My Greddy TT Build, the build to prove you can make high #s without going broke...
Old Mar 27, 2010 | 11:57 PM
  #121
accordfreak's Avatar
accordfreak
just wondering, are you running a surge tank with the inline? Is a walbro 255 inline as efficient as the bosch 044? are you also modifying the stock FPR? I'm trying to figure my own fuel setup. thanks
Old Mar 28, 2010 | 04:39 AM
  #122
jtgli's Avatar
jtgli
Im not running a surge tank before the Bosch. Ive seen this setup done many times over again on other cars with no need for the surge tank. This will be a street car seeing 0 track time, so the need for a surge tank I dont think is really there. However if I ever run into any problems with my setup, its right there and all I need to do in fab up a tank real quick. For now though Id like to see how this setup works as is. There is no OEM fpr, that got deleted with the AAM basic return kit. As per the walbro being able to keep up with the Bosch, this was a concern of mine as well. After talking with a few local people, including blinkerfluid, its seems that the walbro will be alright feeding the Bosch, and that there shouldnt be a "scavaging" affect on the pump. Again this is a new setup that as far as I know has never been done before so we'll see what happens. If it does work though, it'll be a great alternative to those pricey dual and triple intank setups.
Old Mar 28, 2010 | 04:45 AM
  #123
GreenGoblin's Avatar
GreenGoblin
looking good, cant wait to see more.
Old Apr 5, 2010 | 07:06 PM
  #124
Cass007's Avatar
Cass007
BUMP
Heard a rumor it is almost ready for paint. Pics or it never happened
Old Apr 6, 2010 | 01:23 PM
  #125
jtgli's Avatar
jtgli
As requested:
Havent taken any since I put the front back on it yet....
Old Apr 6, 2010 | 02:06 PM
  #126
Vas_Z33's Avatar
Vas_Z33
sweet!!! maybe i missed it but are you going with the same color paint? or changing it?
Old Apr 6, 2010 | 04:50 PM
  #127
jtgli's Avatar
jtgli
Same paint, its really just the front of the car being redone after 3 years of dings and rock chips.
Old Apr 23, 2010 | 09:21 AM
  #128
Cass007's Avatar
Cass007
Update dammit
Its like pulling teeth to get info on this build
Oh... and pics or it never happened
Old Apr 23, 2010 | 08:53 PM
  #129
Teufel's Avatar
Teufel
What do you plan on doing with your 7? I passed with an 86% while working 60hours a week.......yuck!
Old Apr 25, 2010 | 06:32 AM
  #130
jtgli's Avatar
jtgli
I work at a franchise branch of Ameriprise Financial. I am now currently studying for my Series 66 and Life & Health exams. Once I have those past in the next month or so I will be a cerfitied AFA (Associate Financial Adviser) and will being sitting in on meeting and seeing prospects and new clients....aka Cass007 *cough* lol.
Also I have an update!
The car runs!!!!! We started it up last weekend and it fired right up without a hitch. It was one of the most rewarding moments Ive ever had. The motor sounds great, has no leaks, and for being off on the tune now, idles pretty decent. Here's a pic of the finished motor:
Now onto my only problem. My clutch pedal wont return! I have no clue what is wrong and Im about to go crazy trying to solve this issue. The pedal will get pressure for the 2nd half of the swing/motion but uptop it is almost non existant/mushy. I replaced the slave cylinder yesterday and still no luck. I am today going to replce the clutch line and the master cylinder. Hopefully they will do the trick. If not then I dont know wtf Im going to do. Has anyone ever had this issue before? For reference I am running an RPS Max 6 puck clutch from a 300zx and matted it to a JWT flywheel. And before anyone says Im running the wrong clutch, IT WILL WORK ON THE 350z, and was recommended this clutch from Kyle @ IPP and spoke to Shariff about this clutch also before ordering it was he as well has ran it on a 350z before. So does anyone have any ideas how to fix this?
Old Apr 25, 2010 | 07:05 AM
  #131
Alberto's Avatar
Alberto
Cranky FI Owner
Nice gold foil touch, I had the same setup on my charge pipe and intake pipes....you do have brake fluid right?
Old Apr 25, 2010 | 07:08 AM
  #132
Cass007's Avatar
Cass007
I did most of that work .... OCD has its advantages . Jon knew he was copying your style on that, but he just fell in love with the look.
Can't wait to see this tuned and running strong.... its gonna be a fun summer, usually our cars aren't up at the same time. Hustle up though, the clock is ticking on the airstrip/ZdayZ/carlisle events.
Old Apr 25, 2010 | 07:15 AM
  #133
Alberto's Avatar
Alberto
Cranky FI Owner
I took it off my charge pipe cuz too many people started copying it! Thats what I get for answering PM's on where to get it
In all seriousness I could care less, the gold is hot.
Old Apr 25, 2010 | 07:28 AM
  #134
JET MECH's Avatar
JET MECH
I have been running that exact same clutch setup now for 5 years and have had no problems with it what so ever " SAME HERE KYLE RECOMMEDNED IT TO ME" . pedal feel is pretty hard and the friction point is very abrupt but you get used to it rather quickly. I had the same problem that you are explaining with the soft pedal at the top. I just kept on bleeding it continualy till the air was worked out!! took me around 45 minutes of continual bleeding to get all of the air out. Did you install a new throw out bearing and lubricate inner diameter of the bearing before sliding it on the output shaft? Does the shift fork have play in it still with the clutch fully released?
Old Apr 25, 2010 | 07:35 AM
  #135
binder's Avatar
binder
sounds like air. I replaced the master and the slave on my car and it ended up being air.
It takes FOREVER to bleed ours. The best thing to do is make a pressure bleeder and pressure bleed it from the slave cylinder backwards. That will push air up out of the res which is where wants to go (up).
You can use a small little pump oil can with a hose attached to it and the slave cylinder nipple to backwards bleed it. It will work easily and fast.
Old Apr 25, 2010 | 07:55 AM
  #136
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Engine bay looks great!
Old Apr 25, 2010 | 09:02 AM
  #137
jeffie7's Avatar
jeffie7
My cousin does powder coating.... Maybe one day I'll do my charge pipes redline red just to be different.
Old Apr 25, 2010 | 11:13 AM
  #138
Vas_Z33's Avatar
Vas_Z33
you guys wanna share where you got the gold wrap from =)
Old Apr 25, 2010 | 11:42 AM
  #139
Chris@FsP's Avatar
Chris@FsP
A quick Google search turned this up: <a href="http://www.hrpworld.com/index.cfm?form_prod_id=5325&action=product">Gold Heat Reflective Tape</a>
Old Apr 25, 2010 | 01:40 PM
  #140
Cass007's Avatar
Cass007
I looked here... but didn't find it
http://www.pimphats.com/
