Another built motor Vortech dreamer thread.
Old Sep 12, 2015 | 01:04 PM
  #801
meanz's Avatar
meanz
How she sits for now..
Old Sep 12, 2015 | 01:17 PM
  #802
Conway_160's Avatar
Conway_160
Looks like lots of fun.
Old Sep 12, 2015 | 01:29 PM
  #803
Resmarted's Avatar
Resmarted
Sweet man! Looks awesome! Look's like a pretty easy fit too.
Old Sep 12, 2015 | 01:57 PM
  #804
meanz's Avatar
meanz
Yeah this went in prett simple. It was a lot easier since I have the front end off. I'm mocking up some 3" piping off the blower now with a coupler and its clearing. Well it's right up against a couple things, but it's gonna work out great!
Old Sep 12, 2015 | 03:15 PM
  #805
OldManZ350's Avatar
OldManZ350
Hay Josh,
Saw you're pic's photo hut or whatever the name is.
If you have already then no worries. But the Area under the SC'er near the flange on the Frame should be ground or trimmed back. I'd say you want a min of 3/4" clearance here.
Even though you have soild mounts, stuff still moves....
TimRod
Old Sep 13, 2015 | 08:44 AM
  #806
meanz's Avatar
meanz
Thanks Tim, I might wait and see how it does before I do any adjustments to that area.
Been working with mocking up piping coming off the blower. It's a tight fit but it's doable. I'm using extra piping that I have to mock everything up before I buy piping and weld it.
Couple issues I was having, the piping coming out th blower was hitting fan shrouds and was hitting the electrical plug causing piping to bind a little bit. I found I was able to move the fan Motor around if i grinder a notch for the connection for the fans. Grinding down plastic is super easy lol. Had to grind/cut out some more to fit. This is the only spot I've been having issues with. But i have it on now and it's not hitting. It's tight, but not hitting.
Old Sep 13, 2015 | 08:50 AM
  #807
meanz's Avatar
meanz
This was how it was
And this is how it is now. Just had to notch the plastic with a grinder to fit the connector. Hooked my drill to the fan and spun it just to make sure it didn't rub. All good
Old Sep 13, 2015 | 08:52 AM
  #808
meanz's Avatar
meanz
Had to grind this down a little bit
And notch this.
Old Sep 13, 2015 | 12:37 PM
  #809
Cux350z's Avatar
Cux350z
hatersgonnahate
did you confirm with vortech the rotating direction of the gearbox to work on a 350z? Might want to hand spin it to make sure.
Old Sep 13, 2015 | 12:41 PM
  #810
meanz's Avatar
meanz
Yes, I talked to them and they said everything would be good. Just wasn't sure on fitment inside the car. I can spin it by hand in the correct direction and it blows out. When spun by hand, the gears are pretty noisy. I'm guessing it's normal. I'm calling vortech tomorrow to ask about a couple things.
Old Sep 13, 2015 | 01:48 PM
  #811
Cux350z's Avatar
Cux350z
hatersgonnahate
straight cut gears?
It hit me to ask cause they didnt include the cog so they might not of thought about the direction.
Old Sep 13, 2015 | 01:49 PM
  #812
meanz's Avatar
meanz
Yes, straight cut.
Old Sep 13, 2015 | 01:53 PM
  #813
HRMoneyPit's Avatar
HRMoneyPit
Thought YSI was up next!
Either way how much boost you going to use?
Old Sep 13, 2015 | 02:09 PM
  #814
meanz's Avatar
meanz
Who said it wasn't ysi??
Old Sep 13, 2015 | 02:24 PM
  #815
HRMoneyPit's Avatar
HRMoneyPit
Oh, thing is huge. What PSI are you looking at now?
Old Sep 13, 2015 | 02:27 PM
  #816
meanz's Avatar
meanz
Don't know yet. Need to buy some piping and a cog before I find out.
Old Sep 13, 2015 | 02:37 PM
  #817
Conway_160's Avatar
Conway_160
Man this looks awesome, I really need to get mine running again.
Old Sep 13, 2015 | 05:44 PM
  #818
OldManZ350's Avatar
OldManZ350
It's CCW. You can tell by looking at the Volute.
Attached Thumbnails Another built motor Vortech dreamer thread.-screen-shot-2015-09-13-at-9.42.16-pm.png
Old Sep 13, 2015 | 06:01 PM
  #819
Cux350z's Avatar
Cux350z
hatersgonnahate
There is an input shaft...some gears and then finally the impeller spins. The input shaft needs to spin the right direction to spin the impeller the right direction..not sure how many gears in between the input shaft and impeller.
Old Sep 13, 2015 | 06:04 PM
  #820
OldManZ350's Avatar
OldManZ350
Josh, Looking Good!
Just Make Sure! The Volute can Never hit or touch any other part of the car!
It can cause Vibration between the Volute and Impeller, and that's not's good.
Their is only about .006" Clearance between the Volute and the Impeller.
