Stillen HR S/C
Old Jul 12, 2013 | 04:37 AM
  #81
Jaxter's Avatar
Jaxter
Originally Posted by Robert_K
Coming along nicely.
Thanks man.
I'm having idler pulley trouble right now. The 3" I bought is rubbing the block. I have to find a 2.5" before we can get it on the dyno for tuning.
Old Jul 12, 2013 | 05:50 AM
  #82
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Welcome to the life of owning a boosted VQ.
Old Jul 12, 2013 | 04:00 PM
  #83
Jaxter's Avatar
Jaxter
Well nobody makes one that I can find. I'm having one made.
Old Jul 13, 2013 | 07:03 AM
  #84
Classy's Avatar
Classy
I wasn't such a huge fan of my wilwoods, I never got around to trying different pad compounds out, I hope you like yours
Old Jul 13, 2013 | 07:49 AM
  #85
Jaxter's Avatar
Jaxter
They look smaller then I pictured in my head. I got 13" front/rear so I would have more wheel options for later. For some reason I change wheels a lot...Auto ADD I guess.
Old Jul 13, 2013 | 09:20 AM
  #86
Classy's Avatar
Classy
I had the 14 inch front and 12.66 rear. I didn't want to go smaller than an 18, so th 14 inch rotor was fine.
Old Jul 14, 2013 | 04:49 AM
  #87
Jaxter's Avatar
Jaxter
I should have gotten the 14" Fronts too I guess. I doubt ill ever go smaller than 18".
Old Jul 14, 2013 | 04:52 AM
  #88
Classy's Avatar
Classy
I had XXR 521 18x10.5 +25 up front and I had to buy thin nuts for the fake 2 peice fasteners to clear the caliper from the bolts that I also had to shave down, but after I did that I never had a problem and they looked awesome inside that wheel
Please excuse the rims, but it shows how my wilwoods filled out an 18
Old Jul 16, 2013 | 12:47 PM
  #89
Jaxter's Avatar
Jaxter
This should be the last power upgrade for a while. Here are the comparison dynos.
Last Year: Filters, TP, 3" Exhaust, No Tune VS. Same + Uprev.
Most Recent: Stillen HR S/C (SCi @ 49K RPMs), Meth, and JTran Tune VS. Same + Cog pulleys (SCi @ 56K RPMs).
All comparisons should be apples to apples. Hot motor, hot temps, Texas July, same dyno.
EDIT: The run with the cog pulley was cut short do to the belt trying to walk off the cogs. My current idler pulley is 3" OD, and the lip had to be shaved down some for clearance. Now the belt is trying to walk over the lip at high rpms. A 2.5" OD Lipped idler pulley is being machined right now to solve the problem. Then next week we will be able to see a full run with the new setup and a cleaned-up tune.
Old Jul 16, 2013 | 01:15 PM
  #90
Jaxter's Avatar
Jaxter
Oh yeah, and the bad news. My 305mm R888s still did not fit after the fender roll, so I'm selling all four including the 235 fronts. I had to order a set of Nitto NT-05s in 275/245.
Old Jul 16, 2013 | 02:14 PM
  #91
Bmurray350z's Avatar
Bmurray350z
All you needed was some negative camber... There are guys running 305s on the front of the Z.
Old Jul 16, 2013 | 04:35 PM
  #92
Jaxter's Avatar
Jaxter
Dont get me wrong. It can be done on my car too. But, I don't see any point in running so much negative camber that I end up with a 305mm tire making only 100mm of contact with the asphalt. I bought the wrong offset wheel to be running such a wide tire. It would be completely non-functional. Might look cool, but not worth ruining a set of tires. With a 275mm tire, hopefully I'll get a 275mm contact patch and good tread life.
Old Jul 16, 2013 | 05:32 PM
  #93
Classy's Avatar
Classy
Nice torque gain! Fitting big tires on the Z is all about correct width and offset, I don't know what your wheel offset and width is but a 305 is very possible but a tight fit, and I do believe a R888 is a wider tire compared to others
Old Jul 16, 2013 | 05:53 PM
  #94
Jaxter's Avatar
Jaxter
9.5/10.5" +15
Old Jul 16, 2013 | 06:46 PM
  #95
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Congrats. And there are plenty of 350Z owners running a 305/30-19x10.5 +15.
Old Jul 17, 2013 | 02:07 AM
  #96
Jaxter's Avatar
Jaxter
Thanks man. But what is their camber? That is what I'm trying to avoid. All I can speak for is my car. The setup did not fit my goals.
Old Jul 17, 2013 | 03:58 AM
  #97
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Need to ask the guys that are running it. Remember... It doesn't "have" to fit "inside" the wheelwell. Even mine poke out some and are only flush with the fender at it top center point. I prefer a square alignment like what you're going for.
https://my350z.com/forum/wheels-and-...es-thread.html
Attached Thumbnails Stillen HR S/C-screen-shot-2013-07-10-at-10.33.25-am.png
Old Jul 23, 2013 | 05:00 PM
  #98
Jaxter's Avatar
Jaxter
Nothing new FI, but here is some eye candy.
The Rear Diffuser and idler pulley should be installed tomorrow. Then touch up the tune and its done.
Old Jul 23, 2013 | 05:04 PM
  #99
Bmurray350z
Looks good!
Old Jul 23, 2013 | 05:11 PM
  #100
MM'08_350Z's Avatar
That is one beautiful Carbon Silver 350Z!!!
