Jtran Studios Presents turbo kits (fabrication thread)
Old Jul 5, 2010 | 02:43 PM
  #161
bldg250z's Avatar
bldg250z
The car is still at the shop and it's getting the meth tune Wednesday. Johnny will post the numbers.
Old Jul 6, 2010 | 08:42 AM
  #162
bldg250z's Avatar
bldg250z
Alright here are some recent pics on the kit Johnny is finishing off some of the details and will be posting numbers later this week!
now for some more pics
Old Jul 6, 2010 | 08:44 AM
  #163
bldg250z's Avatar
bldg250z
heres a couple of vids
Old Jul 6, 2010 | 09:59 AM
  #164
str8dum1's Avatar
str8dum1
any pics of the airfilter routing?
Old Jul 6, 2010 | 10:45 AM
  #165
bldg250z's Avatar
bldg250z
thats one of the details hes working on
Old Jul 6, 2010 | 10:50 AM
  #166
binder's Avatar
binder
setup looks awsome. I like how the piping is bolted to that side of the engine. Gives me a good idea on how to anchor mine since it's vibrating.
question, did you reclock that turbo drain since it's pointing sideways instead of downwards like it's supposed to? garrett says no more than 15* off of complete vertical for proper draining function. Even with a pump this looks like oil would pool in the housing when the car is off (and pump off) therefore leaking oil through the seals. IDK, i'm not an engineer, i'm just going off of what garrett posts on proper installation (since i used that info for doing mine).
Old Jul 6, 2010 | 11:23 AM
  #167
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Correct, even though there is a return pump, it still relies on gravity to drain out of the housing correctly. It looks to me as if there is simply not enough clearance to have it drain straight down, or even at the recommended angles. Wonder if that's the reason for the smoke in the video?
Old Jul 6, 2010 | 12:05 PM
  #168
bldg250z's Avatar
bldg250z
yes jtran did say he would be correcting the angle of the drain.
and also correct on the smoking there was a bit of puddling and was gonna be corrected ..... again some of these are issues he was addressing this week along with a cover to protect parts of the turbo from debris!
hopefully we'll see updates later this week....
Old Jul 6, 2010 | 02:19 PM
  #169
superchargedg's Avatar
superchargedg
Damn Noobs
Man talk about using a lot of rtv................................................i keed.
Old Jul 6, 2010 | 03:46 PM
  #170
lazyduster's Avatar
lazyduster
is it tap into the block?
Old Jul 6, 2010 | 04:25 PM
  #171
FredB's Avatar
FredB
I like how coolant sprayed damn near every pipe in the kit. What happened there? And the intercoolers off to the left about 2 inches, i assume its for functionality. Having the turbo drain so drastic is going to cause smoking. you should put some bolts in the turbo as well, (it helps seal exhaust gas in).
  #172
FredB's Avatar
FredB
yes
Old Jul 6, 2010 | 04:40 PM
  #173
str8dum1's Avatar
str8dum1
you should also have them figure how to add a muffler. You can tel just by the idle its going to resonant pretty badly. straight pipes are cool to begin with but will get old fast. my old straight pipe is sitting by my front door.
Old Jul 6, 2010 | 05:47 PM
  #174
bldg250z's Avatar
bldg250z
Wow really that's your input then I have no comment!!!
Old Jul 6, 2010 | 08:06 PM
  #175
binder's Avatar
binder
that's the upper oil pan, not the block.
Old Jul 6, 2010 | 08:18 PM
  #176
gotagetmyZ's Avatar
gotagetmyZ
+1
Old Jul 7, 2010 | 06:44 AM
  #177
Jtran Studios's Avatar
Jtran Studios
wow and you arent too bright. as far as bolts in the turbo, we took that one off to finalize fitment of the actual bracing for the turbo. those are water spots on the pipe from hurricane alex idiot. why are you such a smart ***? we are adjusting the turbo drain and making sure everything is broken down and cleaned up before giving the car back to the customer.
Old Jul 7, 2010 | 07:19 AM
  #178
rcdash's Avatar
rcdash
The motordyne 3" shockwave v2 eliminates the drone and is still straight through. A different fitting and I think you could rotate the turbo a little more down - great job working in that tiny space though - props. Congrats bldg250z!
Old Jul 7, 2010 | 08:18 AM
  #179
bldg250z's Avatar
bldg250z
thanks i will look into that!
Old Jul 7, 2010 | 08:53 AM
  #180
Elperuano's Avatar
Elperuano
