Procharger SC pic on the Z!!
Old Jun 2, 2003 | 12:12 PM
  #121
Fëanor's Avatar
Fëanor
Default MAF sensor
"no one answered my question on why the MAF sensor is so high up!!"
If my understanding of this sensor is correct, it will get the most accurate reading of air flow and density if it is placed close to the throttle, especially if the kit is regulating pressure by venting gas. Otherwise, if no gas is vented and there are no major leaks, it wouldn't matter where this sensor is. At one end of the blower it would measure low density * high flow, and at the other end it would measure high density * low flow. The measurement would come out the same.
This kit looks impressive, if a bit pricey. That intercooler looks decent, too. I'm willing to entertain the idea that ATI has justified this cost by developing a high quality blower, in which case reliability would be very good. But they're probably just pricing according to initial demand. Cripes folks, there are economic realities at work here wherein businesses try to make a profit. Deal with it, nobody's forcing the kit on you.
Old Jun 2, 2003 | 12:18 PM
  #122
mcduck's Avatar
mcduck
There is a lot of conjecture here, but even with soft launches or what not, I'm not too keen on dumping $6000 + install on a kit that
A) doesn't get me into the 12s in the 1/4 mile
B) has not yet proven its realiability
C) is from a company with questionable warranty and customer service history.
I think I will have to go the Dr Bonz route and wait a few months to see how this comes out and compare to other offerings like the GReddy kit.... funny how Brickyard owners think alike!
Old Jun 2, 2003 | 12:26 PM
  #123
TJZ's Avatar
TJZ
Well your 'A' isnt confirmed yet. We don't know how fast it'll run with the 7psi pully on.
Far as B, and C goes. They would definitely steer me away from spending over 6k on this kit (that is, if i had the money). If I spent that kinda money and got dicked on customor service I would be soo pissed.
Old Jun 2, 2003 | 01:19 PM
  #124
Chebosto's Avatar
Chebosto
Default Re: MAF sensor
um.. you would get very high disturbed air flow from the throttle body opening closing so often... the maf sensor is supposed to take ambient temperature readings, i.e before the blower...
and if there is a bov. its most likely on the return tubing from the intercooler back up to the throttle body.... which means there will be venting prior to the orginial placement of that maf sensor..
here's taken from
http://www.se-r.net/engine/airflow_sensor.html
regarding MAF...
"Most EFI systems around today use air mass flow in determining the mixture under given operating conditions. Typically there is also throttle position, intake manifold pressure and/or temperature, exhaust gas oxygen (EGO), etc. The advantage to a mass air flow sensor ... allows the ECU to compensate for changes in atmospheric temperature, barometric pressure, and humidity. There are a variety of other sensors that the ECU reads to regulate things like fast (cold) idle, turning up the idle when the AC is on, etc. The mass air flow (MAF) sensor signal and engine speed are the primary (maybe only) determinants of fuel injector pulse length.
Newer systems (e.g. LH-Jet, Motronic, others) use either hot-wire mass air flow sensors or thin-film MAF sensors. [edit: nissans are hot wire]
In a hot-wire sensor, intake air flows over a thin wire heated by a small electric current. The wire is kept at a constant temperature by the current. with increased air mass flow (more volume, or colder denser, air) past the sensor, convective heat transfer from the wire to the air is increased, and more current is required to regulate the temperature. The current requirement thus acts as an index. It is converted to a voltage signal which is then used with engine speed as the main (but not only) inputs determining fuel injection."
with that being read. theoretically, wouldnt you want the maf sensor AWAY from what you're changing with boost via BOV....
Old Jun 2, 2003 | 01:25 PM
  #125
carfever's Avatar
carfever
Default help
ok i have gotten the winzip video to download but a pop up window came up and said it could not find the right compressor. all i can do is hear the sound of it without any picture. any suggerstions?
Old Jun 2, 2003 | 02:00 PM
  #126
Fëanor's Avatar
Fëanor
"with that being read. theoretically, wouldnt you want the maf sensor AWAY from what you're changing with boost via BOV...."
No...in effect the SP is merely redefining what the engine considers ambient conditions. It must measure exactly what the engine is consuming or its readings are worthless. The MAF sensor is used to adjust mixture (among other things), therefore it must know what it's mixing, be it compressed air or ambient air.
