BUDGET Turbo Project- Started
Old May 2, 2013 | 05:45 PM
  #201
soulblade xv's Avatar
soulblade xv
Okay, thanks alot. I am going to look over that and use the flange gaskets so it doesn't leak haha.
Old May 3, 2013 | 10:11 AM
  #202
iideadeyeii's Avatar
iideadeyeii
Good luck. Been slow and working on my motorcycle because bitches like it better.
Bypassed and deleted stock idler pulley
Took off custom ac tentsioner I made when I bought the car and bought an oem one and installed
Took of aftermarket underdrive pulley and installed a stock one.
Made a custom Type-rs to type-h bov plate and installed a Turbo XS RFL replica.
Ordered and installed spyder aftermarket headlights and 55w 5000k hids with slim ballasts (not pertinent to build, but I couldnt drive at night before on old headlights)
Ordered a new belkin db9 to usb cable since all my chinese ones that I had do not work and I don't feel like looking for the correct drivers.
Waiting for that to come in
Old May 3, 2013 | 10:53 AM
  #203
ksuberk54's Avatar
ksuberk54
I'm curious to see how this holds up for you. You're the second person I know whose done this kit and both of you have said it does require a lot of fab work but that it's not that bad. I may look into this in the future. We'll see.
Old May 8, 2013 | 03:26 PM
  #204
nway2deepagain's Avatar
nway2deepagain
The words...budget and turbo should NEVER be used next to each other.
Old May 8, 2013 | 05:50 PM
  #205
nway2deepagain
Originally Posted by binder
Because each of these cars changed every 3 years. The DE platform was 3 years so that's a narrow margin of cars when the v8 cars are essentially the same bodies for a decade or more.
On top of that the total number for our cars ever sold is still less than just 1 year of any mullet machine out there on the road. More cars=more people=more market for parts
Companies don't invest money in a tiny market. There especially isn't money when everyone comes to the forum and wants a 1000$ turbo kit. So if there are 100,000 350z and they sell each of them a turbo kit then they take in 100,000$ now probably 50% of that is overhead so they made a whopping $50,000 in a year. Next year 0$ since everyone has the kit. Not a good business model.
R u trying to prove your self wrong? Sounds like a great business model to me so long as they dont have you for an accountant! Check your math! I hope you will more careful when you start writing prescriptions.
Old May 8, 2013 | 07:50 PM
  #206
DarkCreep's Avatar
DarkCreep
I did it before, and I had absolutely no issues. Theres no need for a 20000 turbo build if the car is only going to be raced from street light to street light.
Only thing I didnt cheap out on was the tune
Old May 9, 2013 | 11:25 AM
  #207
soulblade xv
And i will be doing the same. XD. Except with my kit i replaced the wastegate, bov, and will add an oil cooler and turbo timer. Not to mention i will be running uprev.
Old May 16, 2013 | 07:15 AM
  #208
iideadeyeii
Got db9 to usb belkin cable and it works. My 2.5mm to serial from my LC-1 Doesn't seem to be working, but I don't have the one that innovative sells, instead I have a cheap one off ebay. Went ahead and ordered the cable from the innovative because I cant connect the lc-1 to logworks, UTI or any other utec logger. When that comes in hopefully i'll get some real updates, videos, quarter mile runs
Old May 16, 2013 | 08:45 AM
  #209
nofrey's Avatar
nofrey
Subd....interested to see how this works. I thought of getting this kit just for the piping and replace the turbo, bov, wastegate and interfooler or get custom pipes. If not bp kit if I don't find a used kit when I'm ready to buy.
Old May 16, 2013 | 11:05 AM
  #210
iideadeyeii
In all honestly if I was to do it again I probably would of made my own custom rear mount set-up.
Old May 16, 2013 | 05:55 PM
  #211
nofrey's Avatar
nofrey
Yea I thought about that
Old May 28, 2013 | 07:44 AM
  #212
iideadeyeii
I have to take some new videos, but I finally got the car out of my garage and on the highway. Running above 4k AFR is decent. Under 4k at WOT Im about 10-11, so I need to lean those out. Max boost is 6.4psi according to UTEC. Updates to come
Old May 28, 2013 | 09:00 AM
  #213
iideadeyeii
Side note. I'm only boosting about 2.6psi in first gear and I can get 6.4 in 3-4th gear. Anything think by me running the stock exhaust would restrict the turbo from fully spooling in lower gears since there is less load?
If so, I'm thinking e-cutout or I'm just buying a cheap 3" single exhaust
Old May 28, 2013 | 09:15 AM
  #214
binder's Avatar
binder
Originally Posted by iideadeyeii
Side note. I'm only boosting about 2.6psi in first gear and I can get 6.4 in 3-4th gear. Anything think running the stock exhaust would restrict the turbo from fully spooling in lower gears since there is less load?
turbos require load to spool. Between the low load and very short period of time you are in 1st gear there will be very little time to actually produce boost. This is normal with regards to any turbo.
Old May 28, 2013 | 10:18 AM
  #215
jerryd87's Avatar
jerryd87
plus to elaborate the ebay turbos require alot more force to spool due to poor manufacturing specifications so it wont build as much as well. stock exhaust will also hurt that some but overall its just a combination of things causing it.
Old May 28, 2013 | 11:03 AM
  #216
iideadeyeii
Ok. I maybe just grab a cheap exhaust after I inspect the car in june, so I'm good for a year, though I did legally pass emission with no cats and my injen exhuast the last two years.
I thought the turbo was pulling oil from the feed(wouldn't have surprised me), but I found out my drain flange was not tight enough and fixed it.
Also I had the wrong wastegate spring in. Was hitting almost 10lbs of boost before my ignition cut kicked in(boost cut was set at 9 for protection) Changed the spring 4 times until I got it to under 7. Boost cut is now set at 8psi just in casee, but the utec cut works and it works very well.
Old May 28, 2013 | 05:41 PM
  #217
binder's Avatar
binder
You can just pull the muffler off and test it.
I run stock rear muffler and I have a cutout right off my turbo. With the cutout closed My car gets stuck around 10psi due to heavy back pressure. I open it up and bam, 26 psi no problem. With low power (350hp) I think the stock exhaust won't be too terribly restrictive but I would put that on the upgrade list soon. At the very least take the resonator out of the middle section so it's just a rear muffler.
Old May 29, 2013 | 12:29 PM
  #218
iideadeyeii
That might be an option. How does it sound without the resonator?
I had an exhaust that cost as much as my turbo kit before, so if it is going to sound raspy, I'll just stick to a cutout
Old May 31, 2013 | 12:21 AM
  #219
jerryd87's Avatar
jerryd87
just to give you an idea of how big a difference things can be and the advantages of the quality turbos, did a data log today and i hit a max of 17 psi boost in first gear, however the difference between me and binder is me using the 66 exhaust wheel and a quick spool setup, it also only hit that for a second at 7k, dont see 1 psi boost till 3800 though vs on the highway in higher gears ive seen 5 psi as low at 2500. so what your seeing on your setup is probably on par with what it should be with that turbo
Old Jun 1, 2013 | 07:01 AM
  #220
binder's Avatar
binder
Sounds just like stock but maybe a slight bit louder. No change in tone at all.
Yep, the larger turbo that is more efficient will give you more boost and going to 7k will also give more time for that turbo to spool. Shifting down at 5k or something on the street in first gear would give almost no time for the turbo to build pressure.
