4.08 final drive with vortech
Old Jun 4, 2008 | 12:20 PM
Midnight Ryderz's Avatar
Midnight Ryderz
Default 4.08 final drive with vortech
okay so im wondering what do you guys think. Should i go with the 4.08 final gears with my vortech or no. Let me know what you guys think. I know the vortech is all high end and i want the lower end power so please any info would be great thanks
Old Jun 4, 2008 | 12:22 PM
savvy's Avatar
savvy
What are you putting down for power? What is your redline? Do you already have traction issues?
gothchick's Avatar
gothchick
I think traction would be a problem.
Old Jun 4, 2008 | 12:28 PM
My350P's Avatar
My350P
Probably a terrible idea, since you would be bouncing off the rev limiter constantly. FI is generally better suited for lower ratios, not higher.
Old Jun 4, 2008 | 12:49 PM
SlideFox's Avatar
SlideFox
I miss Scranton, PA!!
Sorry for the OT!
Old Jun 4, 2008 | 01:00 PM
UMW350Z's Avatar
UMW350Z
Michael Scott@Dunder Mifflin Tuning should have all your answers...
But seriously...it depends on the power...if you are only going to do about 350 or less to the wheels, might not be a horrible idea....why not crank up the boost and buy a better LSD instead?
Old Jun 4, 2008 | 01:01 PM
sentry65's Avatar
sentry65
the burninator
not in the case of vortech - speaking from experience. You'd want a lower FD if you had close to 500 whp or more with a turbo setup
IMO I would do it only if you get some serious tires and stay under 420whp
Old Jun 4, 2008 | 01:04 PM
Midnight Ryderz
okay thanks guys anyone else let me knwo i want to hit low 12's in the quprter so
Old Jun 4, 2008 | 01:53 PM
05Z33's Avatar
05Z33
I say go for it. That's what I'm saving up for next. I'm thinking 3.9 or 3.7 for my setup with a Quaife LSD. As long as you know how to launch I can't see you having bad wheel spin.
Old Jun 4, 2008 | 07:39 PM
mafoor's Avatar
mafoor
I still currently have the stock 3.33 pulley and installed the 4.08FD and it feels so much better. Currently i have my stockies on with crappy tires and the only traction issues i have is in first gear and when i slam second. The car pulls so much harder in every gear. Just my 2 cents
Old Jun 4, 2008 | 08:39 PM
350Z400rwhp's Avatar
350Z400rwhp
I am thinking about a 3.9 or 4.08 gear too. The only reason I am hesitant is the bpv and highway driving and the fact that 4th gear goes to 114mph on the stock 3.5 gear which is about perfect for a mid to low 12 second run. I wonder if the extra shift to fifth would counter the quicker acceleration.
Old Jun 5, 2008 | 05:27 AM
jouvert00's Avatar
jouvert00
I was considering a FD swap as well i think the 3.7 would be better suited for the vortech.
The stock 3.5 isn't really that bad i'm trapping 113-115mph with my set up as is.
Old Jun 5, 2008 | 12:22 PM
Midnight Ryderz
thanks for all the info when i get it done I will let ya all know and post some et's
Old Jul 18, 2008 | 01:52 PM
Titan0385's Avatar
Titan0385
I have been debating the 4.08 swap.. I figured the lower the gears, the quicked into boost we get..
I did a gear swap in my 57 Chevy (semi-stock SBC 350).. and went from mid 15s to high 14s.. I cant wait to test my new motor (8000RPM SBC 500+hp) with 4.56s..
If traction is an issue at the track, throw on some drag radials or street slicks.. Goodyear and Nitto have a pretty good setup.
Old Jul 18, 2008 | 07:24 PM
str8dum1's Avatar
str8dum1
i get crappy gas mileage as it is, i can not imagine basically losing an entire gear (6th is as tall as 5th etc). I'd consider a 3.7, but 4+ is pretty short.
for less money, a nitrous kit is a better compromise between street and track.
Old Jul 19, 2008 | 08:12 AM
Fletch69z's Avatar
Fletch69z
I have the 3.9's and I have traction issues through 2nd and sometimes into 3rd depending on how hard I get on it. I am going to Vortech this winter and I'm really concerned about traction. I am kind of wishing that I had kept the stock gears so that I'm not constantly bouncing off of the rev limiter when I go SC. I only have the below mods so with a SC it's going to be interesting, .
Old Jul 19, 2008 | 08:18 AM
sentry65's Avatar
sentry65
the burninator
shorter gearing will hurt you if you don't run good tires.
I use a 3.9 with a nismo LSD, and I run 295 R-compounds, eventually switching to 305's. I wouldn't even remotely consider shorter gearing whatsoever if you don't run some decent grippy tires. Too many people run small casual street tires and still expect traction with shorter gearing...
that said, I still think the 4.08 is probably too short unless you're under 400whp or unless you run some insane R-compounds or slicks
Old Jul 19, 2008 | 10:09 AM
__jb's Avatar
__jb
Z + Rear Seat
Would be pretty cool with a set of 28" drag radials...
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
350z82
Oct 1, 2015 06:25 PM
