Vortech and JWT cams
Old Aug 3, 2013 | 11:06 PM
Jairen's Avatar
Jairen
Default Vortech and JWT cams
Just curious to see if anyone has cams with the Vortech. Curious to see if it's worth it once tuned.
Anyone?
Old Aug 4, 2013 | 03:13 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
C'mon dude. Try using the search function for thread titles with vortech and cams. Also take a look at the Vortech build threads on here.
https://my350z.com/forum/search.php?searchid=17524091
Old Aug 4, 2013 | 03:21 PM
Jairen's Avatar
Jairen
I did that exact same search plus more. If you actually read those threads, you will come up with nothing definitive with little info concerning the Vortech/JWT combo.
I may be wrong, but it seems like there aren't many Vortech-ers that are cammed.
Old Aug 4, 2013 | 04:04 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
First of all, what are your power goals? Stock block or built motor?
If you're on a stock block, cams aren't necessary to make 400whp. At that power level, you're better off doing a pulley upgrade. It's not worth the cost and labor to install aftermarket cams to achieve a number that can be achieved by upgrading the pulley. Here's a perfect example from a very recent thread of some respectable stock block Vortech numbers with stock cams...
https://my350z.com/forum/forced-indu...ercharger.html
Plus there are 2 built motor Vortech build threads on page 1 of the FI section with JWT cams...
https://my350z.com/forum/forced-indu...er-thread.html
https://my350z.com/forum/forced-indu...tor-build.html
And then there's Triji's recent Vortech build with Kelford cams...
https://my350z.com/forum/forced-indu...y-dynosty.html
Old Aug 6, 2013 | 05:10 PM
Eddie K.'s Avatar
Eddie K.
I have just installed a set of Tomie cams on my z after having it tuned it's a blast to drive. The power band hits at 4200 rpm till redline. The car was fun to drive before but with these cams the car is like a rocket at 4200 rpm.
Old Aug 6, 2013 | 05:17 PM
Eddie K.'s Avatar
Eddie K.
I am on a stock block Tomie cams, Tomie headers, CJM stage 2 fuel system and Vortec v3 supercharger with 2.87 pulley. 457 HP.
Old Aug 6, 2013 | 07:13 PM
Colombo's Avatar
do a little searching, a few post down my build thread and a few others. im on built motor w jwt c2 cams valvesprings blah blah. i would say stock block just smaller pulley. dont waste the money.
Old Aug 6, 2013 | 10:32 PM
bealljk's Avatar
bealljk
I ran the jwt c2 cams with the procharger…really opened things up past 5k rpms…13psi 455whp, built block, DW600cc/CJM Stage 2
Old Oct 27, 2013 | 02:30 PM
BadBlu-Z's Avatar
BadBlu-Z
How do you like your IPP stage 2 block? my stock block took a dive and now im thinking about going with the stage 2 block with my vortech v3.
Old Oct 27, 2013 | 07:56 PM
unvmyg35's Avatar
unvmyg35
I have JWT cams on a stock block. Although I also have headers and TP's that help open up things.
350Z_Al
Oct 29, 2020 07:44 PM
B Esquire
Sep 24, 2015 07:52 AM
