my SC Setup
Old Jun 14, 2010 | 06:10 AM
  #181
maXmood's Avatar
maXmood
Under Boost!
Originally Posted by GT-ER
Correct.
thanks!
sometimes when i'm at idle, the car goes from 14.7 to 12.x and back to 14.7.. i'm not sure what's causing this, but i'm thinking because i'm low on fuel and since i don't have an RFS?
just assuming.
how's your car coming along?
Old Jun 14, 2010 | 06:18 AM
  #182
GT-ER's Avatar
GT-ER
Originally Posted by maXmood
thanks!
just assuming.
It's normal for the car to sometimes drop the a/f ratio randomly....nothing to worry about.
I found a pretty nice boost leak and bought a fuel return system...hopefully I'm getting myself out of the hole...lol.
Old Jun 14, 2010 | 06:51 AM
  #183
maXmood's Avatar
maXmood
Under Boost!
thanks..
good to hear you found that leak.. was it in a clamp/coupler?
hope everything works out for you.
Old Jul 17, 2010 | 12:37 PM
  #184
nightcrawler_8's Avatar
nightcrawler_8
update?!!!!
got the haltech ??!!1
Old Jul 19, 2010 | 01:50 AM
  #185
maXmood's Avatar
maXmood
Under Boost!
Originally Posted by nightcrawler_8
update?!!!!
Got the Haltech, but didn't get the time to take my car to the mechanic again.. i'm not quite sure if i want to take the final step of getting the car fixed. it's really hard to trust the available options in my area.
Old Jul 19, 2010 | 08:49 AM
  #186
Erdem's Avatar
Erdem
^+1.. I just feel the same way!!!
good luck with it anyways bro..
Old Jul 28, 2010 | 04:47 AM
  #187
maXmood's Avatar
maXmood
Under Boost!
Quick one... if i have Osiris ROM flashed on my ECU with corrected idle and AFR, and then installed the Haltech on the car, would the haltech over-take the the flashed map as well?
i'm already thinking of putting back the stock ROM once haltech is installed, but just wondering what would happen in such scenario.
Old Jul 28, 2010 | 09:59 AM
  #188
binder's Avatar
binder
you'll need the idle adjusted on the map if you want it to be higher. You can either do that with a flash or if you're staying blow 900 you can just use the cipher cable.
Any haltech adjustments to the fuel will override the osiris fuel and timing maps.
Old Jul 28, 2010 | 12:20 PM
  #189
maXmood's Avatar
maXmood
Under Boost!
thanks binder... always there when i need to clear my doubts.
Old Jul 28, 2010 | 06:34 PM
  #190
binder's Avatar
binder
np. If you're not cammed i would probably just flash back to stock and up the idle with cipher.
I wish i could have done that and saved the cost of a flash but my car still wasn't happy at 900rpms. We had to flash for 1000. got a few more things lined out so maybe we can try to do the 900rpm idle again and get it to work.
Old Jul 28, 2010 | 08:39 PM
  #191
maXmood's Avatar
maXmood
Under Boost!
hmm.. i'm not cammed, so i guess i'll flash the stock ROM. the haltech tuner said he'll do idle + partial throttle tuning, so i figured he'll do the idle as well.. isn't it possible with haltech to set the idle?
my car wasn't happy with 900rpm either, it was raised to 1100rpm to get to idle normally (and it's still not that smooth).
anyways, after idle and partial throttle tuning, he'll finish it off on the dyno.
hope i get done with this (been 2 and half months now and the car still not tuned properly). *fingers crossed*
Old Jul 28, 2010 | 10:20 PM
  #192
mike99101's Avatar
mike99101
Good luck with your setup man-
Just read all ten pages and i hope this does not happen to me when i install my vortech setup
Old Jul 28, 2010 | 10:41 PM
  #193
maXmood's Avatar
maXmood
Under Boost!
you're totally in a different continent.. you got plenty of choices while i don't. that's why i'm into this now.
hope it doesn't pull u this way tho, but with everything around you, it can be fixed by the pros.
Old Jul 29, 2010 | 01:49 AM
  #194
Erdem's Avatar
Erdem
^^^ exactly...
Old Jul 29, 2010 | 01:53 AM
  #195
maXmood's Avatar
maXmood
Under Boost!
Originally Posted by Erdem
^^^ exactly...
how's it going with ur car?
Old Jul 29, 2010 | 03:02 AM
  #196
Erdem's Avatar
Erdem
what car... ooo the 350z.. well it's.. on hold..
I'm not sure what to do about it, get a new built longblock shipped from the US or just get it done here..
I'm still researching the built blocks.. I have IPP and ForgedPerformance in my mind, but not sure..
winther is on it's way. so I'm in no rush
what do you think about the Haltech? I'm considering going that route, now that my Goal is 500WHP
thanks for asking
Old Jul 29, 2010 | 04:58 AM
  #197
midz350's Avatar
midz350
thanks for asking
IPP= lowest prices ever + best customer service ever
Since you are in Denmark, I would go with the Haltech since its open and any tuner can tune it.
Old Jul 29, 2010 | 07:35 AM
  #198
Erdem's Avatar
Erdem
thanks for the input.. I just read about another member in here who had problems with the IPP block..
anyways for how long have u been driven the IPP STG1?
Old Jul 29, 2010 | 11:40 AM
  #199
binder's Avatar
binder
haltech cannot SET the idle. stock ecu controls that.
He said tune teh idle, which means adjust the million parameters to get it to idle properly but the haltech is no able to set the rpm for idle. It's a static setting in the ecu.
Old Jul 30, 2010 | 01:11 AM
  #200
maXmood's Avatar
maXmood
Under Boost!
okay..
i'll just flash the stock ROM, then adjust idle with cipher and pass over the car to him.
