revised HR Build
Old Sep 19, 2011 | 06:40 AM
  #121
str8dum1's Avatar
str8dum1
it sucks cuz you obviously didnt use a pry bar on the flywheel. if they are that negligent with simple things, i can imagine they prolly dont give a **** about anything. good thing you didnt keep driving on it. who knows what woulda happened. Sure wouldnt wanna test the bellhousings scatter-shield abilities.
sounds like its all sorted now
Originally Posted by midz350
The clutch was working fine the last time it was on the car. I called the shop to pick the clutch up and when I got there it was already in a box, I just tightened couple of the the pressure plate bolts with my hand since they were loose. Never thought it would be this fwcked up, so I didn't opened it up. Sorry my mistake
Old Sep 19, 2011 | 07:22 AM
  #122
ace32x's Avatar
ace32x
OS triple ordered this morning! they also paid to overnight it and gave me a huge price break on it so should be in tommorow engine coming out of the machine shop tommorow aswell
Old Sep 19, 2011 | 02:06 PM
  #123
CTZ860's Avatar
CTZ860
Originally Posted by ace32x
ty sir , bigger lobe sizing on the cams keep the valves open longer so you can get more air and exhaust out and make more power pretty much. but going with a bigger cam you sacrifice low end power but you get gains on high end
Loss of bottom end power.....ewwww
Pass on that. But if you were to go with bigger cams could you then push your engine more on the stock bottom end?
From what I've read (not too much) HR's can push out close to 500 on stock internals...?
Old Sep 19, 2011 | 03:08 PM
  #124
ace32x's Avatar
ace32x
i have a forged low compression bottom end now, it was making 530 on stock internals. went with a brian crower 4.07L stoker kit and upgraded fuel return and a twin pump, shooting for 650+ whp on new set up (itl be spooling fairly early with the bigger displacement and the turbo size should be full spool by 3500-3800 rpm)
Old Sep 19, 2011 | 03:14 PM
  #125
ace32x's Avatar
ace32x
going to have to go with cams later thought when i drop bigger turbos and injectors in because the stock ones wont allow enough flow ^
Old Sep 19, 2011 | 05:21 PM
  #126
CTZ860's Avatar
CTZ860
Got ya...cant wait to see this beast when its done.
530 on stock block still seems crazy......was this a daily driver for you? Im concerned about runnin that much power to my hr on stock internals. However...i get the feeling that people blowin their engine are the ones goin to the track frequently and really goin hard on it....
Old Sep 19, 2011 | 05:34 PM
  #127
ace32x's Avatar
ace32x
not daily persay, but it saw atleast 200 miles a week, hard miles at that and was holding up fine, if its ur daily id leave it at 8 psi ( depending on ur tuner and dyno would be between 450-480 wheel)
Old Sep 19, 2011 | 05:49 PM
  #128
CTZ860's Avatar
CTZ860
No daily....i have 35000 miles on car and its not driven in winter. Id say i put only 5-6000 mi on per season. Couple times a week and the rest out joy ridin. Im def lookin for some more power and obvi
FI the way to go.
Just startin to read into this stuff...i got the basic idea based on others builds but still seems like there are mixed reviews on boostin a stock engine and it being a matter of time til it blows.
Realistically i think i wuld be happy with somthin in the 400-450 whp range. Going by ur numbers prior to this build that seems like it wuld be more on the conservative side.....
Old Sep 19, 2011 | 06:08 PM
  #129
ace32x's Avatar
ace32x
id look into the supercharger option if your looking to stay around or below 5, bit safer for the stock block and cheaper too!
Old Sep 20, 2011 | 02:02 AM
  #130
Eno's Avatar
Eno
Man! This was the toughest part for me... waiting for the block to return from the machine shop. I know those boys work fast when they have the parts they need... but it felt like forever.
Still learning lots from your thread though- you've definitely bumped it up a notch or two on my build but I'm also learning that I think I stopped at the right point for what I wanted.
Looking forward to seeing some progress pics!
Old Sep 20, 2011 | 08:21 AM
  #131
ace32x's Avatar
ace32x
theyve had all the bearings and parts and been sitting on it for the last 3 weeks im a little preturbed XD, owell though hopefully its done today like they said!
