Powerlab 37r install begins tonight..
Old Aug 25, 2008 | 09:33 AM
  #101
rcdash's Avatar
rcdash
Originally Posted by SnyperZ
Well, I have to remove most of the turbo system again because the downpipe MUST be wrapped to stop the interior vibrations. Theres absolutely no way that the downpipe doesn't touch the side of the car. Also upon start up (stock ecu just to get it going) I get these codes
P0152-02 sensor bnk2 sens.1 Hi volts
P0101-MAF A CKT Range/perf
P0102-MAF A Low input
P0103-MAF Hi Input
P0113- IAT Sensor 1 Hi input
P0132-02 sensor Bnk1 sens1 Hi volts
P0102 MAF Low input(same code twice?)
P0113 again.
Any ideas on any of these let me know. Also, im getting a weird chirping noise coming from the passenger side..sounds like it might be coming from around the waste gate area..only on decel...gotta love growing pains.
Did you remove the MAF (sorry not familiar with the kit)?
With my MAF removed, I used to get a P0101 - so that's normal. You should wire the Haltech AIT temp sensor (if you bought one to remove the MAF), through the MAF wiring and that will get rid of the IAT code. Hal has wiring instructions.
I have never gotten any of the other codes and I kept a list over a period of 3 months.
Old Aug 25, 2008 | 11:55 AM
  #102
SnyperZ's Avatar
SnyperZ
I reset all the codes and havent had one back yet..so it was prolly something I did.
Old Aug 25, 2008 | 12:32 PM
  #103
SlideFox's Avatar
SlideFox
Soooooo... any heavy driving yet or are you still getting everything together??
I'm still waiting on the Doug vs. SnyperZ race!!
Old Aug 25, 2008 | 01:06 PM
  #104
UMW350Z's Avatar
UMW350Z
almost sounds like a small rattle?
I wouldn't say rattle...i hear a hissing from the passenger side from the wastegate partially letting out exhaust gas when the gas is built up (usually on decel higher than 4k rpms.
if it is a rattle, check under the car when someone revvs it....that should be a good test to.
PS...after my retune, when i give it a good rev, it the BOV sounds off....does yours do that? mine didn't do it before it was retuned.....so cool BTW
Old Aug 25, 2008 | 01:18 PM
  #105
SlideFox's Avatar
SlideFox
wooooooooosh
Old Aug 26, 2008 | 06:29 AM
  #106
Driver06's Avatar
Driver06
Looks good, cant wait to see some numbers man...
As far as Doug vs snyper, I think thats a bit of a stretch.
What about Driver vs snyper We both have stock motors, for now..
Old Aug 26, 2008 | 06:56 AM
  #107
doug's Avatar
doug
lol.. how did i miss this.. by the time he got to 100 mph i would be coming back down from 160mph .. lol
Old Aug 26, 2008 | 07:01 AM
  #108
SlideFox's Avatar
SlideFox
Old Aug 26, 2008 | 07:19 AM
  #109
IIQuickSilverII's Avatar
IIQuickSilverII
doug, slidefox(mike) is talking about your Z, not your rsx
Old Aug 26, 2008 | 07:47 AM
  #110
SnyperZ's Avatar
SnyperZ
lol...with the 350z maybe...I still have my LS RX-7. =)
Old Aug 26, 2008 | 07:54 AM
  #111
IIQuickSilverII
GET THAT VIDEO UP ALREADY!!!!
you car sounds FACKING SICK!!!!!!!!!!!!!!!!
Old Aug 26, 2008 | 08:40 AM
  #112
doug's Avatar
doug
i still have my GSX-R 1000
Old Aug 26, 2008 | 08:41 AM
  #113
doug's Avatar
doug
my Z has a nismo intake and exhaust.. but the UTEC is tuned by MRC so it might be a close race
Old Aug 26, 2008 | 08:43 AM
  #114
IIQuickSilverII
lier...i know you have the HKS dli, which added 2 seconds to your shift time and an extra 20whp too!!!
You still need to take the weed out of the trunk, its adding weight
Old Aug 26, 2008 | 08:50 AM
  #115
SlideFox's Avatar
SlideFox
Old Aug 26, 2008 | 08:52 AM
  #116
doug's Avatar
doug
my sub and amp's keep my car planted.. so i put power to the ground better... so i will launch better than he will.. then once up to speed.. weight doesn't matter
Old Aug 26, 2008 | 09:14 AM
  #117
SnyperZ's Avatar
SnyperZ
if its stock or semi stock..im still not worried. =) I beat my friends 06 1000. He only has exhaust though.(no header)
Old Aug 26, 2008 | 09:17 AM
  #118
SnyperZ's Avatar
SnyperZ
Haha, yeah ill get a vid up. Im going to race my brothers EVO. We've been testing the effectivness of our mods. When we were both BONE stock..I beat him by a fender. Then he did cams,exhaust,few other misc bolt ons and a good tune and he raped me by 2-3 cars per gear. So tonight we are going to test it again to see how much of a difference 4psi makes. Ill get it on video.Right now I have the revlimiter set to 5500 to be safe..but everything works good so far and I had a little update from hal..so ill try a WOT against him from 2nd-4th. His car made 333awhp on a conservative tune.
Old Aug 26, 2008 | 09:18 AM
  #119
IIQuickSilverII
dont act surprised, everybody at the shop knows youve been inhaling chemicals at work
Old Aug 26, 2008 | 09:29 AM
  #120
350 Rookie's Avatar
350 Rookie
anybody wanna race a puney .77 turbo?
