam maybe what the OP is looking for !!!!
Old Sep 5, 2007 | 05:18 PM
jwttz's Avatar
jwttz
^+1 jwt does have alot to choose from then just the S series. They also have the c series which is more for racing than for the street, but require you to switch out you springs and retainers from what I understand.
Old Sep 5, 2007 | 05:25 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Hey guys,
Our GTM stage 3
Stg3 N/A, 302/292 degrees @ .012”, 256/250 degrees @ .050”, 11.50mm/11.00mm Valve lift (intake/exhaust)
SAM
GT MOTORSPORTS
Old Sep 5, 2007 | 05:26 PM
rocks's Avatar
rocks
The non advertised jwt cams are huge. You have to call and ask for them . Wish I knew that when I bought my cams, the revup S7 cams dont even make the idle funky at 450" lift.
Old Sep 5, 2007 | 05:29 PM
booger's Avatar
booger
Sounds like that would be the choice then !!
JWT cams FTW !!!!
Old Sep 5, 2007 | 05:34 PM
rocks's Avatar
rocks
I talked to jim wolf about it one day when i called them. One of the bigger cams he sells will make power all the way too 8500-9000rpms. Of course you either use it with like 15.1 compression or a turbo . He said it would work well with turbos, and i think they are the same price. I am not sure if they sell different springs than what is listed though. The next set of cams when i rob someone for money will be some big jwt cams and brian crower springs/retainers.
Does anyone know if the oilpump and waterpump would be ok too 9k rpms haha.
Old Sep 7, 2007 | 08:39 AM
Matt at PF's Avatar
Matt at PF
yes we use JWT cams.
Matt
PM me for all you performance needs
Old Sep 7, 2007 | 11:24 AM
sentry65's Avatar
sentry65
the burninator
IMO i'm not so sure about running huge cams with the vortech unless if you're reving to like 7500 rpms at least. Huge cams are just going to kill your low end and a lot of the benefit for higher rpms are going to be beyond your redline
Old Sep 7, 2007 | 11:59 AM
teh215's Avatar
teh215
Do any of the cams currently on the market cause problems with piston/valve clearance?
Old Sep 7, 2007 | 02:56 PM
WA2GOOD's Avatar
WA2GOOD
When cams are done right and the right ones for the particular aplication is selected, the cams should not only deal with the higher RPM's better (making more power), but even more importantly will minimize all that lag that is inharent with the Vortech and get you up ionto boost ALOT quicker. The goal here with cams would be to make better use of your boost/power and make more of it.
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