Old Sep 20, 2011 | 06:16 PM
  #132
Eno's Avatar
Eno
Hmmmmm... if my experience is any indicator then I wouldn't be holding my breath. But, on the positive side I would also have the confidence to know that when the machine shop releases it that it's going to be done exactly the way it's supposed to be and will likely save you time in the long run. Andrew from Intec was saying that with many shops he's had to whittle away and dork around with stuff to make things fit properly- on mine he said it was exactly the way he needed it and it required no fiddling at all. He was very happy with it... I assume he's doing your block too? I get the impression he's very, very good at what he does... Is Mike still there? I'd heard some "things..."
Old Sep 20, 2011 | 08:16 PM
  #133
ace32x's Avatar
ace32x
Na mikes doing mine hes the only one I let touch mine there he's always very meticulous and covers everything very thoroughly. He did my while kit the first time around too.
Guess what lol. Wasn't done. They say Thursday now XD
Old Sep 20, 2011 | 09:40 PM
  #134
ace32x's Avatar
ace32x
andrew knows his de's very well hes the man at them, but his HR knowledge isnt quite there yet (he learned on his which is a DE)
Old Sep 20, 2011 | 11:02 PM
  #135
Eno's Avatar
Eno
Oooooh okay that explains it. I was expecting Mike to do my full build too- but the day I was there to pick up I met Andrew and he said he was the one who did the block... I figured Mike might have taken care of just about everything else... with Bobby.
The fact that I'm a DE explains why he was working on it and I get the impression he did an awesome job on it.
Thursday eh? Yes... Now we're talking! Might need to verify which Thursday
Old Sep 21, 2011 | 07:38 AM
  #136
ace32x's Avatar
ace32x
ya andrew is like the de expert from what im told and chatting with him a tad lol, mines just all around knowledgeable and oversees everything make sure everything is to spec since its all on him if theres an issues XD, i really like your G the color and the wheels go together great made almost want one instead of the z XD. yea haha which thursday indeed... pretty sure it'll be done this thursday we verified they started on it monday after they finished up another vq at the machine shop so hopefully its on track lol XD
on a side note me and a friend of mine did some painting and led work on my headlights. not completely done yet were going to unsauder and remove the stock orange running lights in the top corners of each headlight and resauder in some purple ones to match everything a little better
Old Sep 21, 2011 | 06:30 PM
  #137
Eno's Avatar
Eno
Hey thanks man... you know, I do get worked over every so often about having sedan style wheels on the coupe- and I do get razzed at work about driving my girlfriend's car ( sigh ) but hey- I like it too! Hey Eno, your girlfriend buy the car to match her lipstick... poke poke...
I wasn't sure what that part was in your hand... my first thought was that it was going to be some tail light extension or some other ridiculous thing and I was warming up my forehead for a mighty face palm but then I saw the following photo and I was emersed in relief.
Not going to lie- looks pretty slick from here. After the Quaife goes in I think the objective is going to be to clean up my paint and get into some of the finer details as well.
Old Sep 21, 2011 | 06:50 PM
  #138
ace32x's Avatar
ace32x
hahahaha, yea got some anodized purple lugs and some purple harnesses and my carbon fiber vented hood is gonna have purple vents in it little accent color here n there
Old Sep 21, 2011 | 09:23 PM
  #139
Eno's Avatar
Eno
Eh you ever get that cruise control / uprev thing sorted out? I was reading a bit about it in the tuning section and they were talking about just flashing straight off a netbook / laptop... it's not on the fly but might be suitable for your purposes?
I also noticed that Seymore mentioned that uprev was working on a module that you can plug in to the OBD II connection- but that was a couple years ago so I'm doubtful that's ever gone anywhere.
Anyway, just checking...
Old Sep 21, 2011 | 09:32 PM
  #140
ace32x's Avatar
ace32x
nothing yet that i know of , the laptop option or getting a haltech(as much as i dont want to shell out for it) might have to if i wanna have a pump and a c16 tune. but we'll see i may be happy enough with the pump map for along while
Edit: forgot i facebooked uprev a couple months back and they didnt have anything in the works for it yet either : / according to them
