Daily drivers with FI...
Old Feb 6, 2008 | 01:13 PM
ChrisCJ99's Avatar
ChrisCJ99
Default Daily drivers with FI...
So I'm considering going FI with a turbonetics single turbo setup on my 05 Z with 25K miles. I've been doing research for months now and I'm trying to get ALL the info I can before I make this BIG investment. I would like all the Z owners that have FI on their daily drivers to comment here PLEASE!
What is the most common problem that a daily driver with FI will experience?
(clutch? brakes?) I'm just trying to gauge what I can expect and how much it will possibly be...
I'm already aware of the AC lines that get fried with the turbonetics kit, that's why I'm having my AC re-routed and fire-wrapped at Z-Fever in tampa IF and WHEN I go FI
Thanks for the input!
Old Feb 6, 2008 | 01:22 PM
eltness350's Avatar
eltness350
The Untouchable
no offense man but the noob patrol is comin your way...just keep searchin the f1 forums...this topic has been beat up like a $2 *****....
Old Feb 6, 2008 | 01:28 PM
ChrisCJ99's Avatar
ChrisCJ99
Trust me, I have searched. I've seen things here and there, but I mainly wanna know what the MOST common problem seems to be for people driving DAILY with FI... I was hoping this could help people in the same boat as me with the same curiosities
Old Feb 6, 2008 | 01:39 PM
Blu_Blur's Avatar
Blu_Blur
The Z isn't my daily driver but it is still a great car for daily driving with my TN set-up.
The only major factor is how hard you drive the car. If you beat the **** out of it everyday, it won't last that long. If you drive normally, it feels like a normal Z as you need to get into boost in order to go really fast.
Old Feb 6, 2008 | 01:40 PM
iStan's Avatar
iStan
ZR
Tickets.
/thread
Old Feb 6, 2008 | 02:12 PM
k3silk's Avatar
k3silk
I have the jwt tt kit and Its not as bad as you would think. Just need to change your oil and plugs drive it and not beat the fuc out of it and you should be fine. just be ready to build a motor or replace a clutch at anytime because you never know what can happen.
Old Feb 6, 2008 | 02:16 PM
98intrigue's Avatar
98intrigue
I have 83k miles on my 2004 G35 with 20k miles boosted in the past year, since PF put on my TN kit last February.
The problems to date:
-AC has been out since the install...could have been due to using a friends used TN ac line
-Innovate wideband E2 code since August.
-Melted a whole in my lower radiator hose this past Saturday and just replaced it yesterday and the car is running fine.
Reliability is all in the tune and how you upkeep your car. I'd highly suggest taking it to PF to have Jeremy give you a rock solid tune.
Old Feb 6, 2008 | 02:20 PM
ChrisCJ99's Avatar
ChrisCJ99
I don't plan on beating on the car hardly at all... Just occasional "spirited" drives. But I'm only planning on running a MILD and conservative tune (the out of the box ECU flash that comes with the kit)
Old Feb 6, 2008 | 02:24 PM
iknowitsfast's Avatar
iknowitsfast
To add on to this. If you get a TN kit, does your engine suffer When you are NOT in boost? What I mean is...when youre is not flooring it, do you still suffer the risk of the engine blowing? I would think as a daily driver you would be extra cautious....well, only if youre on a stock engine.
Old Feb 6, 2008 | 02:29 PM
phunk's Avatar
phunk
CJ Motorsports
if its your only car, the biggest draw back will be the insecurity you will face every day as your wait for the engine to eventually blow up unless you take it to a very very good installer and tuner.
Old Feb 6, 2008 | 02:31 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
just be prepared just in case to replace/build your motor
Old Feb 6, 2008 | 02:33 PM
Alberto's Avatar
Alberto
Cranky FI Owner
BOOM-theflash is garbage, keep reading. Get ready for a rebuild or a stock block replacememnt + labor. Either way its not cheap!
1 2 NV's Avatar
1 2 NV
I have had my TN kit on my car since June 2005......I think....has it really been that long? lol Any matter, it is my primary vehicle. The only problem I have had was the A/C line. But the last time I had that problem all I had to do was give Reggie a call and he sent one right out. Keep in mind I was still with in my one year warranty. So that just goes to show how long ago I had the problem and that it is possible to have A/C and the TN kit. You just have to be a little creative when routing the A/C line! Now to answer your daily driver question......you can drive your car without ever getting into the boost. Its not like you are constantly in boost because you have a turbo on your car. As long as you drive your car conservatively you wouldn't be able to tell you have it. But, all you have to do is push down a little more and your off. Just think of your gas pedal as a dimmer switch....I know it sounds weird but the more and faster you push it down the more and quicker you will get into your boost!!!!! Have fun, but be smart!!!
Old Feb 6, 2008 | 02:36 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
+1 U will be fine just put extra money on a jar every pay check just in case
Old Feb 6, 2008 | 03:23 PM
ChrisCJ99's Avatar
ChrisCJ99
Really???? How is the reflash garbage?? Hmmm. I will read on this too, which I've already tried looking into it. But why would turbonetics sell a flash that it possibly FATAL to your engine??? I understand that you don't have the luxury of being able to fine tune your engine, as you could with an UTEC, but I'm not going for BIG numbers. Just something SAFE. Sure the UTEC is safe also, but it pushes the turbo a little harder to get more performance (which is GREAT if that's what you want - more power - but I would be more than happy with 360 whp)
Thanks for the input guys! Keep em coming!
Old Feb 6, 2008 | 03:26 PM
2004Black350z
Exhaust Whore
same reason why Greddy gives the the emanage blue. They dont care lol
Old Feb 6, 2008 | 03:35 PM
sentry65's Avatar
sentry65
the burninator
a reflash can't account for variable boost levels. It's a compromise that will lead to certain conditions briefly running too lean and others briefly running too rich
for instance going WOT at 2500 rpms and hitting 8 psi at 3500 rpms vs starting at 3500 rpms then going WOT which initially starts out as 0 psi then hitting 8 psi later at 4000-4200 rpms.
You're going WOT at 3500 rpms in both situations, but they're going to require drastically different A/F ratios since the psi is different
The ECU can only understand 0-100% throttle positions at 3500 rpms. It can't understand what boost pressure is because it's not a turbo ECU to begin with with no psi input going into it.
The UTEC can only account for 2 out of 3 variables too and most tuners use boost and rpm as the variables, while 100% WOT is a fixed parameter. So you end up getting a jerk as you go from <100% throttle to 100% throttle when the UTEC kicks in
Old Feb 6, 2008 | 03:39 PM
ChrisCJ99's Avatar
ChrisCJ99
You're going WOT in both situations, but they're going to require drastically different A/F ratios since the psi is different in both situations.
Understood. Good explanation! So will these conditions be FATAL to the car, or just somewhat of an annoyance?
Old Feb 6, 2008 | 03:41 PM
2004Black350z
Exhaust Whore
cant give a exact answer bc it deals with u, car, installer, tuner, etc list goes on and on and on
Old Feb 6, 2008 | 03:44 PM
str8dum1's Avatar
str8dum1
it only takes 1 ping to bomb your motor. like has been said above, if its your DD, the only difference (barring a good install and tune) is the constant threat of something getting out of whack for a second and you needing a rental for weeks.
