Need suggestions on an oil cooler
Old May 23, 2010 | 07:55 PM
  #81
binder's Avatar
binder
Originally Posted by 05Z33
No that's cool, no offense taken. I knew it would get me to operating temps sooner. I just thought that once I got to those temps; I would stay there without a T stat. Correct me if I'm wrong, but if I were driving around town in say 45 degree weather and my oil temp was 170. Could my oil temps drop to an unsafe level without the Tstat? I'm guessing highway cruising at that temp could cause your oil temps to drop with an oil cooler?
yes it could. That was where i was going with the whole thing.
Like this spring. On my way back from chicago my coolant temps were around 180*. It was in the upper 40's during this night drive. My oil temps were down in the 140's and that was without a cooler installed. So with a cooler it would probably be 20 degrees colder at least on the highway.
I was surprised to see my oil temps that low but that's where it was. Usualy highway during the daytime (60's here in the spring) i don't see more than 160 deg. So basically with that thermostat i would be driving it like i didn't even have it but then once i start banging through the gears and the temps go above 160 the thermostat would start to open and the cooler would take effect.
Right now at 80 deg outside when i'm on the interstate my oil temps are 170's without a cooler.
The reason a track car never needs it is due to the fact that they are never going to be "highway cruising".
Old May 23, 2010 | 08:03 PM
  #82
05Z33's Avatar
05Z33
Ok, so it looks like I will be buying a Tstat oil plate. Just got to see if they make one for an oil cooler and 2 1/8 npt ports. Thanks for the explination Binder.
Old May 24, 2010 | 04:29 AM
  #83
midz350's Avatar
midz350
What would be more functional an oil cooler (13" X 5.75" X 2 " 19 R 22MM) or 36mm Koyo Radiator ?
Old May 24, 2010 | 04:31 AM
  #84
JasonZ-YA's Avatar
JasonZ-YA
both............lol...
no but for real? what do you have issues with in your climate, track side, etc???
you having high oil temp issue.........then oil cooler...
if your having overheating issues, then koyo.....
two different systems, both good upgrades if/as needed.......
if your looking to mod just to mod.....then either or......
-J
Old May 24, 2010 | 04:40 AM
  #85
midz350's Avatar
midz350
I'm running the GTM HR TT kit and will be getting my built short block hopefully later this month, never track just (isolated) highway runs and I live in the SUN lool (here it reach's 122F in summer) and I don't think I can afford them both for now so..
Old May 24, 2010 | 04:46 AM
  #86
JasonZ-YA's Avatar
JasonZ-YA
just blazing down the highway spirited driving, i would do the Koyo..............
the oil can take that lil heat for now...
-J
Old May 24, 2010 | 04:51 AM
  #87
midz350's Avatar
midz350
^^ Thanks.
Old May 24, 2010 | 08:16 AM
  #88
maXmood's Avatar
maXmood
Under Boost!
got both, GTM HD Oil cooler + Koyo 36mm rad.. tbh, money well spent on those.. and IMO, we need those for our weather (GCC countries), don't skip any of them if you can buy both.
Old May 24, 2010 | 08:33 AM
  #89
- bigc -'s Avatar
- bigc -
get the oil cooler. you'll be surprised at the difference in temps with an aftermarket oil cooler. well worth the money.
Old May 24, 2010 | 09:52 AM
  #90
binder's Avatar
binder
you can just get a racerpartswholesale oil cooler for 180$ and haev plenty left over for a radiator.
So if you buy a sensible costed item you can get both. If you buy a crazy expensive 500$ stillen kit then you can't.
easy fix.
Old May 24, 2010 | 11:52 AM
  #91
Barnabas's Avatar
Barnabas
National Z Club President
I got mocal oil cooler from racerparts wholesale came in super fast and looks great. I will post results once its installed with my TT kit.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