Think about it. If the sensor is prior to the blower, and a valve vents off half the volume of gas, the sensor will signal twice as much air as the engine is actually consuing. You'll run entirely too rich.
Old Jun 2, 2003 | 02:37 PM
  #127
2K350Z's Avatar
2K350Z
Default Re: help
Download the DivX codec. It will play fine after that.
Old Jun 2, 2003 | 02:42 PM
  #128
Cintel7's Avatar
Cintel7
Hum... I am not much into quarter mile times, just the trap speed since it indicates a better picture of what the car was making.
105-107 mph! Isn't that the same trap as the stock Camaro SS/Supra/E46M3s.
Old Jun 2, 2003 | 02:54 PM
  #129
carfever's Avatar
carfever
Default thanks
thank u so much fo helping me. i finally got to see it and it is looking sweet
Old Jun 2, 2003 | 03:04 PM
  #130
2K350Z's Avatar
2K350Z
Default Re: thanks
Glad to help out.
Old Jun 2, 2003 | 07:38 PM
  #131
12SecZ's Avatar
12SecZ
OT but I trapped higher than that with my $650.00 N20 Kit with screwed up timing on stock tires 10 % of the cost....
When all is said and done I expect 110 mph traps with my setup.
The Stangs out there with SC's trap around 120+ in the deep 11's as an example.
Old Jun 2, 2003 | 07:52 PM
  #132
CSHFLW's Avatar
CSHFLW
When are you going to get your NO2 working right??? I wanna see what it will do!
Old Jun 2, 2003 | 08:47 PM
  #133
AL350Z's Avatar
AL350Z
I'm with JoeShow750; I can't think of any way to adjust boost without changing the pulley and I don't think ProCharger is just throwing different sized pulleys in with the kit. Maybe this guy is running a 4.5 psi pulley to be safe at the track.
BTW, Where is all the talk about timing. My friends and I went through hell trying to figure out the best timing on a Supercharged Civic Si.
Old Jun 2, 2003 | 09:17 PM
  #134
lotus's Avatar
lotus
Thats not soo bad. I spent 34k on a car and got dicked on customer service by NNA after that another 6k does not seem so bad.
Old Jun 3, 2003 | 12:04 AM
  #135
zxsaint's Avatar
zxsaint
Fairlady Stalker
I'm also going to wait around for 6 months to a year to let the issues get ironed out and the prices to fall. Not to mention make use of the warranty (while it lasts)
Old Jun 3, 2003 | 03:35 AM
  #136
joeshow750's Avatar
joeshow750
Avalon says the fuel system can control boost . I asked them twice about it...I guess they just don't know for sure. I'm calling ATI tomorrow to find out what the deal is...so I'm not eating until then, that way the b*llsh!t they feed me won't taste as bad.
Old Jun 3, 2003 | 05:02 AM
  #137
Avalon Racing's Avatar
Avalon Racing
Avalon Racing
Default boost
Frusr of all ATi is not giving out any specs or prices.
As for booth, The 9intial piece that wiull alter boost is the pulley sizes. Then in conjuncction wi the the fuel management system, the boost and fuel can be fine tuned. The Fuel system alone will not due the work. But is it part of the whole picture. We will have a full tech write up shortly on tuning the system.
Regard
Old Jun 3, 2003 | 06:58 AM
  #138
zoasis's Avatar
zoasis
Default Re: boost
So where did the 369 WHP and the $5400 come from??
Old Jun 3, 2003 | 07:15 AM
  #139
dnguyen's Avatar
dnguyen
I agree...you'd want the MAF sensor in a position where it can get the most accurate reading of air that is being consumed by the engine so that the A/F ratio would be in correct proportions. The way Procharger positioned it seems to be more ideal than positioning it before the supercharger because of the reasons previously mentioned by Feanor. Plus the MAF can measure temperature, pressure, humidity, and airflow (like the article said), so just because the pressure is higher doesn't mean the MAF won't work correctly.
Old Jun 3, 2003 | 07:27 AM
  #140
Ozthe1's Avatar
Ozthe1
...how much does the SC cost , installed...
Thanx
