Got a problem!!! My freshly built Z is overheating and spewing antifreeze
Old Aug 9, 2008 | 04:31 PM
craigo'sznprgrs's Avatar
craigo'sznprgrs
Exclamation Got a problem!!! My freshly built Z is overheating and spewing antifreeze
I hotlapped the car at the track last night, with ZERO issues and today, I take it to the store less than 2 miles round trip and she starts to overheat.
When I get it back to check it out, there is antifreeze everywhere and the overflow tank is completely full??? Its kind of dark, so I can't see if a coolant hose broke, but I could check in the morning, is that a possible issue?
Anything else to look for? The car didn't overboost, or overheat past 3/4 gauge, any suggestions? I need some help, anybody?
Craig
Old Aug 9, 2008 | 04:55 PM
craigo'sznprgrs
Here are some crappy quick pics:
Old Aug 9, 2008 | 05:00 PM
Nathan's Avatar
Nathan
Do the full purge refill outlined on another post.
Overflow tank won't be full with broken coolant hose's
Are the fans turning on ?
SnyperZ's Avatar
SnyperZ
Check for oil in the coolant or coolant in the oil!
Old Aug 9, 2008 | 05:12 PM
craigo'sznprgrs
No oil in the coolant or coolant in the oil, thank GOD!!!
Keep the suggestions coming!
Old Aug 9, 2008 | 05:17 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Compression test
Old Aug 9, 2008 | 05:20 PM
UMW350Z's Avatar
UMW350Z
compression test???
Old Aug 9, 2008 | 05:37 PM
westpak's Avatar
westpak
SFZCC
compression and more importantly leakdown
if you have a headgasket issue that is how you will see it easier, that much fluid coming out is more than simple air in the system more like combustion getting into the cooling system, been there done that have the t-shirt when my sleeves were done incorrectly
Old Aug 9, 2008 | 05:54 PM
r0mey's Avatar
r0mey
+1 with what he said.
But i can tell you now you have a problem
Old Aug 9, 2008 | 06:00 PM
craigo'sznprgrs
Any volunteers?
that sucks, I bought all the best parts including the L19 bolts, arp everywhere!
And to boot, my shop closed, well it looks like I may be screwed! Forged, if they are willing, I would love to have a little rehab, and perhaps, it won't be as bad as it sounds.
Craig
Old Aug 9, 2008 | 06:18 PM
westpak's Avatar
westpak
SFZCC
well I hope it is not bad but I battled spewing coolant for 2 months hoping it was air in the system until a leakdown delivered the verdict
unfortunately you can use the best parts available but that is only half of it the other half and most important is the building itself, like in my case the machine shop botching the sleeve install. GL
Old Aug 9, 2008 | 06:57 PM
craigo'sznprgrs
So true.
I am going to try and pressurize the coolant system tomorrow, buddy told me to try that, and if I can't find a leak, then a leak down is next.
I am not sleeved, if that is any consolation?
Old Aug 9, 2008 | 07:28 PM
westpak's Avatar
westpak
SFZCC
well only that you didn't spend as much
pressurizing the cooling system wont be the final answer if it is a headgasket issue, you can only pressure it so much and mine passed without a problem, when you do a leakdown you pressure it a lot more and will find the smallest leak
you have to realize that the combustion pressures are a hell of a lot more than cooling system pressures and will expose the smallest of leaks
Old Aug 9, 2008 | 07:47 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I will give you a call on Monday. Looks like you probably have a head gasket issue. The cause of it....TBD.
Old Aug 9, 2008 | 08:27 PM
rcdash's Avatar
rcdash
Sorry to hear - hope for the best! FP will take care of you - lucky to be nearby. Definitely sounds like HG issue.
Old Aug 9, 2008 | 10:08 PM
rr_z33's Avatar
rr_z33
you should check the overflow bottle and you can see little black stuff in there. also test your thermostat. those are easy ways to check for headgasket issues. if its your headgasket then your turbos are toast as well and will have lots of shaft play. peices of headgasket in the exhaust dont do so well for your turbos. i learned this by experience.
Old Aug 10, 2008 | 04:46 AM
r0mey's Avatar
r0mey
I agree with sharif that he has some kind of headgasket issue. Ive seen people go thru the same thing and at the end of the day it was a headgasket issue. I wish you the best my man and im sure FP will help you out
Old Aug 10, 2008 | 05:19 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Hope it aint to bad, and everything works out.
Old Aug 10, 2008 | 05:36 AM
craigo'sznprgrs
Thanks man.
I spoke to a friend who is a mechanic at local dealership, and Im hoping that he is right. His main concern was whether or not the car was missing or running rough (and definatively it wasn't), so he thinks that the problem lies somewhere in the coolant system.
Thanks, look forward to speaking with you.
Old Aug 10, 2008 | 07:55 AM
350Z400rwhp's Avatar
350Z400rwhp
It could be a bad radiator cap. Another thing you can do is take the rubber hose that goes to your overflow tank and put that in a clear plastic bottle filled with water. Start your engine and see if it makes bubbles. This would indicate one of two things. 1. Your head gasket is bad and air is entering into your coolant system. or 2. You have a bad radiator cap. I would also check your radiator fans as your radiator may of been able to cool when you were going fast around the track but not at slow speeds around town. Not sure if there are two fans in our cars but if one isn't working it will cause the car to overheat sitting in traffic. The only good sign is that you don't have oil in your coolant (Still could be a head gasket though) so just maybe it is the radiator cap.
