Procharged G35
Old Apr 9, 2015 | 10:45 AM
  #221
Conway_160's Avatar
Conway_160
Motorn is installed!
Old Apr 11, 2015 | 12:25 PM
  #222
Conway_160's Avatar
Conway_160
Looks like I need to extend both of my upper O2 harnesses and I need to add some wire to the water temp sensor on the back of the motor thanks to the pathfinder mod (THING IS A PAIN IN THE ***)
Old Apr 11, 2015 | 08:36 PM
  #223
Conway_160's Avatar
Conway_160
Well the wire harness is installed, but my front 02 sensor harness are to short for my new exhaust so I had to extend my harnesses.
Only thing left to do is extend the two wires that go to my water temp sensor on the back of the motor by 1-2 inches.
Old Apr 12, 2015 | 01:45 PM
  #224
jdm-v35's Avatar
jdm-v35
wow you really had to extend them that far? looks good though. Really want to see what this thing does once its tuned. Hopefully you'll really get to test the limits of the procharger.
Old Apr 12, 2015 | 04:44 PM
  #225
Conway_160's Avatar
Conway_160
I didn't have to extended it that far, i could have gotten away with 6-8 inches but i just did a 15' to be safe that way i have room to keep it away from the headers.
Old Apr 14, 2015 | 07:01 PM
  #226
Conway_160's Avatar
Conway_160
Now just need figure out the misfire.
Old Apr 15, 2015 | 03:43 PM
  #227
Conway_160's Avatar
Conway_160
Well check swapped out both of my cam sensors, checked for spark on all plugs, reseated all fuel injectors, pulled off intake plenum to look for leaks, checked out plugs and found one ground not connected. Still misses and pain in the *** to start.
Old Apr 15, 2015 | 04:06 PM
  #228
Conway_160's Avatar
Conway_160
Default Log of car
Well here is a log of the car while trying to start it and when its running.
I feel that my Bank 1 timing is off, I hope not but.
CIPHER_4-15-2015_5-55-41_PM.zip
Old Apr 15, 2015 | 04:14 PM
  #229
2bad240's Avatar
2bad240
4-6 coils switched? Common problem. Easy to get the plugs mixed up. And could be hard to start if the tune is off its getting to much fuel. Hold the throttle and crank it
Old Apr 15, 2015 | 05:07 PM
  #230
Conway_160's Avatar
Conway_160
Originally Posted by 2bad240
4-6 coils switched? Common problem. Easy to get the plugs mixed up. Id be hard to start if the tune is off its getting to much fuel. Hold the throttle and crank it
Have to hold throttle wide open is the only way it will start, all my plugs and injectors are labeled so they are all good.
Besides the two grounds on the left front side and the one on the right above the exhaust and the one on the main harness right in the front is there any more grounds.
Old Apr 15, 2015 | 05:12 PM
  #231
2bad240's Avatar
2bad240
I had a broke wire right at a injrctor clip the other day and it had a dead miss. Use cipher to do cyl power test and turn them off one at a time till you figure out which is the problem. Then check connections on that cyl.
Old Apr 15, 2015 | 05:42 PM
  #232
Conway_160's Avatar
Conway_160
Thats the plan im just hoping this doesnt hurt my fresh motor
Old Apr 15, 2015 | 05:53 PM
  #233
Conway_160's Avatar
Conway_160
No matter which one I turn off it makes it worse
Old Apr 16, 2015 | 05:23 AM
  #234
meanz's Avatar
meanz
Haven't watched the video yet, but reading comments, hoping it didn't jump time a couple teeth. We had this problem with taywans engine. Pulled it all apart. Put back together and it's good now. His would start up no problem, just a bad miss.
Old Apr 16, 2015 | 07:04 AM
  #235
Conway_160's Avatar
Conway_160
Mine doesn't start up very easy, When I assembled it I ensured every thing way lined up and the chain tight via the tensioner. What would cause it to jump a tooth or two?
Old Apr 16, 2015 | 07:17 AM
  #236
2bad240's Avatar
2bad240
Got any pics of how you set the timing? I have done it more times than I wish to think about
Old Apr 16, 2015 | 07:39 AM
  #237
Conway_160's Avatar
Conway_160
No, pics unfortunately. I just followed the FSM.
Basically I put #1 bank the dowels facing up and the #1 cylinder intake and exhaust cams facing each other at roughly a 45* angle. Then I put the chain on the sprockets with the timing marks aligned. Orginally the dowels on the sprockets didn't line up with the timing marks, so I then rotated both sprockets in my hand with chain still attached until they lined up with the dowels and bolted them down. For the #2 bank I put the dowels at the top and lucky me the timing marks aligned with the sprocket dowels. Once they was all lined up and torqued down I put on the main timing chain and lined up the timing marks. once the chain was installed and the top guide was installed I hooked up the chain tensioner and pulled on that guide until the chain was tight'ish ensureing all the marks were still aligned. I had to redo this step 3-4 times since it jumped a tooth on me a few times.
Sorry if that makes no sense but in a nut shell I did what ever the FSM told me to do.
Old Apr 16, 2015 | 07:44 AM
  #238
2bad240's Avatar
2bad240
Sounds right but hard to tell how to do it over text. I usually put the top guide on after I put the tensioner on though.
Old Apr 16, 2015 | 07:55 AM
  #239
Conway_160's Avatar
Conway_160
I may have put the top guide on last on the final timing fix.
Old Apr 16, 2015 | 08:24 AM
  #240
meanz's Avatar
meanz
Well the first time the timing was set by his friend who went by the book. All the dots/links line up perfect. Even rotated it by hand and it seemed good. After we tore it back apart it was off 2 teeth. Retimed it, then putting everything back it jumped again so quick. Had to redo it again. I didn't time it, so I don't really know what happened when it jumped. But it jumped really quick with out issue. I was there and witnessed it happen though.
