Procharged G35
Old Mar 4, 2015 | 09:24 PM
  #181
Resmarted's Avatar
Resmarted
Originally Posted by Conway_160
Im going to look into getting the coated, if I cant go that route ill just wrap the parts that are close to fuel and clutch lines.
Coating will be $$$ not sure it's really necessary. Probably more than headers? Idk. Anyway, one of the best designs for holding in heat is a thermos... The thermos has an inner cup (ideally) a vacuum, and then an outer cup. The reason it isolates the inner heat so well, is the heat has to radiate from the inner cup to the outer cup, then that has to radiate or conduct. Radiant heat transfer is by far the weakest, especially in a vacuum. Air is a better thermal conductor, but it's still much lower conductivity than lets say a piece of metal (if you were holding one end of a metal rod, and holding a torch to the other side, you'd feel it pretty quick).
By putting a piece of metal in between the header and whatever else is there, you do something very similar. You don't have a black body on the header, and you do have air between the parts, but this still blocks heat tremendously well. Even if it's just like a few millimeters space on each side.
Old Mar 5, 2015 | 07:33 AM
  #182
Conway_160's Avatar
Conway_160
If its that expensive to coat I won't go that route. I'll figure something out.
Old Mar 5, 2015 | 06:07 PM
  #183
KushZEN's Avatar
KushZEN
Its not that bad. I just had my headers ceramic coated for roughly $300. Though mine are Momentum headers and not long tubes, so YMMV.
Old Mar 6, 2015 | 01:26 PM
  #184
Conway_160's Avatar
Conway_160
Headers are on back order..car may run this year.
Old Mar 6, 2015 | 01:43 PM
  #185
2bad240's Avatar
2bad240
Call around. I got mine off ebay. Just had to find someone with them Instock
Old Mar 6, 2015 | 02:10 PM
  #186
Conway_160's Avatar
Conway_160
The only two places on E-Bay that carry them are both are Out of stock.
Old Mar 6, 2015 | 02:34 PM
  #187
2bad240's Avatar
2bad240
Everyone is buying them now. Jeffs set just showed up at my house last week.
Old Mar 6, 2015 | 02:58 PM
  #188
Conway_160's Avatar
Conway_160
How long did he have to wait? I called 3 places they was sold out as well.
Old Mar 6, 2015 | 04:34 PM
  #189
2bad240's Avatar
2bad240
Got here less than a week after he ordered them
Old Mar 6, 2015 | 08:15 PM
  #190
Conway_160's Avatar
Conway_160
Im willing to bet he got the last pair then. I should have ordered mine sooner :-(
Old Mar 6, 2015 | 09:02 PM
  #191
bealljk's Avatar
bealljk
What I would like to do is torque to 35, 50, 65, 80, 95. But then im not sure if I need to lossen them and repeat. The fsm says go to 35lbs then go 90* then another 90. Loosen all the way then retorque. Im probably going with either cosworth or dynosty since they are about the same price.
(not being sarcastic) have you thought about following ARP's instructions for torque'ing? I read the FSM on the their procedure w/a grain of salt and followed ARPs more closely, I used their lube and would recommend it - I bought a canister of it and if I can legally send you some I'd be more than happy to send you a few servings.
http://arpinstructions.com/instructions/202-4701.pdf
FWIW - I went with the OEM HR gaskets bought from Kyle at IPP and I've wrapped my exhaust ... very valid points brought up about unequal heat soak.
Old Mar 7, 2015 | 01:32 PM
  #192
Conway_160's Avatar
Conway_160
Arp reccomendation is 3 stages like I was going to do, only difference is im going to 95lbs and not 80. I have arps lube they sent with the fasteners.
Old Mar 7, 2015 | 02:55 PM
  #193
Resmarted's Avatar
Resmarted
I say do what dynosty recommends. *Ahem* lol
So that is do the Nissan recommended torque pattern (what studs/bolts first second third), and then do it in the 4-5 stages. Not the un-torquing and re torquing. That would be a good idea for torque to yeild bolts. I'm assuming the reason dynosty recommends doing it in more stages primarily because you are going above arp's recommended torque, and the heads are aluminum.
In my book that's the right way. Wouldn't do it any other way, but that's just me.
Old Mar 7, 2015 | 03:14 PM
  #194
Conway_160's Avatar
Conway_160
I plan on doing a few stages and not undoing thw torque.
Old Mar 10, 2015 | 03:02 PM
  #195
Conway_160's Avatar
Conway_160
Received my cosworth head gaskets today, and will be picking up my block tomorrow to start the assembly process. My big delay appears to be my headers have to wait on them now.
Old Mar 11, 2015 | 04:41 PM
  #196
Conway_160's Avatar
Conway_160
So today I started getting all my journal sizes so I can get my oil clearances.
All journals were measured 5 times with a micrometer then I took the average.
From the back of the crank forward my sizes were
Main's- 2.36040 in; 2.36044 in; 2.36046 in; 2.36040 in.
Stock Sizes are (2.3603 - 2.3612 in)
Pistons- 2.04044 in; 2.04044 in; 2.04040 in; 2.04040 in; 2.04048 in; 2.04040in
Stock Sizes (2.0455 - 2.0462 in)
Tomorrow I will be doing my oil clearances.
Last edited by Conway_160; Mar 12, 2015 at 05:55 AM. Reason: Don't know how to micrometer..
Old Mar 22, 2015 | 02:17 PM
  #197
Conway_160's Avatar
Conway_160
Old Mar 22, 2015 | 03:59 PM
  #198
woody03's Avatar
woody03
sub'd
Old Mar 22, 2015 | 05:48 PM
  #199
Conway_160's Avatar
Conway_160
now just need to get some headers,
Old Mar 23, 2015 | 07:16 PM
  #200
Resmarted's Avatar
Resmarted
Equal length shorties?
