Another built motor Vortech dreamer thread.
Old Aug 15, 2014 | 04:08 PM
  #221
Classy's Avatar
Classy
Don't hate, and old man nailed it on the head, I didn't have 5-600 hp. I had about 300hp and did everything I could to the cars setup to make it launch. Never made a top 25 in any category of the drag section.
Old Aug 15, 2014 | 06:31 PM
  #222
Jaxter's Avatar
Jaxter
Deleted
Old Aug 20, 2014 | 09:57 AM
  #223
nathanwl2004's Avatar
nathanwl2004
I apologize for thread jacking, but have any of you guys heard anything from bobby or CIN lately? I've been trying to get ahold of them for a while with no luck.
Old Aug 20, 2014 | 05:14 PM
  #224
meanz's Avatar
meanz
If you call him, make sure to leave a message..Ive talked to him here and there on his cell, he's in the middle of some big things, but said he will call back whoever leaves a message.
Old Aug 20, 2014 | 06:51 PM
  #225
nathanwl2004
Thanks man, I will deffinately do that.
Old Aug 21, 2014 | 08:47 AM
  #226
str8dum1's Avatar
str8dum1
too bad you cant get to a 1/4 as that is a mid 400whp 1/8th mile trap.
I was goin about 96mph in my heavier g35 with about 4xx whp in the 1/8th.
Originally Posted by meanz
My 4th and final run I hit a 2.1 60ft 8.0@95. Will post up a vid after work.
Old Aug 22, 2014 | 02:24 AM
  #227
meanz's Avatar
meanz
Went back to the track again with the hopes of pulling a 7.9 on these tires, but it didn't happen. Pulled another 8.0. I will prolly go back in a couple months when it cools down. Was very hot and humid last night. Hopefully have some tires by then that will hook up. I prolly ran 6-8 times last night. Car acted great, just traction issues. Car did hook once but it caught me by surprise and I bogged.
Old Aug 22, 2014 | 04:07 PM
  #228
meanz's Avatar
meanz
Vid from last night thanks to taywan.
Old Aug 31, 2014 | 11:59 AM
  #229
meanz's Avatar
meanz
Took about a 8 hour round trip drive to Z1 motorsports. Traffic was crazy bad, should of been half that. I will say that the z was pretty good in stop and go traffic. Was hot inside due to no AC. Got to play a bit and car pulled great. Did a decibel test to see if my car would be quiet enough for the track. It pulled 126 decibels from about 50-100ft away. With the silencer it was 105. That track max is 98. Will prolly pass on this track day, mostly because I would need to take off time from work, get a hotel for 2 nights and still register. We are in the middle of closing on this house and don't want any extra bills at the moment.
Jacked the car up to look around and install my z speed shroud I got from cux and also prepare for the oil change. I found that a engine mount bolt that goes to the block had backed out a good bit. It had locktite on it already. I purchased some blue locktite and resecured it. Also found a little residue on outside of my pipes from BPV. Havent checked inside the charge piping yet. I am still running the stock BLV from vortechs kit. Im wondering which would be better. A second BLV on the other side of intercooler or just get a bigger one. I researched a little and see that v-8 guys use 2 on their charge piping. Anyone know of any reason a 2nd BLV wouldn't work as good or not better than a bigger one?
Old Aug 31, 2014 | 12:02 PM
  #230
meanz's Avatar
meanz
I also found a couple of drops of oil coming from the passenger side valve cover in the rear. It hasn't dropped yet, just forming a drop. May be from valve covers rattling loose. Havent checked yet. Kinda hot outside, so the z is just sitting on jackstands at the moment..
Old Aug 31, 2014 | 12:48 PM
  #231
OldManZ350's Avatar
OldManZ350
Sounds pretty Fast in you video.
Old Aug 31, 2014 | 03:19 PM
  #232
Colombo's Avatar
Josh I would deff chase down the oil leak. And DEFF check if your getting oil in the charge pipe or intercooler. Seals of your blower may be on the way out or leaking.
Old Aug 31, 2014 | 03:21 PM
  #233
Colombo's Avatar
If it's seeping out the Bpv mounted on the intercooler I would check not just the charge pipe near the throttle body but check just where it leaves the blower down by the radiator for oil.
Old Aug 31, 2014 | 03:55 PM
  #234
meanz's Avatar
meanz
Well I pulled off charge piping coming directly from blower and for the most part it's pretty dry. You can feel a hint of a film of oil. But doesn't seem like anything catasrophic. I'll have to be easy on it or not drive it at all till I get this BLV off this..
Old Oct 1, 2014 | 12:51 PM
  #235
meanz's Avatar
meanz
Finally got my tial q bov welded and hooked up. Also added a much larger vac hose to control it.
Old Oct 1, 2014 | 02:10 PM
  #236
NAbuilderZ33's Avatar
NAbuilderZ33
Awesome Build, read your whole thread and learned alot thru ur journey with your Z. Subscribed!
Old Oct 1, 2014 | 05:12 PM
  #237
meanz's Avatar
meanz
Thanks man, I just re-read it today myself, lol
Old Oct 2, 2014 | 06:22 PM
  #238
meanz's Avatar
meanz
Went to the strip again. 1/8 mile still. Went with a goal of 7.9s. My best
Ended up being a 7.82@96 Same tires as before..
Old Oct 2, 2014 | 07:14 PM
  #239
taywan's Avatar
taywan
Almost everything is thanks to taywan...jk. had a few after a long *** day. Can't wait to hear in person. Wish I was at drag. Maybe next week
Old Oct 3, 2014 | 08:34 AM
  #240
OldManZ350's Avatar
OldManZ350
Here is a ballpart est of where your 1/4 run would be.
If you set your car up right, you should see Low 11's and High 120's mph
Attached Thumbnails Another built motor Vortech dreamer thread.-screen-shot-2014-10-03-at-12.28.56-pm.png
