Another built motor Vortech dreamer thread.
Old Aug 16, 2015 | 03:02 PM
  #761
meanz's Avatar
meanz
Originally Posted by OldManZ350
Josh, Looking Good!
Those look like nice motor mounts, what brand?
Z1s 6 shooter solid mounts
Old Aug 19, 2015 | 05:37 AM
  #762
meanz's Avatar
meanz
Timing cover came in. Gonna be replacing it soon. Removed my crank pulley, that thing was hard as hell to remove. Had to heat it up a good bit to soften the lock tight.
Old Aug 23, 2015 | 01:16 PM
  #763
meanz's Avatar
meanz
Timing cover installed and sealed up. Took a little longer to do since i worked on it just a little every night after work. Have a few things on the way that i ordered. Everything starting to come together.
On another note, glad i got new engine mounts. My drivers side fell off the work bench and broke in half. Only had about 15k on it.
Sprayed my cam covers black with some black to make it a little cleaner looking. Looking good overall. Think since my front end is off, i might revisit my heat shield that I made and make it a little better.
Old Aug 23, 2015 | 03:13 PM
  #764
Resmarted's Avatar
Resmarted
Looks good. Dont give into the ricer gold temptations m80
Old Aug 23, 2015 | 05:03 PM
  #765
OldManZ350's Avatar
OldManZ350
Looking Good Josh!
Old Aug 24, 2015 | 04:55 AM
  #766
Conway_160's Avatar
Conway_160
Want to reseal my rear timing cover for me???
Looking good!
Old Aug 24, 2015 | 08:59 PM
  #767
Resmarted's Avatar
Resmarted
WHUURRSS DEE FAAAWWWKKINNN BLOOOWWAARRRrr
Old Aug 25, 2015 | 10:49 AM
  #768
meanz's Avatar
meanz
2 week build time..
Old Aug 25, 2015 | 02:18 PM
  #769
Resmarted's Avatar
Resmarted
2 week build time..
So, in about... one and a half months, you'll have a blower. I see.
Old Aug 25, 2015 | 05:07 PM
  #770
meanz's Avatar
meanz
Yeah pretty much. They need to hurry up!
Old Aug 26, 2015 | 10:12 AM
  #771
Resmarted's Avatar
Resmarted
You could probably walk to their shop, learn how to build it yourself and walk home in less time than they take jfs
Old Aug 29, 2015 | 03:34 AM
  #772
meanz's Avatar
meanz
Finally got to start it last night to check for any leaks. Good thing is, no leaks. But battery is so bad it won't hold a charge. Put a charger on it over night and it wouldn't charge. Let the car warm up and did some revs. So far so good. I can def notice a difference in the solid mounts already on how the car idles and revs. It does have a bit of vibration just idling. Also have an exhaust leak under the car. But main concern was leaking timing cover.
Old Aug 29, 2015 | 05:48 AM
  #773
Conway_160's Avatar
Conway_160
Nothing worse than a leaking timing covet :-(
Old Aug 29, 2015 | 06:21 AM
  #774
Cux350z's Avatar
Cux350z
hatersgonnahate
If the battery dropped below 6v or so then your "auto" chargers typically only charge to that. Did you jump start? If so...let your alternator charge the battery up a bit.
leaking timing cover? That sucks royally.
Old Aug 29, 2015 | 07:48 AM
  #775
meanz's Avatar
meanz
Yeah had to jump it to start it. Car would start to die as soon as I removed cables. Let it sit for about 10 min to try and charge it, but it would die. Only reading 12 volts on gauge, battery light on. I forgot what it was when we measured with multimeter. Checked the connections on alternator also. Seemed fine. Checked fuse.. Battery been goin bad for a while though.
Old Aug 29, 2015 | 08:22 AM
  #776
meanz's Avatar
meanz
Looks like I might of found someone to trade my my carbon caps for his billet caps.. Don't want to risk blowing the carbon caps out at high psi. He is in Minnesota, what's the best way to go about this. He's on driver as Young1tran..
Old Aug 29, 2015 | 08:49 AM
  #777
Conway_160's Avatar
Conway_160
Paypal. W/ ins
Old Aug 30, 2015 | 11:58 AM
  #778
meanz's Avatar
meanz
He's actually gonna ship his to me first then in return, I'll ship mine. This should add some peice of mind when hitting high boost.
Old Aug 30, 2015 | 03:18 PM
  #779
Conway_160's Avatar
Conway_160
How much boost you planning for with the YSI?
Old Aug 30, 2015 | 04:11 PM
  #780
meanz's Avatar
meanz
Don't know yet. Hoping to be high in the 20s. The more the better. Haven't even bought cogs or sent out my pulley yet. Figure I'll go ahead and get the 27t for the blower.
