vacuum problem w/ ATI pro charger
Old Aug 16, 2009 | 06:08 AM
UNDISPUTED's Avatar
UNDISPUTED
Unhappy vacuum problem w/ ATI pro charger
OK long story short I am reading boost off gauge witch is installed on back side of intake..I have a large vacuum line coming of rear of driver side valve cover.This line runs across front of intake the leads into a vacuum "T" I believe this "T" is supplied by ATI. This connects to surge valve and fmu. I have no vacuum at the "T" or fmu . please help Is this vacuum line considered part of crank case vent? could i relocate my vacuum line to front of intake without the "T"?
Old Aug 16, 2009 | 07:35 AM
bb1314's Avatar
bb1314
da Terminator!
Snap a picture.
Old Aug 16, 2009 | 10:33 AM
UNDISPUTED's Avatar
UNDISPUTED
Default ati vaccuum problem
vacuum problem w/ ATI pro charger-imgp0193.jpg This is the so called "t" it sets on passenger side in front of intake connect to surge valve and fmu.
It runs across frontover to driver side and to back of valve cover by firewall vacuum problem w/ ATI pro charger-imgp0131.jpg cant get pick of connection but by firewall
Old Aug 19, 2009 | 01:28 PM
Boostedtrack350's Avatar
Boostedtrack350
I also have an ATI Procharger. Forged removed that "T" and replaced it with a vaccuum line distribution block. That "T" was causing me to lose fuel pressure. Give Forged a call.
Old Aug 19, 2009 | 02:23 PM
failsafe306's Avatar
failsafe306
I don't like the sharp angles of those vac lines at all.
Old Aug 20, 2009 | 07:25 PM
brotus's Avatar
brotus
I used a vac distribution block that I ran my bpv, utec map, and boost gauge from.
Here are some pics on how I ran them:
http://g35driver.com/forums/members/...arger0009.html
http://g35driver.com/forums/members/...arger0003.html
Old Aug 20, 2009 | 11:51 PM
UNDISPUTED's Avatar
UNDISPUTED
The line he shows in pic is correct.But my problem is I have no vacuum to the "T".I noticed that my fmu was not lighting up while trying to make adjustment.I have no vacuum to fmu under load.I also have no vacuum at "T" at idle.
Old Aug 21, 2009 | 05:11 AM
brotus's Avatar
brotus
Try hooking up your vac line to the passenger side front of the plenum where there is a nozzle that extends out. The stock line that should have been removed from that location will then be routed back across the plenum to the larger line that came off the drivers side valve cover ( crankcase vent ). From there you will "T" it and run a open uncaped line into front of the blower. Also make sure all your connections are secure to avoid any leaks. Hope this helps.
Old Aug 29, 2009 | 04:15 PM
UNDISPUTED's Avatar
UNDISPUTED
Default your correct
Just thought i would follow up with a thanks you nailed it !!!
Old Aug 30, 2009 | 04:41 AM
brotus's Avatar
brotus
I'm glad to hear you got everything squared away. GL with the rest of your project.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
GaryK
Dec 31, 2003 01:00 PM
12SecZ
Aug 21, 2003 09:34 AM
12SecZ
Aug 21, 2003 06:58 AM
12SecZ
Jul 16, 2003 12:12 AM
