BUDGET Turbo Project- Started
Old Aug 15, 2014 | 08:57 AM
  #301
danny724's Avatar
danny724
Default Don't let the thread die
How's the build going bro and I messaged u if u can message me back thanks
Old Aug 15, 2014 | 09:48 AM
  #302
iideadeyeii's Avatar
iideadeyeii
Yes?
Old Aug 15, 2014 | 09:57 AM
  #303
danny724's Avatar
danny724
Originally Posted by iideadeyeii
Yes?
If u can email me @ danny_14@live.fr
Old Aug 15, 2014 | 10:27 AM
  #304
iideadeyeii
no.
Old Aug 15, 2014 | 11:21 AM
  #305
danny724's Avatar
danny724
Ok im getting a turbo xs management ecu And might be getting a lc-1 wideband when I have everything would I need anything else to download my map to start tuning I know it's a s newbee question but u got to start somewhere
Old Aug 15, 2014 | 12:10 PM
  #306
dragon11689's Avatar
dragon11689
Wow, this is frickin awesome. Best of luck with this man. You rock! Hopefully, I will be able to do this in the future. I'm slowly building my mechanical skill level up to that point.
Old Aug 15, 2014 | 12:34 PM
  #307
iideadeyeii
Laptop with windows xp to use Hyperterminal. UTI-me from jeffsoftware to incorporate lc-1 with Utec. 2x belkin serial to usb cables(dont use any other brand)
Old Aug 15, 2014 | 12:47 PM
  #308
danny724's Avatar
danny724
does uti work with all windows ?
Old Aug 15, 2014 | 12:52 PM
  #309
iideadeyeii
I would assume so. It's just connecting the UTEC to anything that's not a windows xp hyperterminal. I tried other programs in windows 7 and I could never get it to connect. I bought an old laptop with xp on it that won't even hold a charge for less than $50 and works great for the UTEC
Old Aug 17, 2014 | 02:45 AM
  #310
Eno's Avatar
Eno
Hmm if you used a windows 7 machine and had it run the program in "XP compatibility mode" I wonder if it would work for ya?
Old Aug 17, 2014 | 12:02 PM
  #311
djamps's Avatar
djamps
Last time I tuned on a Utec I used PuTTY instead of HT.
http://www.chiark.greenend.org.uk/~sgtatham/putty/
I also didn't need a serial port adapter or serial cable -- the UTEC had a USB port so I used a plain old USB cable and it showed up as a regular COM port in windows. Left it tucked up in the dash in case so I don't have to pull the UTEC down any more.
Old Aug 18, 2014 | 07:25 AM
  #312
iideadeyeii
Car is back together with 6psi spring installed(instead of 5). Car feels slower than before. I didn't have wideband gauge hooked up so it may be fuel related, but my map should be good up to 10psi.
I've been driving my bike around lately when usually I barely drive it so maybe that's why it feels slow.
A/C line is also fixed, but can't run a sway bar with it(well I could, but I would have had to have the car down even longer to route the hose under the sub-frame) Honestly, I can't notice a handling difference. If I did auto-x I'm sure I could then
Old Aug 18, 2014 | 09:20 AM
  #313
NOLAGG's Avatar
NOLAGG
How many miles are on your motor and trans again? And any pics of how it looks currently
Old Aug 18, 2014 | 09:45 AM
  #314
iideadeyeii
145K-ISH
No new pics. Took one of the ghetto a/c line I fabbed up, but that's about it. Nothing exciting to see
Old Aug 18, 2014 | 11:53 AM
  #315
NOLAGG's Avatar
NOLAGG
145K-ISH
Jw did you compression test and or leak down test your car before doing it? Or just said f it lol
Old Aug 18, 2014 | 12:49 PM
  #316
iideadeyeii
F it : ) Car pulled a 13.8 before turbo, so with that I'm assuming compression was good
Old Aug 18, 2014 | 01:09 PM
  #317
NOLAGG's Avatar
NOLAGG
Haha sweet, so bottom line if one were to go the budget semi reliable turbo route, would you suggest going threw same route as your self? Or world you change any of the factors involved such add tuning? Sorry to chew your ear of dude lol and I said f it too when I boosted my 140xxx ka24 240 on 8psi all day on a gt2871r ~~~ haha
Old Aug 19, 2014 | 06:15 AM
  #318
iideadeyeii
I MIGHT have done a custom rear or midmount set-up instead.
I barely had to modify the tune to work since it's already on the UTEC website for this kit.
Old Aug 19, 2014 | 08:57 AM
  #319
danny724's Avatar
danny724
u think if I run that tune on my z for a while it'll last ?? I would run it hard just twice a month though
Old Aug 19, 2014 | 12:18 PM
  #320
iideadeyeii
As far as the AFR goes it's fine and there are no knocks. Out of the box it was running too rich in boost. I only had to shift the entire map over about 2psi to fix the issue
