Procharged G35
Old May 7, 2015 | 11:57 AM
  #321
Conway_160's Avatar
Conway_160
Originally Posted by Resmarted
If that's to reseal your upper pan (and they're actually going to remove it and re seal it) that's a great deal. You sure it isn't your rear main seal? Might be worth it to have them replace that too...
No its not the rear main, it didn't seal in between my upper oil pan and my rear timing cover. I can actually see the oil coming out.
Originally Posted by NAbuilderZ33
Just caught up reading your thread, Conway. Glad everything worked out and the worst of the issues you had are over. Seems like all thats left is the small stuff and a retune! Congrats!
I'm hoping that the worst of it is over. I may self tune to get it drivable and when I go home on leave take it to Hal and see if he can make it run good.
Old May 8, 2015 | 03:27 PM
  #322
Conway_160's Avatar
Conway_160
Well is truly showing me how much she loves me...
As you can see my lower radiator hose is/was rubbing my A/C compressor and ate up my hose. Good thing I was on base and was able to limp it home.
Old May 9, 2015 | 10:29 AM
  #323
jdm-v35's Avatar
jdm-v35
same thing happened to me when i put the bottom radiator hose in upside-down. Yes There is a top and bottom for that hose, and if its on the wrong way, the curve touches the pulley.
Old May 9, 2015 | 11:04 AM
  #324
Conway_160's Avatar
Conway_160
Thats what i think I did.
Old May 9, 2015 | 11:40 AM
  #325
eZg's Avatar
eZg
Damn.....Keep the Faith.
It'll be worth all this BS.
Old May 9, 2015 | 06:17 PM
  #326
bealljk's Avatar
bealljk
easy fix, easy fix...
Old May 9, 2015 | 07:35 PM
  #327
Conway_160's Avatar
Conway_160
Would be really easy if the procharger wasn't in the way.
Old May 11, 2015 | 05:41 PM
  #328
Conway_160's Avatar
Conway_160
Car Runs again, Now back to tuning it/breaking it in...
Old May 16, 2015 | 07:42 PM
  #329
Conway_160's Avatar
Conway_160
Well I think no matter how much I don't want to do it I have to pull the upper pan next week end. It's leaking way to much, and also one of the throttle body coolant lines I blocked off is leaking onto my driver side header.
And my car makes 1psi at 4k rpms...I really need to get a BOV that doesn't leak!
Old May 17, 2015 | 02:23 PM
  #330
Conway_160's Avatar
Conway_160
Well, A friend back home letting me try out his Perrin BOV and it may actually work!
But I found a broken driver side valve cover gasket and my header is covered in oil, but while I'm fixing that im going to go ahead and put my 750cc injectors in so I don't have to mess with that later.
Old May 31, 2015 | 05:38 AM
  #331
Conway_160's Avatar
Conway_160
First off let me say Nissan's RTV that gets sent with the OEM Rebuild kit is worthless! Spent all day yesterday dropping the damn upper oil pan to reseal it. What do I find when I pull off the upper oil pan? F'ing Nissan RTV that hasn't cured and looks like it just came out of the tube! F you Nissan!!!
After ever thing is put back together I waited about 2-2 1/2 hours before putting oil in the car to let the Loctite Grey RTV set. Well the good news is that that is no longer leaking from what I can tell but, the rear timing cover appears to be leaking a little bit and i'm willing to bet it's because I used the Nissan RTV. So I'm hoping that I can run a strip of grey art along the out side of the block and prevent it from leaking.
The worst part is right now I wouldn't be able to race it due to the oil leak
Now that my rant is over I need some help, when I open it up at around 5800-6000 it misses really bad, I currently have Stock Heat Range Copper NKG plugs in it. Is it possible that I'm blowing out the spark, or what else could cause this? Blown Head Gasket, but Oil Isn't Milky?
As soon as I get one of my iridium's replaced "diode is messed up" ill put those in.
Side note: F NISSAN RTV!
Old May 31, 2015 | 06:21 AM
  #332
OldManZ350's Avatar
OldManZ350
How much boost @ 6000rpm?
Plug Gap?
Fuel?
AFR's?
AIT's?
Ignition Timing
Old May 31, 2015 | 01:12 PM
  #333
Resmarted's Avatar
Resmarted
I'd really be surprised if you already blew your HG. Side note, why are you already "opening it up"? Did you do full break in/tune?!
How long did you give the nissan rtv to dry?
Stock heat range I doubt would be getting blown out. It might be a bad coil pack or something along those lines. Along side the questions oldman put forward, do you have good grounds to the engine/head?
What's your timing and spark dwell time through those rpm?
Old May 31, 2015 | 01:59 PM
  #334
Conway_160's Avatar
Conway_160
Well According to my boost guage, that reads -8 when car isn't running it was 6 psi.
Fuel 91 Oct with Ethanol
AFR's 12.4-12.5
Didn't log AIT's :-(
Timing was 13*
So just checked all my plugs, they was all finger tight and gapped to .040 so I droped that down to .032.
Old May 31, 2015 | 02:27 PM
  #335
Conway_160's Avatar
Conway_160
Well I think i'm going to throw in the towel and have some one else tune it. It is just making me mad that I cant get it to run right, now begins the saving some money to get it tuned maybe 2-3 months and she will live again.
Old May 31, 2015 | 03:10 PM
  #336
2bad240's Avatar
2bad240
Bump that timing a bit. I just installed my procharger on the guys car I sold it to. First pull timing was 14 and it was missing and breaking up around 5k Bumped it to 18 it was fine
AFR's 12.4-12.5
Timing was 13*
Old May 31, 2015 | 04:45 PM
  #337
OldManZ350's Avatar
OldManZ350
This is my street tune on 93 octane.
Please use a reference.
Yes, 93 vs 91 octane.
But, about 11psi@6000rpm vs 6psi
File Type: pdf
Old Jun 8, 2015 | 02:09 PM
  #338
Conway_160's Avatar
Conway_160
Ordered, lower control arm bushing so it will stop eating tires and will be dropping off the car to get tuned Wednesday and hopefully picking it up Friday.
Old Jun 10, 2015 | 02:20 PM
  #339
Conway_160's Avatar
Conway_160
Well car is headed to turner in a little bit, should have it back Friday.
Old Jun 10, 2015 | 03:47 PM
  #340
meanz's Avatar
meanz
Hoping for good results!
