Si TRIM VORTECH.
Old Feb 11, 2008 | 12:51 PM
  #361
booger's Avatar
booger
Originally Posted by sentry65
yeah just getting into the sweet spot of a setup with a combination of mods is the trick. Once there, it's smooth sailing
Old Feb 11, 2008 | 12:55 PM
  #362
sentry65's Avatar
sentry65
the burninator
Originally Posted by booger
well it has been for me.
Once I took care of the issues I had, the setup just works.
I don't have belt slip, I get enough fuel and fuel pressure, I have a reliable tune/EMS, etc
Old Feb 11, 2008 | 12:56 PM
  #363
iStan's Avatar
iStan
ZR
Why do I suddenly have bad images of Sentry caressing his Z..
Old Feb 11, 2008 | 12:59 PM
  #364
sentry65's Avatar
sentry65
the burninator
everyone throws on a bunch of parts and hopes they all work right and work together well. It can get complex sometimes with how many aftermarket parts are on the car. Ironing out the bugs is all I'm talking about
Old Feb 11, 2008 | 01:12 PM
  #365
JET MECH's Avatar
JET MECH
True...............so true.................
Old Feb 11, 2008 | 01:13 PM
  #366
booger's Avatar
booger
11psi isnt going to get you belt slip . It isnt going to push an after market fuel system . It isnt going to push your belt set up . It isnt pushing any thing . WHy bring up a statement like you posted a little bit ago ? No one using the SI or T-trim blowers are looking for a sweet spot of a stock SC kit like you have
Old Feb 11, 2008 | 01:19 PM
  #367
sentry65's Avatar
sentry65
the burninator
You're right, my fuel system shouldn't have had issues, but it did.
My belt shouldn't have been slipping, but it was.
11psi isn't very high and I'm glad. It was 12psi before I swapped out my crawford cats and nismo exhaust for AAM cats and APS exhaust with X-pipe. IMO I wouldn't want 13+psi on my stock block engine. Maybe I'm just too conservative
yeah I'm not pushing anything on my setup except my whp. I try to make sure I'm not bringing anything close to the point of failure. I'd rather overcompensate than under compensate on the parts that keep things reliable. IMO the stock block can be perfectly reliable for a good long time and I intend to go that route since even built engines can have issues
What I meant by "sweet spot" is a setup that works, not something that breaks down every 2 days or has some issues that prevents you from driving or driving hard
If these guys end up not being able to keep their belts on the pulleys and/or can't get the air temps under control to make the higher psi worth it, then they haven't reached their "sweet spot" where their setup works well
Old Feb 11, 2008 | 01:27 PM
  #368
booger's Avatar
booger
11psi isn't very high, but it was 12psi before I swapped out my crawford cats and nismo exhaust for AAM cats and APS exhaust with X-pipe
and yeah I'm not pushing anything on my setup except my whp. I try to make damn sure I'm not bringing anything close to the point of failure. I'd rather overcompensate than under compensate on the parts that keep things reliable.
There are a few 1/4 mile tracks around your town . Take it to one of them and run your car hard . Then we will see how hard you are pushing the whp . Like Jeremy Tibb's said.....TRAP SPEEDS DONT LIE !!!!!!!!
Old Feb 11, 2008 | 01:29 PM
  #369
sentry65's Avatar
sentry65
the burninator
someday I might when I run my friend for fun when he fixes up his 240Z, but why do I need to prove myself to you?
What do you know about the tracks around me? Do you know how they compare to other tracks around the country?
besides, I don't see you running any 1/4 mile times with your T-trim cog setup either...
I've posted dynojet and dynodynamics dynos on this site.
You've posted a low res hard to read mustang dyno like 2 years ago, but nothing recent with your T-trim or cog setup
Old Feb 11, 2008 | 01:38 PM
  #370
booger's Avatar
booger
You dont
BUt you keep expecting us to believe you have 477whp with 11psi . Take it to the track and prove you have it . A dyno queen dyno sheet doesnt mean squat . Any one of us could put the car on the dyno . put in C16 race gas and add a bunch of timing for a few runs and get a huge number . But never run that same set up HARD on the street or the track because it wouldnt last long on a stock motor . Someone that ran a T-trim that SAM tuned proved that...didnt they ?
Old Feb 11, 2008 | 01:42 PM
  #371
booger's Avatar
booger
Ummm lets see....Ive never been finished with my set up to even think about it . The one 1/4 track we had closed . The nearest 1/4 mile is [ I think } 250 miles away in KC .
Old Feb 11, 2008 | 01:48 PM
  #372
sentry65's Avatar
sentry65
the burninator
Take it to the track and prove you have it.
how does proving it benefit me?
A dyno queen dyno sheet doesnt mean squat . Any one of us could put the car on the dyno . put in C16 race gas and add a bunch of timing for a few runs and get a huge number.
what are you saying?
Do you really think I was running C16 gas with my $600 cats with the labor I spent having A/F bungs welded in them?
Sam already pushed my timing as far as it could go to the point that I was losing power if he added any more. I was running 96 octane and water/meth when he did that tune.
C16 wouldn't benefit me much since I wasn't detonating.
I guess my word and Sam's word aren't good enough...
