Ditched my vortech: Built motor, greddy twins, budget build: updated 9-18-2010
Old Sep 25, 2010 | 11:26 AM
  #121
Cux350z's Avatar
Cux350z
hatersgonnahate
Originally Posted by BornSlippyZ
Big props to you Op! The work on your Z looks great!
thanks man! I couldnt have done it without Alex (hotrodG35) and some help from James. The amount of time put in this project is just crazy. Between Alex and myself we have over 120 hrs combined in the swap and probably another 60 combined for the pre-swap motor prep.
Few updates:
Car was running without ac....and I knew why. I forgot to plug in the pressure cylinder at the condenser which is also harder to plug in that the knock sensor. Got that done today though and will hopefully fix the AC.
Fixed a leak/kink in the oil cooler feed lines. The fitting to the oil cooler was loose and the hose was kinked a bit. I re-tightened the fitting and repositioned the hose so I should be good to go. Hopefully this will help keep my oil temps down. Also removed the lower L shaped charge pipe and tightened the oil feed lines again. Hopefully that leak is fixed.
Swapped the windshield washer tubes so that they supply the correct windshields. Damn seals still leak like crazy though.
Wrapped the down pipes......while installed! What a pain but it needed to be done. Hopefully this will remedy some of the heat coming up the transmission tunnel.
for the future:
-Some sort of oil catch can
-aam competition 3" dual exhaust?
-3.3 VSLD
-Strut bar to clear TS hood
-Wire tuck
-Finish installing BC
-Install fans onto oil cooler
-new fender liners
Old Sep 25, 2010 | 03:44 PM
  #122
binder's Avatar
binder
where is your oil temp sensor? i put mine in the oil pan so it gets a good balance and smooth reading since the oil is all mixed around together after the turbos.
  #123
binder's Avatar
binder
oh, and have fun with oil leaks. Not to get you down but it seems like once i stop one area from leaking on my car another area decides it would be fun to have a slow leak.
Seems like i've been battling tiny leaks for over a year now. Nothing serious, but enough to be annoying.
Old Sep 25, 2010 | 03:52 PM
  #124
Cux350z's Avatar
Cux350z
hatersgonnahate
oil temp sensor is in an adapter plate right by the oil filter.
I have a few theories...
1. My undertray is removed...may allow cooling air to not reach where it should
2. Sensor is embedded in the aluminum adapter...aluminum transmits heat really well. With the turbos being so close they may be heating the metal up and giving a false reading
3. Oil cooler is mounted inverted. Not 100% sure that it is filled with oil. If it may only run slightly full then it will not be cooling efficiently
My plan:
Use one of these for my sensor
http://www.summitracing.com/parts/MRF-MP-3063/
Invert my oil cooler so it must be full to pass fluid
Fans...2 4" fans to push air through it.
Larger Core. after seeing this one installed there may be room for a taller core.
Old Sep 26, 2010 | 05:55 AM
  #125
ashtrojan2008's Avatar
ashtrojan2008
i've never had a single leak
well except for the very first start up when i installed the kit.. forgot to tighten the turbo clamp..... lol
ross
Old Sep 26, 2010 | 03:21 PM
  #126
Cux350z's Avatar
Cux350z
hatersgonnahate
I hope I dont go through that. These few have been a pita. I think with the proper fittings leaks can be eliminated.
Just checked back over the budget....ouch. Way over budget. I think i can successfully remove the "budget" from "budget build". Sucks that there is still more to do!!!
Looking more and more at Haltech as my ECU.
Old Sep 26, 2010 | 05:57 PM
  #127
binder's Avatar
binder
The cooler mounting isn't causing it to run half full. When the oil goes through those lines it has (or should have) plenty of pressure to keep the cooler full.
I never like mounting temp sensors in the oil plates. It just doesn't seem like the best place to put it. It's also oil pre-cooler so it will be a higher reading.
Your undertray being off won't keep temps up either. I haven't had an undertray on my car since i went FI over a year ago. I leave it off for ease of checking on things weekly.
My leaks are all stupid ones. I've had the oil pan off so many times for weird things, this last time i didn't wait overnight to run the engine after RTV'ing the pan. Othertimes it's like, a fitting will start leaking, tighten it and it's all good, then another one starts leaking, readjust it and i'm good for a while....it just keeps continuing like that.
Old Nov 5, 2010 | 08:03 PM
  #128
nathanwl2004's Avatar
nathanwl2004
Looks Awsome man. I'll bet your excited to have it running. You should definitely bring that beast up to charlotte sometime. I'll call first dibs on a ride
Old Nov 8, 2010 | 06:00 PM
  #129
JAM3Z's Avatar
JAM3Z
Phenom
Updates!!!
Old Nov 8, 2010 | 06:48 PM
  #130
Cux350z's Avatar
Cux350z
hatersgonnahate
Swapped in a 3.3 vsld
Exhaust arrived, awaiting install
Battery dead.....
Once I button here back up I will put some more miles on here.
Still looking at ems since I want to run a utec but with 800cc injectors it may be tough.
Leaning towards haltech or fcon. Would love to have bootcamp.
Old Nov 8, 2010 | 07:21 PM
  #131
JAM3Z's Avatar
JAM3Z
Phenom
Battery dead.....
Tons of doodads are available for the FCON (CAMP2, AFC, Navigator, etc), I'm not that familiar with the Haltech though.
Old Nov 8, 2010 | 07:58 PM
  #132
nathanwl2004
me personally i'm leaning towards proefi. lotsa bad *** features ie flex fuel, launch and performance traction controll. not to mention really advanced knock detection and control
Old Nov 8, 2010 | 11:01 PM
  #133
str8dum1's Avatar
str8dum1
^ya but like 2 tuners in teh country that know how to actually make that stuff work..
Old Nov 9, 2010 | 07:47 AM
  #134
nathanwl2004
Very true but one of those is sp and if I were gonna drop a bunch of dough for a monster built setup I would consider shipping my car to them
Old Dec 29, 2010 | 06:17 AM
  #135
JAM3Z's Avatar
JAM3Z
Phenom
updates?!
Old Dec 29, 2010 | 06:35 AM
  #136
Cux350z's Avatar
Cux350z
hatersgonnahate
nope. Still sitting in the garage. Was in wisconsin all month and then Aiken. Just havent had time to work on her.
Old Dec 29, 2010 | 07:11 AM
  #137
Quamen's Avatar
Quamen
And you didn't even stop in and say hi...
Old Dec 29, 2010 | 07:42 AM
  #138
Cux350z's Avatar
Cux350z
hatersgonnahate
Ill be back in January...on my birthday too . 4th-7th.
It was work related so we spent 12 hrs a day in a plant, ate dinner and went home. Even on weekends.
Old Dec 29, 2010 | 09:26 AM
  #139
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Not really. Don't forget Injected Performance/Dynosty and PF Supercars. I know Hal took the ProEFI class/training and IIRC he was willing to travel for mobile tuning. That could be a viable option for guys in your region. The other dealers are also trained by ProEFI and I venture to say that most are probably capable and competent to tune a VQ.
http://proefi.com/Dealer_List.html
Old Dec 29, 2010 | 09:37 AM
  #140
JAM3Z's Avatar
JAM3Z
Phenom
Chris, if you need a hand with anything, let me know. I'm living in Greenville now (getting my MBA) so I'm only like 20 minutes away.
