Looking for a metal 5/8" check valve for my oil catch can system
Old Apr 19, 2012 | 08:33 PM
350Z400rwhp's Avatar
350Z400rwhp
Default Looking for a metal 5/8" check valve for my oil catch can system
I want to put one inline inside the hose coming off my manifold to my catch can so when I boost it doesn't pressurize the whole system. I assume it would need to be metal and most likely a ball bearing style. Any suggestions on where I can find something like this? I have heard people mention it on here but just can't find where to buy something specific that can handle to heat inside a car engine. Thanks in advance
Old Apr 19, 2012 | 08:40 PM
rcdash's Avatar
rcdash
3/8" brake booster valve works fine (plastic).
Old Apr 20, 2012 | 05:53 AM
str8dum1's Avatar
str8dum1
or dont plumb it into the plenum. Problem solved
Old Apr 20, 2012 | 06:15 AM
graffkid732's Avatar
graffkid732
McMaster Carr if you really want one. Parts stores should have them as well.
Old Apr 20, 2012 | 04:02 PM
albinobob's Avatar
albinobob
These guys have everything and ship it pretty fast.
mcmaster.com
Old Apr 20, 2012 | 09:20 PM
350Z400rwhp
Doesn't the vacuum draw off the manifold make the catch can system more effective?
Old Apr 20, 2012 | 09:21 PM
350Z400rwhp
mcmaster.com
Thanks! This is exactly what I'm looking for.
Old Apr 21, 2012 | 06:55 AM
str8dum1's Avatar
str8dum1
maybe at idle, but wen you are driving, theres not much vaccum anyhow, esp if you have a built motor with cams.
Old Apr 21, 2012 | 07:48 AM
rcdash's Avatar
rcdash
^ ???. When you let off, there's lots of vacuum - much more than idle. Obviously, if you keep your foot pressed on the accelerator all the time, then what you say is true...
Old Apr 21, 2012 | 09:18 AM
str8dum1's Avatar
str8dum1
i only smell my car when i am idling. i dont car about actually catching vapors since its not plumbed into the plenum. Although, my catch can fills with water quickly since i'm on E85.
Old Apr 21, 2012 | 11:16 AM
MDK's Avatar
MDK
Summit carries brass check valves... something like this might work for you? http://www.summitracing.com/parts/CTR-24-280/
Old Apr 22, 2012 | 10:57 AM
binder's Avatar
binder
i'm making another post about my wonderful experience with trying to recirculate.
Old Apr 22, 2012 | 11:46 AM
jerryd87's Avatar
jerryd87
checking my logs i never hit more then -12 psi vacuum, barely more then my idle vacuum of -11.
Old Apr 23, 2012 | 06:02 AM
binder's Avatar
binder
that's -24inHG. I idle around -16inHG. Most of these check valves have a 1psi opening which would be 2inHG so -2inHG vac should open it easily.
Sleeper_Z
Sep 30, 2015 10:25 AM