I will track the car someday on a road course, but I won't go about doing it the same way Diesel350 did without water/meth injection. I won't use my aggressive map and we already know I'm running 11 psi instead of 13 like he was
My car is mostly driven on the street as it turns out. Why does it need to be "proven" at the track?
tracking is so expensive. I'd kinda rather spend the money on other things than to get respect or whatever from people over the internet
Old Feb 11, 2008 | 01:50 PM
  #373
iStan's Avatar
iStan
ZR
SOOOOOOOOOOOOOOOOOOOO. I wonder what Paul is up to now.
Old Feb 11, 2008 | 01:54 PM
  #374
booger's Avatar
booger
how does this benefit me?
Do you think I was running C16 gas with my $600 cats with the labor I spent having A/F bungs welded in them?
guess my word and Sam's isn't good enough for you, that's fine. I don't care
I will track the car someday on a road course, but I won't go about doing it the same way Diesel350 did without water/meth injection and I won't use my aggressive map.
I consider road course work kinda like jogging and 1/4 mile racing more like running. My aggressive map is for when it's cooler weather or if I did run at the drag strip. In the summer or on a road course, it's going to be my lower power map
Putting your car on a 1/4 mile doesnt cost squat and it proves your whp.....and as you say ' someday ' it will never come . TRAP SPEEDS DONT LIE !!!!!
Old Feb 11, 2008 | 02:00 PM
  #375
sentry65's Avatar
sentry65
the burninator
this is sounding like a broken record
no the drag strip doesn't cost all that much
I have a reasonable idea of the ballpark I'd trap at based on the other vortech trap speeds listed on this site.
That's about as much as I care about the drag strip.
but a road course isn't cheap where the entry fee is around $150 a day, then there's the race gas you'll use throughout the day doing laps, then tire and brake wear, changing clutch and brake fluid, engine oil, etc and yes, the possibility (as always) that I might blow the engine.
I used to take my NA modded Z on road courses - I know how expensive it was even for being NA...FI would be even worse. I'd honestly just rather pay $400-500 at Bondurant Racing School and drive one of their Z06's around the track all day with their track insurance knowing at the end of the day I can just walk away from it all while my Z is still in perfect running condition with nothing needing to be replaced, fixed, or adjusted
I built my car for me to have fun driving it, not to prove anything on a forum
If "someday" never did come, so what?
Even you said I don't need to prove myself to you
So why is it I need to get to the drag strip to "prove" my whp to you?
edit:
sorry for the off topic
as always, booger and I can't occupy the same thread...
Old Feb 11, 2008 | 02:02 PM
  #376
iStan's Avatar
iStan
ZR
Old Feb 11, 2008 | 02:59 PM
  #377
Hexxum001's Avatar
Hexxum001
As others have said.....Sam seems to only tune late at night after hours . I dont think its because his Mech.'s dont like the noise . Loud exhaust's comes with working at a performance shop and to expected .
I can tell you another reason why Sam prefers tuning after hours, from being at the shop and from him telling me. During work hours, he gets interrupted so many times that it is almost impossible for him to finish tuning a car in a reasonable amount of time. After hours, the phones don't ring and he can concentrate better on tuning.
Old Feb 11, 2008 | 03:11 PM
  #378
booger's Avatar
booger
edit:
No one really cares what it cost to run a day at a road course . And a road course proves nothing other than if you are a good road course driver . A 1/4 mile proves your cars whp .
And yes...SORRY for getting off topic ! I think it started with
" <TABLE class=tborder cellSpacing=1 cellPadding=6 width="100%" align=center border=0><TBODY><TR title="Post 5161708" vAlign=top><TD class=alt1 align=middle width=125>sentry65</TD><TD class=alt2>yeah just getting into the sweet spot of a setup with a combination of mods is the trick. Once there, it's smooth sailing</TD></TR></TBODY></TABLE>
which had nothing to do with a SI trim or getting it to work
Old Feb 11, 2008 | 03:18 PM
  #379
sentry65's Avatar
sentry65
the burninator
" <table class="tborder" align="center" border="0" cellpadding="6" cellspacing="1" width="100%"><tbody><tr title="Post 5161708" valign="top"><td class="alt1" align="middle" width="125">sentry65</td><td class="alt2">yeah just getting into the sweet spot of a setup with a combination of mods is the trick. Once there, it's smooth sailing</td></tr></tbody></table>
IMO it completely was on subject
I was trying to encourage him that even though it's tough now, once he's over the hump and gets everything working right, things will get easier since he sounded a little discouraged and mentioned going TT
and later calling me out to "prove" my whp to you with a drag strip time...
apparently you have this need to laugh at everything I say
Read the new FI rules please...
https://my350z.com/forum/forced-induction/309144-fi-forum-conduct-it-s-best-that-you-all-read-this-updated.html
Originally Posted by Wired 24/7
Classically, and even more-so lately, this forum has been full of hot-headed debates, name calling, bashing, and playing the victim.
Constantly, underhanded comments meant to rile up certain individuals are posted, and there have been far too many uncivilized comments posted on behalf of many members and sponsors. Not to mention there has been an epidemic of "calling out" certain individuals.
either way Booger, we've each said our piece, took up a whole page worth of posts, and so we really should just stop talking to each other in this thread...
Old Feb 11, 2008 | 03:28 PM
  #380
booger's Avatar
booger
NO...you took up a whole page with your foot long post's . I dont need that many words to get my points across .
