Ready to buy my setup... Build Thread
Old Jan 11, 2011 | 03:18 PM
  #101
RetchedOne's Avatar
RetchedOne
Here's one more...
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/afAoK8eqNFI?hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/afAoK8eqNFI?hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Jan 11, 2011 | 03:24 PM
  #102
str8dum1's Avatar
str8dum1
i'd be extremely careful. I assume you are just using stock plugs now?
too low of octane, too high of AITs, etc can all cause that as well.
now is when you better trust your tuner 100% becuase if its knocking enough to pull timing in this cold weather, even with 1 step colder plugs, come summer your block might decide it needs a little ventilation.
Originally Posted by RetchedOne
Me Too???
He showed me the graphs, what he said makes sence.
I'm going off what he is seeing and what the graphs sare saying...
It tries to pull timing at high rpm's due to knock... the line goes from a nice smooth ramping line to bumpy crap close to redline.
You can see it pulling timing due to det.
Old Jan 11, 2011 | 04:44 PM
  #103
RetchedOne's Avatar
RetchedOne
This is what lawrence said.
Plugs are ordered.
I dont plan on flogging the car.. till teh new plugs are in...
I've got the dyno sheet...
Now to get it scanned...
Old Jan 11, 2011 | 07:09 PM
  #104
RetchedOne's Avatar
RetchedOne
Dyno run Doc -
436 HP
365 TQ
Once the new plugs are in, Intec will strap it to the Dyno again to adjust a few things.
Lawrence expects the high end torque to improve with the colder plugs.
Old Jan 12, 2011 | 01:31 AM
  #105
maXmood's Avatar
maXmood
Under Boost!
nice numbers dude.. enjoy ur ride!
Old Jan 12, 2011 | 04:30 AM
  #106
GoJira33's Avatar
GoJira33
sounds great man, nice numbers
Old Jan 12, 2011 | 07:10 AM
  #107
RetchedOne's Avatar
RetchedOne
This is the way the Z should come from Nissan...
Old Jan 12, 2011 | 12:01 PM
  #108
Barnabas's Avatar
Barnabas
National Z Club President
awesome!!! enjoy it!
Old Jan 12, 2011 | 12:05 PM
  #109
OldManZ350's Avatar
OldManZ350
Very Nice......
Old Jan 12, 2011 | 01:50 PM
  #110
RetchedOne's Avatar
RetchedOne
Made my appt for next week to have the dealership fix my leaky valve cover too, warranty should cover it Yeay!
Old Jan 12, 2011 | 04:20 PM
  #111
maXmood's Avatar
maXmood
Under Boost!
even tho this is almost a common issue, i still wonder why no vendor took the initiative to make an aftermarket one that works better!?
Old Jan 12, 2011 | 05:52 PM
  #112
RetchedOne's Avatar
RetchedOne
yeah...
It is a "complicated" part though.. with all the different angles/pockets and tabs... but i'm still surprised...
Heck.. you can get a clear one for a honda.. gosh... they get all the fun stuff...
Old Mar 8, 2011 | 01:25 AM
  #113
seymore4's Avatar
seymore4
Professional
2 months later... how's it treating you?
Old Mar 13, 2011 | 01:54 PM
  #114
RetchedOne's Avatar
RetchedOne
It's been running great, zero issues.... Untill yesterday.
I was getting on the freeway, 1st gear, second gear, foot half way into the throttle (regular freeway entry...) and it completely cut out... Like it had no fuel... i let of the gas and it was fine... came back to life.
then today, same thing. At a stop light in town, 1st gear, fine.. second gear acceleration about half way into the gear, and it cut out...
I thought it was the traction control kickin in, so i disabled VTC.. same thing happended....
I'll probably need to bring it into Intec to have lawrence take a look...
I just got finished replacing a motor in my buddies Altima, and have no desire to do my car next...
Other than this issue, i'm happy with teh Vortec and supporting Mods.
Old Mar 13, 2011 | 07:31 PM
  #115
seymore4's Avatar
seymore4
Professional
hmmmm bad fuel pump?
Old Mar 14, 2011 | 05:38 AM
  #116
GreenGoblin's Avatar
GreenGoblin
yeah...
I actually looked into having one made and the cost was a lot...
Old Mar 14, 2011 | 08:43 AM
  #117
Alberto's Avatar
Alberto
Cranky FI Owner
Did the dash lights all turn on?
My car did that to me once, turned out to be a bad TB. No biggie.
Old Mar 14, 2011 | 08:56 AM
  #118
rcdash's Avatar
rcdash
There is the new one with the invidually replaceable spark plug socket gaskets. http://g35driver.com/forums/vendor-s...-new-post.html
Also, make sure you have a breather on your crankcase - excess pressure can cause leaky valve covers among other problems.
Old Mar 14, 2011 | 09:02 AM
  #119
rcdash's Avatar
rcdash
Me Too???
Ummm, no. I'm pretty sure the stock ECU does not pull timing after 5k rpms. It only attempts to detect knock at peak torque and then the window is off. If you are seeing irregular patterns above that, it's something else.
I run 2 step colder NGK iridiums. I think 1 step colder is probably fine too. Never knew Greddy branded their own plugs.
Old Mar 14, 2011 | 04:16 PM
  #120
Barnabas's Avatar
Barnabas
did you change your MAF? I had the same issue before I installed my HPX
